Looking at specifying some of our floor posijoists to be 400mm to minimise deflection. However we need to use eger protect or caberdeck as floor will be exposed until watertight.
Most flooring sheets are 2400x600mm. However does this work for 400mm spaced floor joists?
It is likely that there is a lot else you don't know. Keep asking.
What is the project?
Thanks @saveasteading I have been asking for past 6 months on here. It’s our second self build so learned a lot on the first one. Like bouncy floors because they werent designed to minimise deflection. Not best airtightness etc which in trying to remediate. Got the builder doing a Tony tray for example around the joists. Posi rafter roof with blown cellulose instead of attic trusses with PIR. Architect designed  cold ventilated flat roof for a portion of the build. This forum had me switch out for a warm roof.. Learning a huge amount on here.
There is definitely a lot that I don’t know!
Edited by SBMS
6 hours ago, SBMS said:
Thanks both. Thought that’d be the case but wanted to check
P4 Glue and screw then tape the joints with gaffa tape if it’s exposed
