saveasteading Posted August 28 Posted August 28 3 hours ago, BotusBuild said: the foundation slab, That's different. I'm sitting now in what will be oug garage and it has a very agricultural floor. I don't see why we need to improve it for garden stuff, a mower and maybe even a car to sit on. If I too engines apart that would be different. My man cave in the corner will get some marmox on it, then levelled with latex and then... I think a floor of many colours, using leftover tiles*. 6" pir in the walls and ceiling of the boxout. Electric, probably infrared, heating. * there's a thing... I have boxes and stacks of spare tiles sitting in the shed "just in case". You can be sure that heavy iron pots have been dropped in the kitchen, and that floors have moved. No tile has broken , ever. They might if there was grotty workmanship on the dot and dab principle, but the adhesive contact is total and loads go straight to the screed. Tile if you want, using those free tiles that will take up space until you move.
Nickfromwales Posted August 28 Posted August 28 45 minutes ago, BotusBuild said: UFH loops in the slab already with 100mm PIR underneath 😀 Mini bar? 1
Andeh Posted August 28 Posted August 28 With UFH you need to assume constant heat to make the most of it, otherwise a cold slab just takes too long for weekend working. We put in two over sizes radiators, on their own zone off the ASHP. With insulation all round (except the slab), and within an hour it's toasty warm for that sudden bout of working or playing on there!
Nickfromwales Posted August 28 Posted August 28 2 minutes ago, Andeh said: With UFH you need to assume constant heat to make the most of it, otherwise a cold slab just takes too long for weekend working. We put in two over sizes radiators, on their own zone off the ASHP. With insulation all round (except the slab), and within an hour it's toasty warm for that sudden bout of working or playing on there! Timer to come on as setback; can deliver the temps you want, when you want them, and switch off midday Sunday to allow the space to be heated residually until cold.
BotusBuild Posted August 28 Author Posted August 28 (edited) What is this talk of only using at weekends? Blasphemy! Probably just have a Willis heater and timer setup on a 12C setback temp, with a 15C working temp. Did I mention the proposed 4 post lift 🙂 Edited August 28 by BotusBuild 1
Roger440 Posted August 28 Posted August 28 43 minutes ago, BotusBuild said: What is this talk of only using at weekends? Blasphemy! Probably just have a Willis heater and timer setup on a 12C setback temp, with a 15C working temp. Did I mention the proposed 4 post lift 🙂 Just a 4 poster? You need a 2 and a 4........................... However, warm it isnt. Still to many options and decisions. And not enough money 1
Dan F Posted Saturday at 03:37 Posted Saturday at 03:37 (edited) Depends what you'll use garage for, but if the floor is reasonably flat swisstrax is an option worth considering. It worked out cheaper and easier than epoxy for us (in part because we didn't need to grind/prep the slab), and it looks fantastic too. There are a couple of caveats you have to weigh up with it though. - Doesn't need much cleaning because of how it's designed, but dust does accumulate underneath it. - You don't want to drop anything very small on the floor! Also water goes through it (which may or may not be a good thing) - Not that confortable walking in socks (there is another models which this isn't an issue with though, although it accumulate more dust due to flat surfaces). On the flip-side, you can pull it up to clean underneath it you want,change the design or replace damaged tiles, things don't bounce off it etc. Edited Saturday at 03:54 by Dan F 3
BotusBuild Posted Saturday at 08:58 Author Posted Saturday at 08:58 15 hours ago, Roger440 said: Just a 4 poster? You need a 2 and a 4........................... However, warm it isnt. Still to many options and decisions. And not enough money Love the exhaust and radiator setup on the orange triumph 😀 1
-rick- Posted Saturday at 09:30 Posted Saturday at 09:30 15 hours ago, Roger440 said: However, warm it isnt. Still to many options and decisions. And not enough money Well that's a much more substantial workshop than I was expecting from your previous posts. Barn vs 2/3 car garage. To cost effectively make that space warm? Build a room within the room for the work area and heat/cool that, don't heat/cool the storage. Even a large tent that you can move about if needed to contain the air of the area you are working would help.
Nickfromwales Posted Saturday at 10:04 Posted Saturday at 10:04 1 hour ago, BotusBuild said: Love the exhaust and radiator setup on the orange triumph 😀 A temporary solution whilst we were suffering from this heatwave 😂
saveasteading Posted Saturday at 13:15 Posted Saturday at 13:15 3 hours ago, -rick- said: much more substantial workshop I wouldn't recommend space heating except for any enclosed workshop. Infra red heating pointing at work- forces, or even on a trolley for very local benefit. It's standard in the vehicle industry buildings I've done and I think pretty well everywhere... to the extent of doors being left open. Eg in big shed retailers and esp garden centre checkouts you may see heating directed at the person. In garages it may point down on the bonnet or under the raised vehicle. Presumably you'd use electricity but there are gas methods too.
Roger440 Posted Sunday at 08:15 Posted Sunday at 08:15 22 hours ago, -rick- said: Well that's a much more substantial workshop than I was expecting from your previous posts. Barn vs 2/3 car garage. To cost effectively make that space warm? Build a room within the room for the work area and heat/cool that, don't heat/cool the storage. Even a large tent that you can move about if needed to contain the air of the area you are working would help. Ive partly done/doing that. At the back (centre of pic) are the double doors into my "clean room". That fully insulated (apart from floor) The area under the mezz will recieve the same treatment with an insulated door on the front opening. That will be the "dirty room" for weding, fabrication, painting etc. But the main part of the workshop with the ramps, which is where i spend a good chunk of time doesnt lend itself to further subdivision, especially with the entrance door where it is. Ulitmately i need to sort out the roof as its just single skin fibre cement. So any heating just disappears. The walls are cavity block. The only sensible answer is either spray foam (expensive), but 27 of the roof sheets are cracked (mostly due to overtightening on install (!!!) so that needs fixing first. Or put another insulated steel roof on the inside. (more expensive) Replacing the whole roof is beyond expensive!
Roger440 Posted Sunday at 08:21 Posted Sunday at 08:21 (edited) 19 hours ago, saveasteading said: I wouldn't recommend space heating except for any enclosed workshop. Infra red heating pointing at work- forces, or even on a trolley for very local benefit. It's standard in the vehicle industry buildings I've done and I think pretty well everywhere... to the extent of doors being left open. Eg in big shed retailers and esp garden centre checkouts you may see heating directed at the person. In garages it may point down on the bonnet or under the raised vehicle. Presumably you'd use electricity but there are gas methods too. All correct. And whilst good in a commercial environment and enough to satisfy the law, its not really what im looking for. This is purely a hobby. If im cold, i wont enjoy it, so becomes pointless. Ive spent enough of my working life in cold workshop environments, even with various forms of heating to know i need better. My long term target is to maintain it through winter at 12c. 12c is ok if you are working. 2c or less, not so much. But until i sort the roof out, everything else is pointless. Edited Sunday at 08:22 by Roger440
Susie Posted yesterday at 09:12 Posted yesterday at 09:12 2 post and 4 post with room to move other cars. The floor is power floated concrete been down 10yrs industrial use and very few dents, the floor brushes up very easily. 1
BotusBuild Posted yesterday at 09:43 Author Posted yesterday at 09:43 @Susie, I've been in that garage 🙂 I should have paid more attention to the floor, and not the cars 🙂 1
saveasteading Posted yesterday at 09:58 Posted yesterday at 09:58 On 30/08/2026 at 09:15, Roger440 said: Or put another insulated steel roof on the inside. (more expensive) Replacing the whole roof is beyond expensive! I've done many an over-clad. The cement roof stays on, fix omega shape brackets over, then rails. Then you overclad with or without insulation. The downside is that the old cladding is still there, affecting value. Is it asbestos or innocuous fibre cement? The risk of asbestos(2% of the toatal) is overstated unless the material is crushed and sniffed. Against under-cladding is that the roof may leak onto it.
Roger440 Posted yesterday at 19:09 Posted yesterday at 19:09 9 hours ago, saveasteading said: I've done many an over-clad. The cement roof stays on, fix omega shape brackets over, then rails. Then you overclad with or without insulation. The downside is that the old cladding is still there, affecting value. Is it asbestos or innocuous fibre cement? The risk of asbestos(2% of the toatal) is overstated unless the material is crushed and sniffed. Against under-cladding is that the roof may leak onto it. Looked at that too. Im not a fan, as keeping said insulation dry in this environment will be rather difficult. Wind driven rain can be rather bad. More expensive than spray foam, a bit more expensive than my under cladding wheeze (mainly because i can the do latter, but not the former) but cheaper than a new composite steel roof. The thing that skews it, is the overall roof is 4000sqft the workshop circa 2400, the balance being either the canopy (big) or the rear of the already insulated office bit. If i do inside, ive only 2400sq ft to do, and whilst i "could" do only part of the outside, it would look terrible and its not exactly hidden from the house! But everything is an option. Spray foam still looks like the winner. If i stop the leaks. Its not asbestos as built in 2001.
saveasteading Posted 12 hours ago Posted 12 hours ago 11 hours ago, Roger440 said: Spray foam still looks like the winner. If i stop the leaks. I have an aversion to spray foam. It has ruined many a house. The people who do it used to be opportunists without knowledge of thd harm it can cause.. maybe that has changed. Think of it as a temporary fix at best. A Proper Job will cost more than you are wishing for. But in perspective, Stripping the roof will only take 2 days, recladding in 40mm composite about 4 days.
Roger440 Posted 11 hours ago Posted 11 hours ago (edited) 38 minutes ago, saveasteading said: I have an aversion to spray foam. It has ruined many a house. The people who do it used to be opportunists without knowledge of thd harm it can cause.. maybe that has changed. Think of it as a temporary fix at best. A Proper Job will cost more than you are wishing for. But in perspective, Stripping the roof will only take 2 days, recladding in 40mm composite about 4 days. Fotunately there no timber in the roof its all steel. So not going to get ruined. Though it doesnt look that great, but nothing a coat of matt black wouldnt sort out. No one want to do the roof with new panels except for a chap i know. He is expensive, big company, lots of overheads etc, so i get it. But £50k isnt happening. Problem is, a) i cant do it myself, and b) going to need a crane as the panels will be 6.2m long. Cant rerally use a telehandler as there is a 10 to 12ft wide hardcore strip down each side, but no space to actually turn. If i was to do it, id probably be looking at 100mm rather than 40. Only going to do it once! Pic for reference Edited 11 hours ago by Roger440
Roger440 Posted 11 hours ago Posted 11 hours ago 22 hours ago, Susie said: 2 post and 4 post with room to move other cars. The floor is power floated concrete been down 10yrs industrial use and very few dents, the floor brushes up very easily. Now thats nice. Both the building and the contents......................
saveasteading Posted 11 hours ago Posted 11 hours ago Or single sheet and you can insulate underneath when funds allow. Lighter panels by a long way.
SteamyTea Posted 7 hours ago Posted 7 hours ago On 02/09/2026 at 10:12, Susie said: brushes up very easily. And the panel fit is better than the cars. (Sorry, could not resist)
