Recently my wife asked me to replace all the mounting boxes in our house. They're all pretty old and it seemed like a good idea. I bought new boxes for all the sockets and light switches in the house and although I'm not an electrician I did go to college to do level 2 electrical installations so thought this would be easy. It turns out that all the premade holes in the new boxes are in  different positions to the old boxes. So it's not just a case of removing the old ones and screwing in the new ones. I'd have to drill new holes for every single one. The thing is when I started drilling all the plaster started breaking away in big pieces. I guess my question is can I just fill in the cavity with filler and screw straight into that? What would an electrician do in this situation?
Thanks in advance
Unless the back boxes are rusted, threads stripped, or some other damage, an electrician would do nothing.
It seems a strange idea to change something you should not ever see when the fitting is in place.
Photos might explain the why?
If they are an issue, I would be more concerned that the wiring is an issue also. Are you sure you didn't miss hear her? What prompted the request?
I guess they're surface mounted?
Old ones won't have bonding connecteions for metal face plates, but those can be soldered on without removing from the wall.
Other than that, as long as they are deep enough to take the gubbins for modern sockets without crushing cables I can't think of a reason to replace them?
