Depth of Hearth in front of Wood Burning Stove
benben5555
It's quite clear, the hearth in all cases should extend at least 225mm in front of the stove for a closed appliance (which I assume this is)
How deep it is overall depends on the dimensions of the stove and how close it can go to surrounding walls.
Its not clear to me unfortunately!
What is the meaning of this bit where it says 500mm
Our previous hearth came out half the distance of this one Around 200 Which was suppled and installed by the stove shop and Hettas certified by them
So the diagrams probably just a guide
BC will only be interested in the cert
Bottom line is you have to follow manufacturers instructions. If the manufacturer says 600mm, as an example, that's what you have to do. Manufacturer instructions trump building regs.
Choose log burner you are going to install follow those instructions.
