Mulberry View Posted Friday at 17:11 Posted Friday at 17:11 We're in the process of detailing our whole house roof with a Sika single-ply membrane. We'd like a nice kerb-edge trim (ideally Zinc/Alu), but how would this be detailed if fitted after the membrane? Is this a normal thing to do? I've not approached an installer yet, maybe they'll know the answer, but asking you good chaps! If anyone has done similar, pics would be welcome.
gaz_moose Posted Friday at 17:25 Posted Friday at 17:25 those fillet strip details look fiddly. the plastic kurb edge trim just gets nailed on with poly top nails and looks kind of naff. I guess you could nail it along the top edge so you dont see the fixings. 1
Mulberry View Posted Friday at 17:41 Author Posted Friday at 17:41 13 minutes ago, gaz_moose said: those fillet strip details look fiddly. the plastic kurb edge trim just gets nailed on with poly top nails and looks kind of naff. I guess you could nail it along the top edge so you dont see the fixings. I'm not experienced at all with this type of roof, so any/all feedback is appreciated. I guess the drip edge could be turned back up on the inside and fixed to the underneath of the 40x70 timber, they're used to that detail with Zinc roofing if I was to get trims done by a Zinc installer. But how to seal it to the Single-Ply on top? Architect seems to show another membrane.
gaz_moose Posted Friday at 18:26 Posted Friday at 18:26 ive only done 2 epdm roofs so am far from an expert. it looks like your epdm is set to somehow go over the top of the edge trim. with the plastic stuff the edge trim goes on last then you pull the epdm downwards and trim it with a stanley knife. theres loads of videos on it by a youtube guy called oakwood garden rooms, thats how i learned it. 1
Gone West Posted Friday at 19:59 Posted Friday at 19:59 We had a Sika single-ply membrane installed on a small extension a couple of months ago. The edge trim upstand is a steel profile covered with a membrane. The profiles were fitted first, then the underlay and then the roof membrane was welded to the profile. The edge of the roof was just a double layer of 18mm OSB. 1
Mulberry View Posted Saturday at 10:16 Author Posted Saturday at 10:16 14 hours ago, Gone West said: We had a Sika single-ply membrane installed on a small extension a couple of months ago. The edge trim upstand is a steel profile covered with a membrane. The profiles were fitted first, then the underlay and then the roof membrane was welded to the profile. The edge of the roof was just a double layer of 18mm OSB. Thanks for this. Helpful. So the steel profile is seen from the ground I assume? Don't suppose you took any pics of it in progress?
Gone West Posted Saturday at 11:18 Posted Saturday at 11:18 1 hour ago, Mulberry View said: Don't suppose you took any pics of it in progress? I'll have a look, probably not from close to.
Andehh Posted Saturday at 21:27 Posted Saturday at 21:27 Ours look very similar to the above, if your desperate I can nip up and take some pictures.
makie Posted Saturday at 22:13 Posted Saturday at 22:13 10 hours ago, Gone West said: These are the best I've got, sorry. Shouldn't be an issue if they have welded it correctly but that up-stand should be on top of the base layer. 1
Gone West Posted yesterday at 07:57 Posted yesterday at 07:57 9 hours ago, makie said: Shouldn't be an issue if they have welded it correctly but that up-stand should be on top of the base layer. IIRC the upstand is on top of the underlay.
makie Posted 23 hours ago Posted 23 hours ago 15 hours ago, Gone West said: IIRC the upstand is on top of the underlay. The bottom picture, it is not.
Gone West Posted 14 hours ago Posted 14 hours ago 8 hours ago, makie said: The bottom picture, it is not. I don't understand. The underlay used is a material that looks like a dark green nylon pot scourer and isn't visible in the last picture 😕.
Nick Laslett Posted 14 hours ago Posted 14 hours ago (edited) @Mulberry View, not the exact same finish requirements, but here are some pictures of how they did our flat roof. Aluminium trims are fitted at the same time as the Sika membrane. The bespoke Aluminium Trim appears to be riveted to the Sika membrane. Then another strip of membrane is glued over the top. Hard to tell, but from left to right it goes: slate tile, lead, aluminium, membrane strip, membrane. For your detail, you would have a bespoke piece of aluminium to cover the curb. Edited 13 hours ago by Nick Laslett 1
Nick Laslett Posted 14 hours ago Posted 14 hours ago (edited) “Sika Sarnafil Single Ply Trims” appears to be the magic words. https://cwgsheetmetal.co.uk/roof-flashings-edging-trims/#3 USA website here with lots of detail pictures, which give an idea. https://www.hickmanedgesystems.com/brands/sika-roofing Good video showing how membrane and trims are fitted. https://youtu.be/V7zutZU_Jwc?si=SPFDU7ByOXvNTPGI Edited 14 hours ago by Nick Laslett 1
Gone West Posted 6 hours ago Posted 6 hours ago 7 hours ago, Nick Laslett said: Aluminium trims are fitted at the same time as the Sika membrane. That's interesting, our trims were steel and were screwed down and the membrane was welded to the trim.
Nick Laslett Posted 5 hours ago Posted 5 hours ago 44 minutes ago, Gone West said: That's interesting, our trims were steel and were screwed down and the membrane was welded to the trim. I actually think the ones in my picture and link are galvanised steel. Looking at our flashing schedule they called it “Trocal Metal” https://grc.sika.com/dam/dms/gr01/3/010945011000000001_Sika_Trocal_Metal_Sheet_Type_S_eng.pdf I’m not sure why I thought they were aluminium. So ours are galvanised steel too.
