Building a double garage as shown in photo attached.
Id like the fall to be from front to back across the 5.8m span.
I'm struggling to find the right roof rafter size to tolerate that span.
I plan to have OSB roof, EPDM (rubber roof) covering, interior insulation in between rafters.
Is the 5.8m span doable?
Could I bolt two rafters together across the 5.2m span to reduce down the 5.8m span into two separate sections attached to the double rafters by joist hangers; sitting on 1 end of the 5.8m wallplate and the other ontop of the steel wallplate, therefore allowing me to use smaller rafter sizing?
Is it too much hassle, should I just go across the 5.2m span (which is less than ideal as it doesn't help with the garden side view of the garage for my plans.
Advice welcome and thanks in advance!
You appear to have have two brick piers in the right place to put another beam across, thereby reducing your rafter span in half.
Unfortunately I drew that a bit off, the posts are not in the same place, this is an extension of the previous single width garage.
I can't put an rsj between them. But I see no reason why I can't tie in another pillar to align, and then span that.
Could I use a UB?
Good shout guys, any thoughts on the rsj/ub to span the garage opening?
On 01/06/2025 at 04:14, Conor said:
I'd run a steel beam across between the two piers. Something like a 178x102x19.
Could I use a UB?
2 hours ago, ProDave said:
Span all the joists the shorter 5.2M dimension?
Then my fall has to be in a direction I'd ideally not wanted to be
2 hours ago, SBMS said:
Engineered posi rafter could do a 5.8m span.
Thought about that but too expensive and too large/tall for just the garage roof
48 minutes ago, ab122 said:
too expensive
You can't have big spans without beams or deep joists.
I'd guess that the beams across the door and the midpoint would be more like 250 deep for economy or shallower at a price.
OR posijoists or similar....at a cost.
The slopes can be sorted by various means, which can be discussed later.
Once (if) you acccept that there are these heavyish members and costs then  the next thing is you need an SE to design it to building regulations.
We don't do calculations and other detailed design on here.
I wouldn't use osb. Any tiny leak and it fails , or have a very well built covering.
Makes sense, while I look into that, how can the slope be handled later? Can furrings go across (90 degrees) as opposed to along the joists then? To change the slope?
Why can't the slope go either way?  surely whatever wall plate you support them on would be on a slope so the next joist along is a little lower etc.  Is this not allowed?  Are you forced to put them all level and add firrings?
And if that is the case, whichever way you want the slope it would have to be dead flat in both directions then firrings added?
I'm self building, so I guess I could do whatever. But the way I was advised is fully flat and then firring ontop of joists, didn't know I could put them across, nor that I could put the wall plate on a slant. Though the walls are level so I'd probably find that hard to do
Cheaper than putting in steel maybe.. you could do a reduced depth joist (maybe an 8 inch) with larger chords to beef it up. If you want larger spans without a steel you’ll have to get something engineered… don’t think you’ll get away with anything less than 7 or 8 inches tall anyway spanning that much?
You could always ply all the way over first then put your firrings on whichever direction you want then ply on top of them to form your sub deck.
So to make sure I understand, what you are saying is put the steel above garage door opening and use the posijoists to span from front to back without the need for steel.
And to use an 8" posijoist?
Thanks
