cwr Posted Wednesday at 13:25 Posted Wednesday at 13:25 Hi folks Any advice on best method of doing external plasterboarded corners with tape/fill/sand? I've used paper tape before and the results were aesthetically good, but was very susceptible to chipping. Is the paper tape with a metal film good, or is there a more robust solution out there (that's not wet plastering)? Thanks
Crofter Posted Wednesday at 13:50 Posted Wednesday at 13:50 If it's a location that might be susceptible to wear, I'd look at an extruded metal bead.
Mr Punter Posted Wednesday at 13:51 Posted Wednesday at 13:51 I have just done a small bit with the metal reinforced paper tape on some boxing. It was not too bad. If I was doing it on price we would be hungry! 1
Russell griffiths Posted Wednesday at 16:06 Posted Wednesday at 16:06 Plastic beads, the only proper way to get a sharp external corner IMHO
Crofter Posted Wednesday at 16:23 Posted Wednesday at 16:23 16 minutes ago, Russell griffiths said: Plastic beads, the only proper way to get a sharp external corner IMHO Why plastic rather than metal?
Mr Punter Posted Wednesday at 16:28 Posted Wednesday at 16:28 21 minutes ago, Russell griffiths said: Plastic beads, the only proper way to get a sharp external corner IMHO I have only seen them used for external render. The OP is doing tape and fill plasterboard.
JohnMo Posted Wednesday at 17:02 Posted Wednesday at 17:02 3 hours ago, cwr said: Is the paper tape with a metal film good, or is there a more robust solution out there (that's not wet plastering)? Metal reinforced tapes are good, nice true and straight corners, and difficult to damage. 1
Susie Posted Wednesday at 17:13 Posted Wednesday at 17:13 6 minutes ago, JohnMo said: Metal reinforced tapes are good, nice true and straight corners, and difficult to damage. Used these on my plant room, and happy with them to use again, would also consider using them for a vaulted ceiling to wall internal corner on my next room. It’s also dependent on the fill you do, how many fills and how many sands.
JohnMo Posted Wednesday at 17:50 Posted Wednesday at 17:50 Corner tapes this is what our taper insisted on for our vaulted ceiling (nearly all of the rooms). Myself and grandson did the hall and it was great to use. https://www.belmoretools.co.uk/levelline-drywall-corner-tape-2-75-in-x-100-ft-roll.html
Russell griffiths Posted Wednesday at 18:08 Posted Wednesday at 18:08 1 hour ago, Crofter said: Why plastic rather than metal? They don’t dent, they get bashed, the plaster pops off, you can then re fill the damaged area without changing the whole bead. 1
Russell griffiths Posted Wednesday at 18:13 Posted Wednesday at 18:13 1 hour ago, Mr Punter said: I have only seen them used for external render. The OP is doing tape and fill plasterboard. Available in thin coat for internal tape n fill, widely used in America and Australia where they tape n fill far more than us they do a massive amount of decorative beads including shadow gap and ones that take led strip. we are a bit stuck in 1960. 1
cwr Posted Wednesday at 18:44 Author Posted Wednesday at 18:44 4 hours ago, Crofter said: If it's a location that might be susceptible to wear, I'd look at an extruded metal bead. Can you get ones for fill and sand? I've seen some at 2 or 3 mm but surely they're for wet plater as would stick out too far? Unless possibly along the tapered edge but I can't always arrange that.
Mike Posted Wednesday at 18:45 Posted Wednesday at 18:45 4 hours ago, Mr Punter said: I have just done a small bit with the metal reinforced paper tape on some boxing That's an unusual octagonal access hatch...
Mr Punter Posted yesterday at 08:28 Posted yesterday at 08:28 13 hours ago, Mike said: That's an unusual octagonal access hatch... Yes a bit odd. It is fire and acoustic rated. Maybe the octagon made it a bit stronger? 1
