You need my door liner clamps . Perfect for this !
Got 4 of these …. For sale !
Edited by Pocster
2 hours ago, BotusBuild said:
Following this link https://www.juliancassell.com/2564/fitting-a-door-lining provided by @MortarThePoint in another post I have fitted my first door lining (of 14). Rather pleased with the result.
Hopefully the remainder will be as successful
Were the linings a kit or did you make the linings yourself?
I have some stupidly thick walls I will need to make my own linings for using 25mm MDF.
You can get them cut to the width you want and edge banded to save loads of time on painting.
or look at Todd doors I’ve used their ones different widths for thick walls, can’t remember the sizes but I have 125studs with 11mm osb both sides and 15mm plasterboard.
If you need to borrow a pukka Milwanky router / hinge jig kit for when you go to do the doors and linings just PM me, and all you'll need to cover is just the P&P both ways if so. Router / batteries etc all in the kit too, so plug 'n play ;)
I’m a sucker for new stuff so I already have hinge jig and door stand etc. my router will also do the hinges but I think it doesn’t plunge enough to do the latch but I’ll cross that bridge when I get to it!
very kind of you to offer though. I’m sure I’ll be posting nearer the time for more advice on it all though.
You need my clamps aswell ! . They are for door linings - makes it much easier to get them level in all axis .
how do these work then? ive got 5 doors i need to switch out this summer after the building settled on the beams and threw the linings out.
I think no one gets these .
I did 6 door linings with them .
1 at top on each side and one at bottom . Go between the lining and the wall . Allows you to move the lining in all directions to get it perfect . Then I foam around the lining - making sure to protect the clamps so I can remove them .
They take a bit of getting use to but make it far simpler and allow you to get it level in all directions so all your doors close nice 😊
can you not do the same thing with packers though?
Of course . These are much easier . Effectively acting like packers but you can adjust as you level the frame . Much easier with these .
They are a kit, but needed some fettling.
Yes, and it's fiddly. Ask me how I know 😁
5 minutes ago, BotusBuild said:
Biting. Will you take £20?
20 each with free postage ?
you will need all 4
Not when I can get them for a tenner and free postage off fleabay.
Nice try.
£20 for all 4 is the offer
Nice try.
Only ones on eBay I can see are mine at £13 each … Show me your bargain for a tenner on eBay ?
10 minutes ago, BotusBuild said:
I'll carry on with wedges
Yeah awesome . A link to mine ! - and yes if you buy all 4 they are about a tenner each !
  • 1 month later...
A quick follow up and another door lining question.
All the door linings I bought were kits and the headrail had grooves cut in it for the legs/jambs to fit into, which I ended up having to reposition because of the opening widths.
Could I just buy planed timber and make up linings? Yes, probably.
Do I need the grooves in the headrail?
Just buy solid timber no need to trench the heads, glue and screw before fitting, get in the habit of pre knotting the timber and giving it a coat of primer before fitting, far better than your painter doing only the front face afterwards.
Will do for the last 10 🙂
have a look at the souber morticing jig. awesome for latches and mortices for bathrooms etc.
https://www.ironmongerydirect.co.uk/product/souber-dbb-latch-and-lock-morticer-jig-247397?vat=1&gad_source=1&gad_campaignid=22180738972&gbraid=0AAAAAD-uRIQje6OxgetEy6Z0ydNuIsa50&gclid=CjwKCAjw1dLDBhBoEiwAQNRiQWtOV_tGpyOKeZWa4gobYSOvg-wZOLnMWdsIUpfy1oxzcyZrxEs3WxoCo9YQAvD_BwE
I bought the offset addon for it to dot he secret hinges.
green mdf track sawed down makes much better and wider stops than the crappy 25mm paint sticks that come with liners.
Edited by Dave Jones
