Andrew Jones Posted Tuesday at 15:49 Posted Tuesday at 15:49 I am looking at a plot in the north of Scotland, can you explain to me how the planning & building control works in Scotland as it appears to be different from the rest of the UK
Crofter Posted Tuesday at 15:56 Posted Tuesday at 15:56 Well firstly, you may already be aware that planning and building control are separate. Sorry if this is all stuff you already know. The planners want to know what the building will look like and what it will be used for. It's all about the impact on the surroundings. So appearance, number of bedrooms, etc. Building control want to know the technical details of how it's actually constructed, to make sure that it won't fall down or fail to meet standards on things like disabled access and energy efficiency. The idea is to ensure that the supply of housing is off suitable standard, seeing as most houses will outlive the people who build them.
JohnMo Posted Tuesday at 16:20 Posted Tuesday at 16:20 Planning permission is pretty similar to the rest of the UK, maybe a few different details, but essentially the same. You then need a Warrant to allow you start building. You need full construction details, a structural engineering certificate, and an EPC based on your drawings. So pretty similar to building regs drawings. But you cannot build until approved.
ProDave Posted Tuesday at 16:31 Posted Tuesday at 16:31 Building warrant in Scotland is similar to full plans approval in England. There is no simpler option here. No building notice option. You submit your design to building control and can't start building until all details are approved. At least you then know if you build to the plans there will be no nasty surprises.
JohnMo Posted Tuesday at 16:56 Posted Tuesday at 16:56 My headspace likes the Scottish system, it's a bunch of black and white steps. Do yourself a big favour read Scottish building regs. Once you have the warrant, building control generally visit 3x, at foundation concrete pour, prior to plasterboard and at completion.
saveasteading Posted Tuesday at 16:58 Posted Tuesday at 16:58 As a professional designer and contractor I preferred the English way of being able to start quickly and sort details out as it proceeded. BUT I think the Scottish requirement for full details is the better idea in regards to quality and certainty. It also allows time to debate or resolve any issue with the BCO, and thus no delays or arguments once it is all running. The main difference in conversions is that the Scottish regulations allow pragmatism. 'As far as reasonably practicable' is stated a lot. For example we proposed leaving some attractive masonry exposed internally, whereas strict interpretation required it being insulated and boarded over. The bco was in full agreement and it was a verbal agreement. You appear to be doing new-build. The same apples to, I think, a lesser extent.
nod Posted Tuesday at 17:00 Posted Tuesday at 17:00 A rule of thumb is Where ever you are Building Control have no interest in planning maters They are just there to make sure that you or your builder complies with building regulations Planners on the other hand are there to make life difficult for you 1
JohnMo Posted Tuesday at 17:32 Posted Tuesday at 17:32 32 minutes ago, nod said: A rule of thumb is Where ever you are Building Control have no interest in planning maters They are just there to make sure that you or your builder complies with building regulations Planners on the other hand are there to make life difficult for you Yep 1
andyscotland Posted Wednesday at 06:23 Posted Wednesday at 06:23 The other difference (that is implied but not explicit in the earlier posts) is that Building Control is done entirely by the local authority covering your area. The English/Welsh option to use a private BCO does not exist.
