BotusBuild Posted Wednesday at 17:14 Posted Wednesday at 17:14 Following this link https://www.juliancassell.com/2564/fitting-a-door-lining provided by @MortarThePoint in another post I have fitted my first door lining (of 14). Rather pleased with the result. Hopefully the remainder will be as successful 5
Pocster Posted Wednesday at 19:17 Posted Wednesday at 19:17 (edited) You need my door liner clamps . Perfect for this ! Got 4 of these …. For sale ! Edited Wednesday at 19:19 by Pocster
Thorfun Posted Wednesday at 20:12 Posted Wednesday at 20:12 2 hours ago, BotusBuild said: Following this link https://www.juliancassell.com/2564/fitting-a-door-lining provided by @MortarThePoint in another post I have fitted my first door lining (of 14). Rather pleased with the result. Hopefully the remainder will be as successful Were the linings a kit or did you make the linings yourself? I have some stupidly thick walls I will need to make my own linings for using 25mm MDF.
Russell griffiths Posted Wednesday at 20:19 Posted Wednesday at 20:19 4 minutes ago, Thorfun said: Were the linings a kit or did you make the linings yourself? I have some stupidly thick walls I will need to make my own linings for using 25mm MDF. You can get them cut to the width you want and edge banded to save loads of time on painting. or look at Todd doors I’ve used their ones different widths for thick walls, can’t remember the sizes but I have 125studs with 11mm osb both sides and 15mm plasterboard. 1
Nickfromwales Posted Wednesday at 21:03 Posted Wednesday at 21:03 1 hour ago, Thorfun said: Were the linings a kit or did you make the linings yourself? I have some stupidly thick walls I will need to make my own linings for using 25mm MDF. If you need to borrow a pukka Milwanky router / hinge jig kit for when you go to do the doors and linings just PM me, and all you'll need to cover is just the P&P both ways if so. Router / batteries etc all in the kit too, so plug 'n play
Thorfun Posted yesterday at 07:07 Posted yesterday at 07:07 10 hours ago, Nickfromwales said: If you need to borrow a pukka Milwanky router / hinge jig kit for when you go to do the doors and linings just PM me, and all you'll need to cover is just the P&P both ways if so. Router / batteries etc all in the kit too, so plug 'n play I’m a sucker for new stuff so I already have hinge jig and door stand etc. my router will also do the hinges but I think it doesn’t plunge enough to do the latch but I’ll cross that bridge when I get to it! very kind of you to offer though. I’m sure I’ll be posting nearer the time for more advice on it all though. 1
Pocster Posted yesterday at 07:23 Posted yesterday at 07:23 15 minutes ago, Thorfun said: I’m a sucker for new stuff so I already have hinge jig and door stand etc. my router will also do the hinges but I think it doesn’t plunge enough to do the latch but I’ll cross that bridge when I get to it! very kind of you to offer though. I’m sure I’ll be posting nearer the time for more advice on it all though. You need my clamps aswell ! . They are for door linings - makes it much easier to get them level in all axis . 1
Super_Paulie Posted yesterday at 08:37 Posted yesterday at 08:37 1 hour ago, Pocster said: You need my clamps aswell ! . They are for door linings - makes it much easier to get them level in all axis . how do these work then? ive got 5 doors i need to switch out this summer after the building settled on the beams and threw the linings out.
Pocster Posted yesterday at 08:49 Posted yesterday at 08:49 9 minutes ago, Super_Paulie said: how do these work then? ive got 5 doors i need to switch out this summer after the building settled on the beams and threw the linings out. I think no one gets these . I did 6 door linings with them . 1 at top on each side and one at bottom . Go between the lining and the wall . Allows you to move the lining in all directions to get it perfect . Then I foam around the lining - making sure to protect the clamps so I can remove them . They take a bit of getting use to but make it far simpler and allow you to get it level in all directions so all your doors close nice 😊
Thorfun Posted yesterday at 10:23 Posted yesterday at 10:23 1 hour ago, Pocster said: I think no one gets these . I did 6 door linings with them . 1 at top on each side and one at bottom . Go between the lining and the wall . Allows you to move the lining in all directions to get it perfect . Then I foam around the lining - making sure to protect the clamps so I can remove them . They take a bit of getting use to but make it far simpler and allow you to get it level in all directions so all your doors close nice 😊 can you not do the same thing with packers though? 1
Pocster Posted yesterday at 10:25 Posted yesterday at 10:25 Just now, Thorfun said: can you not do the same thing with packers though? Of course . These are much easier . Effectively acting like packers but you can adjust as you level the frame . Much easier with these . 1
Pocster Posted yesterday at 10:32 Posted yesterday at 10:32 So someone needs to buy them ! Not expensive !!
BotusBuild Posted yesterday at 15:00 Author Posted yesterday at 15:00 18 hours ago, Thorfun said: Were the linings a kit or did you make the linings yourself? They are a kit, but needed some fettling. 1
BotusBuild Posted yesterday at 15:04 Author Posted yesterday at 15:04 4 hours ago, Thorfun said: can you not do the same thing with packers though? Yes, and it's fiddly. Ask me how I know 😁 1
BotusBuild Posted yesterday at 15:08 Author Posted yesterday at 15:08 4 hours ago, Pocster said: So someone needs to buy them ! Not expensive !! Biting. Will you take £20? 1
Pocster Posted yesterday at 15:15 Posted yesterday at 15:15 5 minutes ago, BotusBuild said: Biting. Will you take £20? 20 each with free postage ? you will need all 4
BotusBuild Posted yesterday at 15:18 Author Posted yesterday at 15:18 😂 Not when I can get them for a tenner and free postage off fleabay. Nice try. £20 for all 4 is the offer
Pocster Posted 23 hours ago Posted 23 hours ago 8 minutes ago, BotusBuild said: 😂 Not when I can get them for a tenner and free postage off fleabay. Nice try. £20 for all 4 is the offer Only ones on eBay I can see are mine at £13 each … Show me your bargain for a tenner on eBay ? 1
Pocster Posted 22 hours ago Posted 22 hours ago 10 minutes ago, BotusBuild said: I'll carry on with wedges Yeah awesome . A link to mine ! - and yes if you buy all 4 they are about a tenner each !
