fandyman Posted December 29, 2025 Author Posted December 29, 2025 1 hour ago, saveasteading said: Quite so. I'd advise you listen to the advice here. it may be free and we aren't always right, but it is by people who have done it/ do it for a living/ know the theory or the reality or both. Draughts are worse than cold bridges and that thermal pic may make it look worse than it is. draughts can be sorted with standard brush strips. so what do you do if you get awarded £30 towards fitting these? Up to you. You will spend many hundreds and they might agree that it isn't a justifiable claim. I've sat with an industry expert (selected by my solicitor) because of a cost claim by a client. I think it was about structural design. After a very expensive hour he said how interesting it had been, and I clearly knew more than him on the matter in question. That might be the case here, with the free advice above being equally expert. Not mine: the others who know this subject backwards. The “£30 brush strips” framing isn’t really applicable here. I’m not pursuing this via FENSA for compensation, and I’m not expecting token gestures. The escalation route I’m using is Section 75, which is joint and several liability for the entire contract value where goods or services aren’t provided with reasonable care and skill. That’s a very different legal framework from snagging or goodwill fixes. This isn’t about chasing draught brushes or minor sealing - it’s about establishing whether a persistent condensation/mould issue arising at a specific junction is an acceptable outcome of the installation, or whether it points to a defect in the way the threshold detail was executed. If an independent assessment concludes it’s acceptable, that’s the end of it. If it doesn’t, the remedies available under Section 75 are materially more than “£30”. I think it’s important to be accurate about the mechanisms involved, particularly for anyone else reading this thread who may be weighing up similar options.
Mr Punter Posted December 29, 2025 Posted December 29, 2025 I have not made a section 75 claim but will be interested to see how you get on. It does seem to favour the consumer. Please let us know how it progresses and what you had to do.
Spinny Posted December 29, 2025 Posted December 29, 2025 I have aluminium doors and three have cills. The manufacturers technical drawing shows that the cill (as with the frames) incorporates a thermal break betwen the external facing aluminium and the internal facing aluminium. If you google 'do PVC cills have a thermal break' their AI engine says PVC cills do not incorporate a thermal break etc because the UPVC is itself more insulating, and that air pockets are usually also incorporated into the design to reduce thermal bridging. I think you might start by obtaining and examining the technical drawings of the UPVC cill and frame designs, and also to identify what the manufacturers data sheets and specs and installation instructions have to say about the thermal properties the door and cill etc is designed to achieve - and with what installation detail. This then might allow you to identify specific product thermal specifications you would rightly be expecting to achieve, and to compare this with what has actually been achieved by the install. Any discrepancy will then either be due to a defective product, and/or a defective installation and therefore responsibility rest with the manufacturer and/or the installer. You say a conservatory was taken down and this window fitted into the opening in the wall ? Did you give any consideration to ensuring the opening was properly prepared for the door fitting - e.g. by a builder such as the one doing the demolition ? If you ordered the door without having the opening surveyed or prepared to the installer/manufacturer's instructions then I would imagine this might make a claim more questionable ? From the photographs it looks as though there is two layers of sealant and a DPM between the cill and the brickwork. One might expect this to at least provide a little insulation, but if you can feel draughts it seems the underside of the cill is not properly sealed up. So you might try actually getting the gap between the cill and the brickwork properly sealed up externally to stop all entry of cold air from the outside. I can understand you being very disappointed with the thermal performance - did you research and check this out when choosing your doors ? Personally I would expect the window company to be trying to do something more than complete denial.
saveasteading Posted December 29, 2025 Posted December 29, 2025 Interesting I looked it up and suspect this will be your problem copies of warranties, photographic evidence or independent expert reports, for example. as I expect your bank will immediately ask for this and you will be into costs. alternatively the other party will throw some tech explanation at the bank, and then they ask you. OTOH if the window people do think they have some liability, or better things to do with their time, you may get an offer to end the matter.
fandyman Posted December 29, 2025 Author Posted December 29, 2025 24 minutes ago, Spinny said: I have aluminium doors and three have cills. The manufacturers technical drawing shows that the cill (as with the frames) incorporates a thermal break betwen the external facing aluminium and the internal facing aluminium. If you google 'do PVC cills have a thermal break' their AI engine says PVC cills do not incorporate a thermal break etc because the UPVC is itself more insulating, and that air pockets are usually also incorporated into the design to reduce thermal bridging. I think you might start by obtaining and examining the technical drawings of the UPVC cill and frame designs, and also to identify what the manufacturers data sheets and specs and installation instructions have to say about the thermal properties the door and cill etc is designed to achieve - and with what installation detail. This then might allow you to identify specific product thermal specifications you would rightly be expecting to achieve, and to compare this with what has actually been achieved by the install. Any discrepancy will then either be due to a defective product, and/or a defective installation and therefore responsibility rest with the manufacturer and/or the installer. You say a conservatory was taken down and this window fitted into the opening in the wall ? Did you give any consideration to ensuring the opening was properly prepared for the door fitting - e.g. by a builder such as the one doing the demolition ? If you ordered the door without having the opening surveyed or prepared to the installer/manufacturer's instructions then I would imagine this might make a claim more questionable ? From the photographs it looks as though there is two layers of sealant and a DPM between the cill and the brickwork. One might expect this to at least provide a little insulation, but if you can feel draughts it seems the underside of the cill is not properly sealed up. So you might try actually getting the gap between the cill and the brickwork properly sealed up externally to stop all entry of cold air from the outside. I can understand you being very disappointed with the thermal performance - did you research and check this out when choosing your doors ? Personally I would expect the window company to be trying to do something more than complete denial. Agreed on separating product design vs installation detailing vs the surrounding building fabric. For uPVC I’m not expecting an “aluminium-style thermal break”, but I do agree the right starting point is the manufacturer’s section drawings / data sheets / installation instructions for the frame + cill so the intended thermal performance and assumed installation detail is clear. On the “opening prep” point: the opening was already in this state when I bought the property and has not recently been altered. The installer measured and supplied the door set to suit the existing opening; I didn’t specify a brick-to-brick detail or instruct them to omit any clearance/thermal mitigation. From my side, the key symptom remains persistent localised condensation/mould at the internal sill/lower frame junction, correlating with low surface temperatures on thermal imaging. I take your point that there may also be an air leakage component under the cill if the underside isn’t properly sealed - I’m going to check/confirm that separately - but the issue presents primarily as a cold internal surface at that junction rather than general room humidity.
fandyman Posted December 29, 2025 Author Posted December 29, 2025 (edited) 25 minutes ago, saveasteading said: Interesting I looked it up and suspect this will be your problem copies of warranties, photographic evidence or independent expert reports, for example. as I expect your bank will immediately ask for this and you will be into costs. alternatively the other party will throw some tech explanation at the bank, and then they ask you. OTOH if the window people do think they have some liability, or better things to do with their time, you may get an offer to end the matter. Agreed - I’m under no illusion this is cost- or effort-free. I’m proceeding on the basis that it now comes down to evidence and independent assessment. Just to clarify for anyone reading this later - warranties don’t really affect the process I’m following here. Under Section 75, the card provider’s assessment isn’t contingent on manufacturer or installer warranties. It’s about whether the goods/services were supplied with reasonable care and skill and whether the outcome is acceptable. Warranties can be part of the background paperwork, but they don’t limit or replace the bank’s liability. Photographic evidence and (if required) an independent expert report are what actually inform the decision, rather than whether a warranty exists or what it covers. I just wanted to make that distinction clear so people don’t conflate warranty routes with Section 75, as they operate independently. Edited December 29, 2025 by fandyman
craig Posted December 29, 2025 Posted December 29, 2025 There is a clear point you’re missing here. You employed the supplier to supply the door at the surveyed size, the installers installed said door into the existing opening. UPVC by design is “thermally” broken by the chamber design. This isn’t product related by the sounds of things but the lack of insulation under the threshold is. This needs done. Installing onto the outer brickwork in typical English builds is standard practice, it’s not the most thermally efficient position but they really haven’t done anything wrong here. I appreciate you have an issue needing resolved and didn’t exist before. Insulate under threshold and monitor. Discuss solutions before going down routes that sours the taste for everyone.
Roundtuit Posted December 29, 2025 Posted December 29, 2025 My advice is to take on board whatever @craig suggests. Unless your agreement with the installer included improving building fabric to mitigate existing cold-bridging, then you only have some minor snagging issues that you could probably have resolved yourself with some expanding foam and sealant in the time taken to craft your comprehensive and eloquent posts!
fandyman Posted December 29, 2025 Author Posted December 29, 2025 18 minutes ago, craig said: There is a clear point you’re missing here. You employed the supplier to supply the door at the surveyed size, the installers installed said door into the existing opening. UPVC by design is “thermally” broken by the chamber design. This isn’t product related by the sounds of things but the lack of insulation under the threshold is. This needs done. Installing onto the outer brickwork in typical English builds is standard practice, it’s not the most thermally efficient position but they really haven’t done anything wrong here. I appreciate you have an issue needing resolved and didn’t exist before. Insulate under threshold and monitor. Discuss solutions before going down routes that sours the taste for everyone. I don’t think I’m missing that point - I agree that uPVC frames are inherently more insulating due to their chambered design, and I’m not alleging a defective product. My concern has always been about the installation outcome, specifically at the threshold detail. Where I differ is that I’ve already tried to resolve this reasonably and practically with the installer. The installing team have attended multiple times, and the company owner himself has visited. On those visits, the issue was repeatedly dismissed as “normal” on the basis that heat rises, that the bottom of doors is always colder, and that condensation is caused by breathing or clothes drying indoors - which I made clear we do not do. Beyond additional sealant, no attempt was made to investigate or improve the threshold detail. I’m not disputing that installing onto outer brickwork is common practice in typical UK builds. I am questioning whether, in this specific case, the resulting internal surface temperature at the sill/frame junction - which is cold enough to repeatedly condense and grow mould under normal occupied conditions - is an acceptable outcome of reasonable care and skill. If insulating under the threshold is the appropriate mitigation, that’s exactly the sort of conclusion I was hoping to reach collaboratively. Unfortunately, that option was explicitly ruled out by the installer, who stated insulation under the sill is not required and that nothing further could be done. Given that, it seems reasonable to seek independent or regulatory review rather than continue a circular discussion where the issue is acknowledged in practice but dismissed in principle.
craig Posted December 29, 2025 Posted December 29, 2025 (edited) Then he’s talking nonsense. You always insulate all around the frame and that includes the threshold when necessary. It doesn’t need to be foam, Compriband would be good enough. Edited December 29, 2025 by craig
Redbeard Posted December 29, 2025 Posted December 29, 2025 (edited) OP, forgive me if I have missed this, but where do you see the mould and condensation? Is it on the main frame members (perhaps the bottom of the uprights and on all of the horizontal members) or perhaps only at the very bottom of the bottom members? The former could suggest that the specific frame sections are much less well-insulated than many of us thought* and the latter that it's perhaps the cold floor cooling the frame and taking it below the dew-point, in which case replacing the course of bricks immediately below the cill with Compacfoam could arguably warm things up enough to address (I hesitate to say 'cure' as we do not know enough about the specifics) the worst 'manifestations'. *Do they still use galv steel reinforcement at the corners of bigger frames? Edited December 29, 2025 by Redbeard
SBMS Posted December 29, 2025 Posted December 29, 2025 1 hour ago, fandyman said: My concern has always been about the installation outcome, specifically at the threshold detail. The installer is not responsible for the installation outcome in so far as its interaction with your existing building fabric. They are responsible for installing the door correctly - not for correcting or redesigning a thermally poor threshold detail that pre-exists the installation. Their response doesn’t seem great from a customer service perspective and as others have said they are responsible for foaming, sealing etc in so far as it relates to installation of their product. This will improve things for you no doubt. However, Unfortunately I think your camera shows the brickwork thermally bridging UP (not across the threshold which would imply no thermal break in the frame)… it’s a bit like fitting new tyres to your car.. you’d expect the fitter to balance your tyres and get the pressures right. But if your suspensions fundamentally out and the car pulls to the left: whilst it’s not the ‘installation outcome’ you’d like, It’s not the tyre fitters fault what they’re fitting onto isn’t fit for purpose..
fandyman Posted December 29, 2025 Author Posted December 29, 2025 54 minutes ago, Redbeard said: OP, forgive me if I have missed this, but where do you see the mould and condensation? Is it on the main frame members (perhaps the bottom of the uprights and on all of the horizontal members) or perhaps only at the very bottom of the bottom members? The former could suggest that the specific frame sections are much less well-insulated than many of us thought* and the latter that it's perhaps the cold floor cooling the frame and taking it below the dew-point, in which case replacing the course of bricks immediately below the cill with Compacfoam could arguably warm things up enough to address (I hesitate to say 'cure' as we do not know enough about the specifics) the worst 'manifestations'. *Do they still use galv steel reinforcement at the corners of bigger frames? Good question - the condensation and mould are localised, not distributed across all frame members. They occur at: the internal sill / lower frame junction, and the lower portions of the vertical frame members where they meet the sill, particularly at the junctions between the main door frame and the side panel frame. They are not present: higher up the verticals, across the mid or upper horizontal members, or elsewhere in the room under the same conditions. Thermal imaging shows a consistent cold band along the internal face of the lower frame/sill junction, with a sharper cold signature at the side-panel–to–main-frame junctions. That correlates exactly with where condensation and mould are forming. That’s why I’ve been focusing on the threshold detail rather than the frame sections generally. If the frame profiles themselves were underperforming thermally, I’d expect condensation higher up the uprights and more uniformly across the frame, which isn’t what’s being observed. On reinforcement: I haven’t opened the frame to confirm, but given the door size I would expect steel reinforcement at corners/uprights, as is typical. That said, the condensation pattern doesn’t suggest a corner-only or reinforcement-only issue - it aligns much more closely with the sill/support interface and local thermal continuity at that junction. I agree that the floor/threshold interface is likely playing a role in cooling the lower frame below dew point; the question I’m trying to resolve is whether the way the sill is supported and detailed has unnecessarily amplified that effect, given the resulting persistent condensation and mould.
fandyman Posted December 29, 2025 Author Posted December 29, 2025 9 minutes ago, SBMS said: The installer is not responsible for the installation outcome in so far as its interaction with your existing building fabric. They are responsible for installing the door correctly - not for correcting or redesigning a thermally poor threshold detail that pre-exists the installation. Their response doesn’t seem great from a customer service perspective and as others have said they are responsible for foaming, sealing etc in so far as it relates to installation of their product. This will improve things for you no doubt. However, Unfortunately I think your camera shows the brickwork thermally bridging UP (not across the threshold which would imply no thermal break in the frame)… it’s a bit like fitting new tyres to your car.. you’d expect the fitter to balance your tyres and get the pressures right. But if your suspensions fundamentally out and the car pulls to the left: whilst it’s not the ‘installation outcome’ you’d like, It’s not the tyre fitters fault what they’re fitting onto isn’t fit for purpose.. I agree that installers are not expected to redesign an entire building, and I’m not suggesting they should. Where I differ is that the interaction between a supplied product and the existing building fabric is part of the installation outcome, particularly where that interaction creates an internal surface that repeatedly drops below dew point under normal conditions. The difficulty with the tyre analogy is that in this case the installer didn’t just “fit tyres to an unknown suspension”. They surveyed the opening, specified the product, chose the threshold detail, and installed it. I didn’t instruct a brick-to-brick threshold or ask for zero clearance beneath the sill - that detail arose from the way the installation was measured and executed. On the thermal imaging point: if the brickwork were thermally bridging up the frame as the primary mechanism, I’d expect a more diffuse vertical gradient extending into the room and along the uprights. What’s actually observed is a consistent cold band at the sill/frame junction with intensified cold signatures at frame junctions, which correlates with where condensation and mould are forming. That pattern points to the threshold/support detail being a significant contributor, not just the general floor construction. I’m not asserting fault by default - I’m trying to establish whether the outcome is an unavoidable consequence of the existing building fabric, or whether the threshold detailing has unnecessarily amplified the cold surface at that junction. That distinction matters, and it’s why I’m seeking independent review rather than relying on analogies or assumptions.
SBMS Posted December 29, 2025 Posted December 29, 2025 9 minutes ago, fandyman said: I agree that installers are not expected to redesign an entire building, and I’m not suggesting they should. Where I differ is that the interaction between a supplied product and the existing building fabric is part of the installation outcome, particularly where that interaction creates an internal surface that repeatedly drops below dew point under normal conditions. The difficulty with the tyre analogy is that in this case the installer didn’t just “fit tyres to an unknown suspension”. They surveyed the opening, specified the product, chose the threshold detail, and installed it. I didn’t instruct a brick-to-brick threshold or ask for zero clearance beneath the sill - that detail arose from the way the installation was measured and executed. On the thermal imaging point: if the brickwork were thermally bridging up the frame as the primary mechanism, I’d expect a more diffuse vertical gradient extending into the room and along the uprights. What’s actually observed is a consistent cold band at the sill/frame junction with intensified cold signatures at frame junctions, which correlates with where condensation and mould are forming. That pattern points to the threshold/support detail being a significant contributor, not just the general floor construction. I’m not asserting fault by default - I’m trying to establish whether the outcome is an unavoidable consequence of the existing building fabric, or whether the threshold detailing has unnecessarily amplified the cold surface at that junction. That distinction matters, and it’s why I’m seeking independent review rather than relying on analogies or assumptions. Im not sure I agree with your interpretation of the thermal imaging. That pattern could definitely be consistent with ground-contact brickwork below bridging cold up. Do you think then that this isn’t the culprit and it’s the frame threshold? Ie a manufacturer issue?
Mattg4321 Posted December 30, 2025 Posted December 30, 2025 Rightly or wrongly, I think if you employed 10 different firms to do this work, then you would get it installed in this way 10 times (hopefully with better sealing - there shouldn’t be any draughts!). If the opening isn’t properly prepared, that’s on you. Of course, a great company would survey and suggest improvements before going ahead, but most of these guys don’t really understand this sort of thing. It’s for the customer/architect to spec. These guys just know how to fit windows and doors so they are properly sealed and don’t let draughts or water in and open and close smoothly. Anything beyond that is highly unlikely. Do you have condensation build up elsewhere in the house? Does sound like this room is probably colder than the rest of the house - reading between the lines? Do you have any mechanical ventilation? Intermittent or continuous?
SBMS Posted December 30, 2025 Posted December 30, 2025 11 hours ago, fandyman said: whether the way the sill is supported and detailed has unnecessarily amplified that effect, given the resulting persistent condensation and mould. I think from this you’re hoping that because they’ve bedded it on silicone and packers that this is exacerbating the thermal bridging. It’s not. And I think it’s standard installation. What should have happened is your lower course of bricks should have been taken off and replaced with marmox, compacfoam etc. as others have said this isn’t the installer responsibility and they’ve installed as any installer would. 1
fandyman Posted December 30, 2025 Author Posted December 30, 2025 24 minutes ago, Mattg4321 said: Rightly or wrongly, I think if you employed 10 different firms to do this work, then you would get it installed in this way 10 times (hopefully with better sealing - there shouldn’t be any draughts!). If the opening isn’t properly prepared, that’s on you. Of course, a great company would survey and suggest improvements before going ahead, but most of these guys don’t really understand this sort of thing. It’s for the customer/architect to spec. These guys just know how to fit windows and doors so they are properly sealed and don’t let draughts or water in and open and close smoothly. Anything beyond that is highly unlikely. Do you have condensation build up elsewhere in the house? Does sound like this room is probably colder than the rest of the house - reading between the lines? Do you have any mechanical ventilation? Intermittent or continuous? I don’t disagree that many firms would install it this way - that’s kind of the point. “Common practice” and “acceptable outcome” aren’t always the same thing, particularly when the outcome is a persistent cold internal surface that repeatedly condenses and grows mould under normal conditions. I didn’t alter or newly create the opening - it existed as-is when I purchased the property. The installer surveyed it, specified the door, and executed the threshold detail. I didn’t instruct a brick-to-brick sill or prevent any form of thermal mitigation. I also accept that many installers focus on airtightness, water ingress, and operation rather than thermal junction performance. But the question I’m asking isn’t whether this is unusual - it’s whether the resulting internal surface conditions are an acceptable outcome of reasonable care and skill. To answer your questions: there’s no comparable condensation elsewhere in the house, the room is heated in line with the rest of the property, and RH is typical for an occupied dwelling. That’s why the issue being confined to the sill/frame junction matters. I’m not expecting perfection or passive-house detailing - I’m trying to establish whether this outcome is unavoidable, or whether the threshold detail has unnecessarily coupled the internal frame to cold masonry in a way that could reasonably have been mitigated.
fandyman Posted December 30, 2025 Author Posted December 30, 2025 39 minutes ago, SBMS said: I think from this you’re hoping that because they’ve bedded it on silicone and packers that this is exacerbating the thermal bridging. It’s not. And I think it’s standard installation. What should have happened is your lower course of bricks should have been taken off and replaced with marmox, compacfoam etc. as others have said this isn’t the installer responsibility and they’ve installed as any installer would. I don’t think that follows, and it’s not what I’m asserting. I’m not saying silicone or packers create a thermal bridge in isolation. I’m saying the resulting installation detail has coupled the internal frame directly to cold, ground-connected masonry, producing an internal surface temperature low enough to repeatedly condense and grow mould. That outcome is observable and isn’t in dispute. Replacing the lower course of bricks with Marmox / Compacfoam would certainly be one way of mitigating that - but that doesn’t automatically mean the only way, nor does it mean the installer bears no responsibility for the detail they chose and executed. They surveyed the opening, specified the product, and installed the threshold. I didn’t instruct a brick-to-brick sill or prevent any form of thermal mitigation. Saying “this is how any installer would do it” describes industry normality, not whether the outcome is acceptable when it results in persistent condensation under normal internal conditions. Those two things aren’t the same. I’m not arguing that the installer should redesign the house or retrofit insulation into the floor. I’m questioning whether the threshold detail they implemented has unnecessarily amplified heat loss at that junction, and whether the resulting internal surface conditions are a reasonable outcome of the service provided. That’s why I’ve been careful to frame this as an outcome-based question, not a blanket criticism of standard practice.
Redbeard Posted December 30, 2025 Posted December 30, 2025 58 minutes ago, fandyman said: I’m questioning whether the threshold detail they implemented has unnecessarily amplified heat loss at that junction, Can I ask what you had there before? I think I understand that there was simply the existing opening - unadorned by frame or anything - and a conservatory bolted on the back. What was on the floor at that junction between room and conservatory - i.e. over the area in which condensation and mould is occurring? Hypothesis is that the brick was 'sucking' enough to disperse the condensation so that you did not see it as droplets. Then you put something else hard and not terribly insulated next to that area and *that* became the 'target area'. As I say, simply a hypothesis....
fandyman Posted December 30, 2025 Author Posted December 30, 2025 35 minutes ago, Redbeard said: Can I ask what you had there before? I think I understand that there was simply the existing opening - unadorned by frame or anything - and a conservatory bolted on the back. What was on the floor at that junction between room and conservatory - i.e. over the area in which condensation and mould is occurring? Hypothesis is that the brick was 'sucking' enough to disperse the condensation so that you did not see it as droplets. Then you put something else hard and not terribly insulated next to that area and *that* became the 'target area'. As I say, simply a hypothesis.... That’s a fair hypothesis to explore, but there’s an important factual point to clarify. Before the doors were installed, there was a continuous screed and floor build-up running from the living space into the conservatory area. The ground-level brickwork at the opening was not exposed internally, and there was no visible condensation or mould at that junction. As part of the works, the conservatory base was removed and the screed was cut back to just behind the brick line. The installer then positioned the sill/frame forward and created a new internal junction, including a small expanding-foam upstand between the sill/frame stack and the remaining screed/finished floor. That foam is incomplete in places and has visible gaps. So while I don’t rule out the ground-contact masonry contributing to cooling, the key change is that the installation has introduced a new cold internal surface and junction detail that did not previously exist, and that surface is now where condensation and mould are forming. That’s why I’ve been focusing on the threshold detail itself - not because I think the building fabric was perfect before, but because the installation altered how that fabric is thermally coupled to the internal environment. I’m not asserting a single cause; I’m trying to understand whether the way the sill and frame were positioned and detailed has unnecessarily amplified what was previously a non-manifesting condition.
SBMS Posted December 30, 2025 Posted December 30, 2025 27 minutes ago, fandyman said: That’s a fair hypothesis to explore, but there’s an important factual point to clarify. Before the doors were installed, there was a continuous screed and floor build-up running from the living space into the conservatory area. The ground-level brickwork at the opening was not exposed internally, and there was no visible condensation or mould at that junction. As part of the works, the conservatory base was removed and the screed was cut back to just behind the brick line. The installer then positioned the sill/frame forward and created a new internal junction, including a small expanding-foam upstand between the sill/frame stack and the remaining screed/finished floor. That foam is incomplete in places and has visible gaps. So while I don’t rule out the ground-contact masonry contributing to cooling, the key change is that the installation has introduced a new cold internal surface and junction detail that did not previously exist, and that surface is now where condensation and mould are forming. That’s why I’ve been focusing on the threshold detail itself - not because I think the building fabric was perfect before, but because the installation altered how that fabric is thermally coupled to the internal environment. I’m not asserting a single cause; I’m trying to understand whether the way the sill and frame were positioned and detailed has unnecessarily amplified what was previously a non-manifesting condition. I might be misunderstanding so just want to clarify… previously where this junction existed both sides were effectively warm? Ie one side was your internal house and the other side was a conservatory (heated?) 1
saveasteading Posted December 30, 2025 Posted December 30, 2025 28 minutes ago, fandyman said: trying to understand whether the way the sill and frame were positioned and detailed has unnecessarily amplified what.... I'd be surprised if an arbitrator or similar deemed a window installer should have these skills. Unless they advertise.. 'more than a window company' sort of thing. If you'd gone through a general contractor then this might be different, but you'd have paid a lot more.
fandyman Posted December 30, 2025 Author Posted December 30, 2025 2 hours ago, SBMS said: I might be misunderstanding so just want to clarify… previously where this junction existed both sides were effectively warm? Ie one side was your internal house and the other side was a conservatory (heated?) Not exactly. There was a conservatory attached, but it wasn’t part of the main thermal envelope and wasn’t heated to house temperatures. More importantly, the junction itself wasn’t exposed internally. Before the doors were installed, there was a continuous screed/floor build-up across that threshold area, so no cold internal sill/frame surface existed and there was no condensation or mould there. The change introduced by the installation is a new internal sill/frame junction directly coupled to ground-connected masonry. That exposed surface is now cold enough to condense under normal conditions
fandyman Posted December 30, 2025 Author Posted December 30, 2025 (edited) 2 hours ago, saveasteading said: I'd be surprised if an arbitrator or similar deemed a window installer should have these skills. Unless they advertise.. 'more than a window company' sort of thing. If you'd gone through a general contractor then this might be different, but you'd have paid a lot more. Reasonable care isn’t limited to what a trade normally chooses to think about - it’s judged on the outcome of the service. If the installation creates a new internal surface that predictably falls below dew point under normal conditions, it’s fair to at least question whether that outcome is acceptable. I didn’t engage a general contractor or an architect, but I also didn’t instruct a detail that would knowingly create condensation and mould. The installer surveyed the opening, specified the product, and executed the threshold detail. Whether that outcome is ultimately deemed acceptable or not is exactly why I’m seeking independent review - not because I expect installers to be “more than a window company”, but because outcomes matter regardless of marketing labels. Edited December 30, 2025 by fandyman
