Hey folks, me again! Our swimming pool foundation dig is going well so far.
I was wondering if anyone can recommend any rebar suppliers that can do H10 (10mm) links/stirrups with a dimension of 90mm, ie shape code 51 where B=90mm
Our engineers have specified 90mm max for our lintels and piers as they want a 30mm coverage each side within our 150mm ICF concrete due to fire regulations.
The suppliers I’ve checked with say they can only do down to 100mm, some even only going down to 110mm. I did get a quote from someone that said they could do it, at 20% more expensive and of dubious repute? I say dubious but really it’s just that I haven’t seen them mentioned before, and hoping someone here might have personal recommendations instead.
I’ve asked our engineers to come up with alternatives but I’m not very optimistic about them coming up with a timely solution…
I’d rather get the bars supplied bent, but failing that how hard is it to bend my own bars for a pencil neck with absolutely no experience? 😅
Thanks!
Bending is easy enough with a bar bender but by the time you’ve hired one and bought the bar you’re probably better paying the 20% premium on the few you want….
I’m not sure you’d get a bar bender to manage bends in that short succession though.
45 minutes ago, JohnMo said:
I got mine from eBay.
Maybe I’m being a bit uppity about it, but how do you know if the rebar meets the standards?
I’m assuming that’s why most suppliers can’t go down to 90mm either.
Good question. And there is a lot to talk about here…
I’ll keep it quick though.
Ask for the suppliers CARES certificate. If it covers the relevant classes you’re looking for you’re good. I’m over generalising but for domestic work I wouldn’t dig much further than that. It’s a rabbit hole.
On the bending sizes and radii, factory bent will give you the most options. On site you don’t really want to be making up complex bar bends!
Total construction supplies in the west mids did mine, they didn’t like it as it was small and hard to bend, but did them as I had had £5000 worth of steel for my foundations, and they featured my foundations on their website.
give them a call.
could you drop to 8mm links, check with structural engineer, easier to bend to get the tight radius.
give them a call.
Thanks Russell! Yes we can drop to H8 as well, though with the ones I’ve checked with was still 100 or 110.
Yeah. We don’t have crazy amount and it’s pretty much straight bars or square links but I’d still rather avoid bending them on site if I can
I had similar issue, ended up buying a rebar bender and making my own.
It worked out quite a bit cheaper than buying ready made links even allowing for the bender
Got it from eBay, it’ll do up to 14mm bar
ill sell it if your interested but I’m a few miles from Cambridgeshire as I’m near Norwich
Shape code 51 is this
Table 2 says this
And there lies your problem.
I suspect your SE has made a bollocks of this link / beam design. 10mm links with only B = 90 mm? even if in terms of buildability and cost.
Let’s just say I won’t be recommending them for many other reasons as well.
We’re thinking of trying it out with a bending jig as a trial and see how feasible it is
Thanks. If you’re happy to sell it I’ll let you know on Tuesday if we decide to try it ourselves.
I made 200 links didn’t take too long once you get the hang of it.
I have some bits  of rebar kicking about you can try
IMG_2271.thumb.jpeg.5aa9ce2aa02cb962141a1b75ee7d1d71.jpegIMG_2255.thumb.jpeg.8ada5dac9834ac57fe04109e7b3fe6ba.jpeg
Happy days, I’ve managed to find a supplier to do the links in 90mm without any extra costs.
Thanks all for the help. I won’t be needing the jig after all.
Good, just make sure that you can vibrate the concrete ok and get the pour sequencing right.
Go back and just check the design with you SE, in case there is an annotation error.. it happens.
Thanks. Yes, we’ve checked the dimensions with them and according to our SE that’s the “standard detail” approved by the ICF manufacturer who’ll come on site to help with the first lift as well.
