d438a1 Posted May 30 Posted May 30 Hi there, I'm just about to go ahead with a deposit for a solar system but wondering if I should be future proofing more. Currently on single phase which powers the house and a large separate garage and flat above. That is fed on a dedicated 24m2 cable. Solar wise, we are going sig energy and looking at 16kw batteries and 14kw PV. As part of this, we are also getting the multiphase zappi charger. All of this will be housed in the garage. Upcoming in next year or so: - 16kw ASHP. Power input I think is around 6kw. This is sized large to also provide heat for workshop. New large workshop building. It will have a lot of equipment, some needing 16amp supply but as it’s just me in theory I’d only use a large dust extractor (2-3kw max) and 1/2 machines at a time with max maybe an additional 2-3kw. The existing garage will be converted at some point to an air bnb which may put more concurrent demand on. Likely we may but a small gas boiler in to utilise existing LPG tank we have in order to remove existing electric shower and small water heater for tap. I've attached a few photos of current setup. So i guess my questions are... With my future demands (whereby there could be a mix of house, airbnb garage and workshop running at same time), should I be considering 3 phase? Even if the above demands 3 phase, is it worth getting solar 3 phase equipment? Or would it make more sense to seperate phases to garage, house and workshop? I'll also note that utilising 3 phase for the car charger and workshop for bigger equipment is a real nice to have Thanks
JohnMo Posted May 30 Posted May 30 Haven't you answered your question. 11 minutes ago, d438a1 said: multiphase zappi charger Wouldn't that need 3 phase? 13 minutes ago, d438a1 said: small gas boiler in That will exclude you from any grants, for a heat pump.
d438a1 Posted May 30 Author Posted May 30 The zappi works on single or multiphase. I always charge overnight anyway, so it's not deal breaker if it stays on 7kw. On the main house I'm replacing an existing LPG boiler with heat pump. I didn't realise it would somehow invalidate that grant if i got a separate gas boiler later for other building? Thanks
nod Posted May 30 Posted May 30 The energy suppliers are mad keen on selling three phase Weather you need it or not
Kelvin Posted May 30 Posted May 30 We are also going SigEnergy with 24kWh of battery storage. With your demand wouldn’t you better going slightly larger on battery storage? The Sig battery system is very flexible so easy enough to add more later. Adding the extra 8kWh cost £2300. I put single phase in because it was a few hundred pounds compared to 3 phase which was several thousand. To some extent going 3 phase might have been better but several thousand buys a lot of electricity and the single phase supply seems adequate for our needs. With your likely future demand going 3 phase will be more flexible but don’t underestimate the cost. Get an estimate from your DNO asap.
JohnMo Posted May 30 Posted May 30 2 hours ago, d438a1 said: 16kw ASHP I would make sure this will do all your needs, as the nameplate rating may not (very unlikely) to be correct at your design outside temperature. 16kWh of battery isn't going to last long driving a 16kW heat pump. If your max draw is 6kW, less than 3 hours your battery is flat. Especially so if you're in the workshop at the same time. Heat pump at full load and PV generation good at same time is unlikely. Have you checked the PV output in the winter, so you get to disappointed mid winter doing 140W instead of 14kW.
d438a1 Posted May 30 Author Posted May 30 Thanks for feedback. The 16kw was advised as part of a recent quote I had. I was already stretching budget to get 16kw battery. But I'll take another look! But as you said it seems easy to add later. I've definitely maxed out what I can with solar at 32 panels for suitable roofs.
joth Posted May 30 Posted May 30 4 hours ago, d438a1 said: Even if the above demands 3 phase, is it worth getting solar 3 phase equipment? Or would it make more sense to seperate phases to garage, house and workshop? Haven't seen this answered, but, even if you do have different phases to different areas, so long as the whole lot are being supplied via a DNO cut out and single mater, you can still put a 3 phase inverter onto the main 3 phase supply and then divide the phases out to sub distro boards as needed. To a degree this is always going to be the case - there's no such thing as a 3 phase domestic "ring main" socket so some areas of the house will be on different phases. And you'll probably want all 3 phases in the garage anyway for the car lift or, whatever. If you're worried about balancing PV generation to demand across phases, don't. Modern meters to net billing so you're only charged for your net import (or paid for net export) across phases at any given moment in time. Couple more things to note: - you can't buy a 3 phase inverter now "just in case" and upgrade to 3 phase supply later. A 3 phase inverter needs 3 phases to output onto. - A single battery often has a power limit lower than it's capacity, e.g. a 16kWh sized battery may only be able to supply 5kW at any given moment. This also limits it's usefulness for high demand users - do you have DNO approval for 14kW PV ? They may look more kindly to this if on 3 phase. - have you asked for an indicative price for 3 phase? This maybe prohibitive and will answer your question - "The 16kw was advised as part of a recent quote I had." - this is obviously just guess work with so much future expansion of use planned. tldr you can always more than you have, the optimum size depends a lot if you just plan to time shift your PV generation or use it for cheap overnight rate time shifting too. With my tariff (Eon Next) it's actually more financially rewarding to sell all PV generation rather than store it, and then fill the battery from grid each night. But that may change when the tariff is updated next year.....
Kelvin Posted May 30 Posted May 30 The 16kWh SigEnergy system he’s likely looking at is made up of 2 x 8kWh batteries. A single battery outputs at half its capacity but it doubles up with each battery so in this case it will be 8kW. Their inverter system (which they call the Energy Controller) is very flexible and for 3 phase can go up to 30kW but this is all DNO dependent. In my case I’m going with the single phase 8kW unit. Unlike the Tesla PW3 you have to buy the specific Energy Controller to match the system rather than set it in software. Therefore if the DNO upgraded the infrastructure later you’d need to buy an upgraded EC to take advantage of it. The SigenEnergy system is very flexible, modular and compact. They also have a 12.5kW and 25kW DC bi-directional charger that supports V2L/H/G. It’s not cheap at around £4000 (for the 25kW unit) and they are waiting on the regulator approving it for home use. The downside is they only formed in 2022 so are a relatively new company so there’s an element of risk there.
scottishjohn Posted June 1 Posted June 1 having just been through a solar installation i can answer this fairly well I am too old to be going of roofs now so nooption but a professional job I already have 3 phase cos the difference inprice for my supply was only £1000 to do it as for how professional the salemen are that whole other story Iwas very happy with the actual engineers who did the job and they stood up well to mt grilling into all the technicalbits of the system and the dno /export systems as for what you put back to the grid you can send back 3.8kw per phase without any problem --they have to let you do that amount --no argument above that it needs agreement and adifferent permit from the DNO that will take time so you need that all sorted out and warrantied that it will happen before you push the button on a bigger set-up and give them some money - If they will not do that --change your supplier --they are cowboys the DNO judges what you send back by the size of the invertor as its maximum is the max that can be sent back continuosly the other thing is if you go for a 13kw=invertor it is classed as commercial -so your installation will have vat added pleas check this before making decision I was going for that when the 2nd supplier worked out he could get30 panels on the roof as ithought that it would pay back well inthe "shoulder months" they all seem to use "open solar" software which takes a view of house from goggle earth --but it is not scaled exactly --so thats what happened to me --when they came to do it they had the rails onbefore they saw that they could not get the 30 panels on !! an opening for a discount !! or get all your junk offf my roof and put everything back as it was to start with the resulting deal was another battery for free which took me up to the 17kw an old saying in scotland --"when you see a stick --cut it" I went for 26panels which gave me 11.7kw and the invertor is a 3 pahse smart 11kw and 17kw of giv batteries panels are the cheap bits and if doing it yourself you will not be allowed to send back more than 4kw total - unless you get it certified by an approved mcs installer you need an mcs cert -which you then take to your supplier to get an export M-Pan number you need to check carefully that the batteries you are getting will comply to get a bigger KW export cert . ocotpus only like giv batteries --but there are some they willalow onthier tariff --check which if you going octopus Iwould suggest you talk to ther suppliers before signing up I found they ALL lie to certain extent on things and do not be afraid to tell the others you look at what sig have siad then you will find like me all the holes in the quotes for example when asked they said bird gaurds are std fitment --not so they wanted to charge extra -- a dull chance that happening with me had to get them to alter the contract to include them remeber when you sign you are comitted just make sure your quote has all these things clearly marked I had one supplier who told me exactly what panels and invertor were going to be and when the quote came --the make was"to be advised" and another salesman told m the reason why they always specify a smaller invertor than the ouput of the panels is that the invertor takes 1.5kw to run it I rung up GIV energy and spoke to the tech man who pointed me too the spec sheet-- it takes 15w to run not 1500w so do not believe half of what they tell you do your homework also warrnaties for panels,invertor and batteries check with the maker -- for example --giv invertor has 12 years -but if you do not get and mcs cert and one of thier apporved fitters its 5 years lots of bobby traps -solar panels sales are like car sales used to be in the sixities .LOL- some do not include scaffolding in the quote and add it on
scottishjohn Posted June 1 Posted June 1 On 30/05/2025 at 14:31, joth said: you can't buy a 3 phase inverter now "just in case" and upgrade to 3 phase supply later. A 3 phase inverter needs 3 phases to output onto. unless i have been lied to --again you always have 2 "strings" of panels each string ir wired in series then the 2 strings are in parrallel you cannot have more than 2 strings on one invertor so I am told its when it comes out the other end of the 3phase inverytor it splits up the load -not on the input
scottishjohn Posted June 1 Posted June 1 On 30/05/2025 at 09:27, d438a1 said: With my future demands (whereby there could be a mix of house, airbnb garage and workshop running at same time), should I be considering 3 phase? Even if the above demands 3 phase, is it worth getting solar 3 phase equipment? Or would it make more sense to seperate phases to garage, house and workshop? I'll also note that utilising 3 phase for the car charger and workshop for bigger equipment is a real nice to have its what I have done 1phase for house 2nd phase for garage 3rd phase for expansion if iever build the holidays lets
SteamyTea Posted June 1 Posted June 1 TL:DR You ideally needs to split your PV across the phases you use during the daylight hours. Net Metering may be possible with your energy company, but check first, and check if you can get a Net Meter fitted. And, kW is power, kWh is energy.
d438a1 Posted June 3 Author Posted June 3 Thanks for all the further replies. The company installing the solar submitted the G99 last week to DNO, so will find out in due course. I did also ask for formal quote on 3 phase, so that should also be due back in next week or 2. Sorry if I'm being slow, but I still didn't quite work out if having 3 phase inverter is worth it
Roger440 Posted June 3 Posted June 3 53 minutes ago, d438a1 said: Thanks for all the further replies. The company installing the solar submitted the G99 last week to DNO, so will find out in due course. I did also ask for formal quote on 3 phase, so that should also be due back in next week or 2. Sorry if I'm being slow, but I still didn't quite work out if having 3 phase inverter is worth it As scottishjohn said, be sure to make sure your 3 phase quote is for a resedential connection, not non-residential. Turns out my quote was non-residential. Fortunately, owing to the bonkers price attached id not persued it yet.
Roger440 Posted June 3 Posted June 3 On 30/05/2025 at 11:13, nod said: The energy suppliers are mad keen on selling three phase Weather you need it or not Energy suppliers might be, but the DNO isnt!!!
joth Posted June 3 Posted June 3 2 hours ago, d438a1 said: Sorry if I'm being slow, but I still didn't quite work out if having 3 phase inverter is worth it If you have a 3 phase supply anyway, and the price is not prohibitively higher, then yes it is. Splitting your generation over phases means less voltage lift per phase, so less risk of the inverter shutting off if the local supply voltage runs high. 1 hour ago, Roger440 said: Energy suppliers might be, but the DNO isnt!!! I believe this depends a lot on DNO and location. I heard a while back Western power were starting to insist on doing 3 phase install (even if only 1 phase brought out of the head) wherever they have capability for it.
scottishjohn Posted June 4 Posted June 4 On 01/06/2025 at 18:36, SteamyTea said: TL:DR You ideally needs to split your PV across the phases you use during the daylight hours. Net Metering may be possible with your energy company, but check first, and check if you can get a Net Meter fitted. And, kW is power, kWh is energy. no need with modern meters --Ihad that very conversation with the dno men when they camto fit it makes nodifference as its AC current so it just takes the toal kw used
scottishjohn Posted June 4 Posted June 4 21 hours ago, joth said: Sorry if I'm being slow, but I still didn't quite work out if having 3 phase inverter is worth it If you want to keep to the simple dno rules --and going to make lup to 4kw per phase above that you need diffrent approval -not usually with held --but more paperwork and time it is possible to go up to 16kw per phase --but thats the limit -fullstop that could depend on size of your incoming cable? and as isaid before it will judged not on number of panels but size of invertor --as its size is the limit is can pass back to the grid
scottishjohn Posted June 4 Posted June 4 (edited) On 30/05/2025 at 12:28, JohnMo said: Have you checked the PV output in the winter, so you get to disappointed mid winter doing 140W instead of 14kW. that is why having more panels will hlep for the winter -as will more battery panels are cheap the thing you have to watch with some panels and invertors is the minimum voltage they need to make to turn on the invertor another question to ask them which is why they usually spec the invertor at around 80%of panel capacity and accept that on thesuper summer days you might not get all of your panel capacity -dependoing on make of invertor Edited June 4 by scottishjohn
joth Posted June 5 Posted June 5 15 hours ago, scottishjohn said: no need with modern meters --Ihad that very conversation with the dno men when they camto fit it makes nodifference as its AC current so it just takes the toal kw used Yeah, I've given up harping on about this but if you search this forum for "polyphase" you'll see I've been trying to raise awareness of this for a number of years.. 😂
d438a1 Posted June 10 Author Posted June 10 (edited) So had a quote back which was pretty reasonable at £1500 inc vat, but with me doing excavation and ducting. I've attached the plan they sent me. Currently my supply is overhead from the pole and they are mandating it needs to be underground following yellow line. However it's quite a tricky run with lots of concrete. However, I'm now thinking maybe of using the wooden pole near the garage and house the meter, etc in garage or behind garage. I've already got a trench open (in pink line) to then feed back to house. There is also the existing 25m2 armoured cable between house and garage. What are thoughts on reconfiguring and housing in garage? Thanks Edited June 10 by d438a1
scottishjohn Posted June 10 Posted June 10 (edited) 9 hours ago, d438a1 said: There is also the existing 25m2 armoured cable between house and garage. Edited June 10 by scottishjohn deleting
