saveasteading Posted 15 hours ago Posted 15 hours ago We are wrapping the scaffolding to try to keep the rain out while framing and cladding. 1
Redbeard Posted 14 hours ago Posted 14 hours ago (edited) I like the way you used the cardboard cut-outs to boost the apparent numbers!😉 Edited 14 hours ago by Redbeard 3
SteamyTea Posted 14 hours ago Posted 14 hours ago I work in an industrial heritage visitor attraction, we use a lot of scaffolding in creative ways. It is brilliant stuff.
saveasteading Posted 13 hours ago Author Posted 13 hours ago 1 hour ago, Redbeard said: the apparent numbers There were 3 more off picture. The gang was 5, but in the afternoon others turned up after completing other jobs, because it needed all hands to beat the wind. It had been foul weather.
ProDave Posted 13 hours ago Posted 13 hours ago I am more curious what is all the timber laid out on the floor?
Big Jimbo Posted 13 hours ago Posted 13 hours ago The guy second from the right is defo the bloke who plays keyboards in the Pet Shop Boys 1
FuerteStu Posted 13 hours ago Posted 13 hours ago 17 minutes ago, ProDave said: I am more curious what is all the timber laid out on the floor? Wall template?
SteamyTea Posted 13 hours ago Posted 13 hours ago 35 minutes ago, Big Jimbo said: The guy second from the right is defo the bloke who plays keyboards in the Pet Shop Boys Looks more like something from The Long Good Friday. But no matter. 1
MikeSharp01 Posted 11 hours ago Posted 11 hours ago I like that you have Ned Kelly wearing his metal head gear working there in the middle with the green high viz. 1 1
saveasteading Posted 9 hours ago Author Posted 9 hours ago 4 hours ago, ProDave said: timber laid out on the floor? You see rooms. Sole plates. The structure is hybrid. The portal frame stays in place and already has a new roof.. The existing slab is 175 thick. Rooms internally will be timber stud and the external walls are being studded too, as the photo shows. 6x2 joists and a few steel beams over big spaces. One great first floor deck will then receive walls and ceilings. The sole plates are packed up to level and will then be grouted, but they are not fixed yet as can be seen. Due to kicking and wind that will have to be done again. The timber house industry works to +/- 10mm, which appals me. We are working to +/-2. ie try for 1mm but accept that a few will vary from that. We hope the early precision makes everything that follows fit better and not squeak.
SteamyTea Posted 4 hours ago Posted 4 hours ago ♫You see rooms. Sole plates. The structure is hybrid. What a wonderful life.♫
