Bancroft Posted November 24, 2024 Posted November 24, 2024 We're planning on a concrete slab foundation under an ICF build and I'm presently thinking about conduits required to run through the slab. And the list seems to be growing daily! I've got the basics like sewage out, and mains water and electricity in, but it's all the other stuff: Into the house - ASHP, aircon (split system so essentially another ASHP just providing cool v hot), solar/battery, broadband/fibre. Back out - electric gate power (and ethernet for video camera/security), lighting to garage, lighting to garden, water supply to external taps, power out to car charger. And so the list goes on. (Let me know if anything crucial missed). What's the best way to organise these without causing interference between different supplies or ending up with multiple conduits under the slab? Clearly water and electric should be kept separate but can electricity, fibre and ethernet go through one conduit? Is that a good idea? Could all electrical supplies go through one conduit or should they be split up? Ditto ASHP and aircon plumbing. Is it worth considering just a single electrical supply out and then putting another meter box in the garage to split all the external requirements from there? How have others approached this issue?
Russell griffiths Posted November 24, 2024 Posted November 24, 2024 Power out for sewage treatment plant if you have one. don’t mix power and internet. don’t worry about multiple ducts, if you need them that’s it, you need them. all power in and power out can come up below the consumer unit, I have about 6 ducts there, then 3-4 more in the plant room for water in and ASHP in and out. you will need power out to the ASHP plus maybe cat 6 to control it. Do a sketch of the house and some lines on it of every device inside and out and how each device will get either power or water to it or from it or both. I wouldn’t be surprised if you end up with 20 odd penetrations in the slab, don’t worry just get them in, and run a spare just in case. 2
Andeh Posted November 24, 2024 Posted November 24, 2024 Do not forget insulation size on the pipes!! We had a nightmare of a job pulling 4 x AC pipes through together with the insulation on. 110mm duct was stupidly ambitious, but narrowly managed to make it work. Also bends disproportionately add to the resistance pulling things through. 3
Nickfromwales Posted November 24, 2024 Posted November 24, 2024 5 hours ago, Bancroft said: What's the best way to organise these without causing interference between different supplies or ending up with multiple conduits under the slab? Don't be shy, the last M&E spec I delivered had about 17 different ducts for everything. Makes life soooo much easier at 1st fix etc, and for any alterations you may want to make downstream. 2
Bancroft Posted November 25, 2024 Author Posted November 25, 2024 20 hours ago, Russell griffiths said: Do a sketch of the house and some lines on it of every device inside and out and how each device will get either power or water to it or from it or both. I wouldn’t be surprised if you end up with 20 odd penetrations in the slab, don’t worry just get them in, and run a spare just in case. Yes, I'm expecting this as part of the architect's work but I just want to make sure I'm happy in my own mind before him and the builder start trying to bamboozle me! Good point ref power for the sewage - had missed that one. 1
Bancroft Posted November 25, 2024 Author Posted November 25, 2024 18 hours ago, Andehh said: Do not forget insulation size on the pipes!! Good point. I expect size of duct is a balance between being as small as possible to reduce space and any heat loss, but big enough to not make it impossible to thread stuff through.
Bancroft Posted November 25, 2024 Author Posted November 25, 2024 15 hours ago, Nickfromwales said: he last M&E spec I delivered had about 17 different ducts for everything Now got me thinking about what I might have missed! My list seems small in comparison.
Bancroft Posted November 25, 2024 Author Posted November 25, 2024 Some really helpful stuff here, gents, many thanks. Feel better equipped to hold my own with the professionals.
Russell griffiths Posted November 25, 2024 Posted November 25, 2024 List from my memory power in power out to garage power out to sewage plant power in from solar power out to car charger telecoms in cat 6 out to electric gates power out to electric gates cat 6 out for cameras power out front garden lights power out back garden lights ASHP flow out ashp flow return, could both be in single insulated duct power to ASHP cat 6 to ASHP so 13-14 ish without thinking too hard. plus all your poo pipes. lots could change in your situation, sewage plant might be near the garage so could take power from there, the car charger could be on the side of the garage as well.
Nickfromwales Posted November 25, 2024 Posted November 25, 2024 12 hours ago, Bancroft said: Yes, I'm expecting this as part of the architect's work but I just want to make sure I'm happy in my own mind before him and the builder start trying to bamboozle me! The only real issue with rising penetrations through a slab is if it’s a block and beam. In this situation you need to avoid a beam. Structural engineers will have some “say” if you have all ducts together and it requires steel reinforcements being re-jigged, but a little bit of pragmatic pre-planning and dialogue will resolve this in a day. Tell your builder that this will progress at your pace, and will arrive at the end result that you want, and he will have to slow down accordingly. 1
trialuser Posted November 26, 2024 Posted November 26, 2024 My advice is that you talk to your air con installer at an early stage. You will need to use an f-gas bod. There are restrictions on the max pipework length to each indoor unit. The insulated pipes (a pair to every indoor unit) are quite bulky, easily kinked, the insulation is easily torn (and then at risk of condensation forming) and should be a continuous length from external unit to the internal units. 1
Bancroft Posted November 26, 2024 Author Posted November 26, 2024 11 hours ago, Nickfromwales said: The only real issue with rising penetrations through a slab is if it’s a block and beam. We're planning on full concrete slab at the moment so hopefully not an issue. Not sure trying to hold the builder back will work. I get the impression that once he gets going he's full speed ahead - which is another reason why I'm doing a bit of homework now.
Nickfromwales Posted November 26, 2024 Posted November 26, 2024 3 hours ago, Bancroft said: We're planning on full concrete slab at the moment so hopefully not an issue. Not sure trying to hold the builder back will work. I get the impression that once he gets going he's full speed ahead - which is another reason why I'm doing a bit of homework now. Less haste = more speed, and then no expensive fixes 1
Gibdog Posted January 2, 2025 Posted January 2, 2025 Hi @Bancroft, I posted a similar (but much less through) Q just before Christmas and someone pointed me to this thread. Have you finalised the penetrations? Would you be up for sharing it? I'm at a similar stage and my list feels very small (9!). Many thanks, Gracie
Alan Ambrose Posted January 4, 2025 Posted January 4, 2025 >>> Is it worth considering just a single electrical supply out and then putting another meter box in the garage to split all the external requirements from there? As it’s usually much easier to do lines into a garage, yes reckon so, also for ethernet (with a separate POE hub there). In fact, I could see 2 or 3 consumer units - in another thread, someone suggested a separate CU for the kitchen rather than running everything back to the main CU. Seems helpful. 1
Bancroft Posted January 16, 2025 Author Posted January 16, 2025 On 25/11/2024 at 14:37, Russell griffiths said: cat 6 out to electric gates For some reason I read this as '6 cats out to electric gate'. Was about to call the RSPCA! 1
Bancroft Posted January 16, 2025 Author Posted January 16, 2025 On 02/01/2025 at 14:26, Gibdog said: Have you finalised the penetrations? Would you be up for sharing it? Hi Gracie, not completed yet; architect working on it still. But what I have so far is as shown here.
Gibdog Posted January 17, 2025 Posted January 17, 2025 Thank you - that's a lot bigger than my list! I'll check again. May I ask what the solar conduit is? Are your panels not on the roof..? And your broadband - is that with Virgin by any chance? Are you using the same duct as electrical cable..? Many thanks.
Nickfromwales Posted January 17, 2025 Posted January 17, 2025 @Gibdog The extra penetration for sewage and grey water vs one duct for both will depend on whether you have a sewerage treatment plant or not If you're on a network sewer then no need to segregate them. You shouldn't really have any 'sensitive' or low voltage services in with mains cables tbh, I'm sure it's been done under duress a thousand times though, but this is a new build / new design so best to do things right. GTC (I worked with them in Gravenhill in oxford) would point blank refuse you a connection if you asked them to pull the same 2 cables into the one duct, so beware of getting refusals to connect / adopt your chosen methodology with groundworks from 3rd party providers! BT will want you to use a specific (BT56) rigid duct which they usually supply you FOC. If you search on here there are threads showing the recommended separation of incoming underground services when sharing the same trench etc which will help with economising on the number of trenches etc. Remember there are different size ducts, so some will be small 50mm ones, medium are ~75mm and bigger ones are 100-110mm (or larger), so don't install a bigger duct than needed for say the incoming internet provider (50mm is ample there). Cold mains will need the bigger size because of the minimum bending radius of 32mm MDPE, same for the incoming mains steel wire armoured cable, and so on. If you don't need a sprinkler / automatic fire suppression, then the outside taps should all come off the incoming cold mains MDPE (blue alkathene) pipe and (ideally) not after the domestic stopcock in the house, thus saving another penetration. The house water pressure can be more adversely affected by the outside taps coming after the internal house stopcock, and I avoid this whenever I can by simply T'ing off the incoming 32mm pipe with feeds to various outside tap locations, underground.
Gibdog Posted January 20, 2025 Posted January 20, 2025 On 17/01/2025 at 14:03, Nickfromwales said: BT will want you to use a specific (BT56) rigid duct which they usually supply you FOC. Thank you so much @Nickfromwales - those little tidbits are so useful! Do you have any idea about Virgin connections? I've spoken to countless people there but no-one seems to have a clue what to say to me!
Nickfromwales Posted January 20, 2025 Posted January 20, 2025 1 hour ago, Gibdog said: Thank you so much @Nickfromwales - those little tidbits are so useful! Do you have any idea about Virgin connections? I've spoken to countless people there but no-one seems to have a clue what to say to me! Virgin seem to be less fussy, so I’d say pull a unique 50mm duct in for that, from the house to the boundary. Don’t forget to put a rope in it! 1
Benpointer Posted January 20, 2025 Posted January 20, 2025 On 25/11/2024 at 23:40, Nickfromwales said: The only real issue with rising penetrations through a slab is if it’s a block and beam. In this situation you need to avoid a beam. Structural engineers will have some “say” if you have all ducts together and it requires steel reinforcements being re-jigged, but a little bit of pragmatic pre-planning and dialogue will resolve this in a day. Tell your builder that this will progress at your pace, and will arrive at the end result that you want, and he will have to slow down accordingly. This has got me thinking about a couple of points: For a block and beam floor, the conduits presumably need to come up between beams. So do you cut a hole in a block, leave a gap between blocks where the conduit i, or what? Do the conduits get sealed in with expanding foam where they come through the B&B? Same for the insulation layer above the B&B? How are the conduits mad airtight once the cables, pipes etc are drawn through them - is expanding foam acceptable? Thanks
Benpointer Posted April 18, 2025 Posted April 18, 2025 On 17/01/2025 at 14:03, Nickfromwales said: @Gibdog The extra penetration for sewage and grey water vs one duct for both will depend on whether you have a sewerage treatment plant or not If you're on a network sewer then no need to segregate them. You shouldn't really have any 'sensitive' or low voltage services in with mains cables tbh, I'm sure it's been done under duress a thousand times though, but this is a new build / new design so best to do things right. GTC (I worked with them in Gravenhill in oxford) would point blank refuse you a connection if you asked them to pull the same 2 cables into the one duct, so beware of getting refusals to connect / adopt your chosen methodology with groundworks from 3rd party providers! BT will want you to use a specific (BT56) rigid duct which they usually supply you FOC. If you search on here there are threads showing the recommended separation of incoming underground services when sharing the same trench etc which will help with economising on the number of trenches etc. Remember there are different size ducts, so some will be small 50mm ones, medium are ~75mm and bigger ones are 100-110mm (or larger), so don't install a bigger duct than needed for say the incoming internet provider (50mm is ample there). Cold mains will need the bigger size because of the minimum bending radius of 32mm MDPE, same for the incoming mains steel wire armoured cable, and so on. If you don't need a sprinkler / automatic fire suppression, then the outside taps should all come off the incoming cold mains MDPE (blue alkathene) pipe and (ideally) not after the domestic stopcock in the house, thus saving another penetration. The house water pressure can be more adversely affected by the outside taps coming after the internal house stopcock, and I avoid this whenever I can by simply T'ing off the incoming 32mm pipe with feeds to various outside tap locations, underground. Wait, does the grey water need separating from the sewage for a STP? No mention of that in the Klargester Biotec installation instructions. https://www.tanks-direct.co.uk/files/pdf/2698_1014179-03-biotec-2--3-installation-manual.pdf
Russell griffiths Posted April 18, 2025 Posted April 18, 2025 2 hours ago, Benpointer said: Wait, does the great water need separating from the sewage for a STP? No mention of that in the Klargester Biotec installation instructions. https://www.tanks-direct.co.uk/files/pdf/2698_1014179-03-biotec-2--3-installation-manual.pdf A sewage treatment plant takes it all, toilet, shower wash basin washing machine dishwasher just nothing that you haven’t eaten except good quality toilet paper, no wipes no sanitary products no nappies, just poo. 1
saveasteading Posted April 18, 2025 Posted April 18, 2025 On 20/01/2025 at 21:41, Benpointer said: leave a gap between blocks where the conduit i, or what? Yes it is that simple. a hole in a block is to difficult, so either shunt it up to touch, or cut a alice off. then you have a gap remaining but can pop a piece of ply over it and infill with hand mixed concrete or some leftover. The ply is left in place for ever. 3 hours ago, Benpointer said: does the great water need separating For clarity. Grey water is the kitchen and laundry drainage and it goes in with the sewage to the treatment tank. Rainwater should not go there for several reasons. It dilutes the sewage and pushes it through too quickly, overloads the soakaway, and is wasted whereas it could go elsewhere useful in the grounds. Plus you can catch the rainwater for gardening. 1
