I was lucky that a local road next to my build was planed and relayed and got a good deal on the planings. I found them good, was over previous fairly solid ground, pushed about with the JCB and compacted with a big diesel roller, never moved but depends on how the edges are dealt with I guess.Ā
Take a look at this picture
Ā
Ā
No we are not looking at that trusty reliable subaru (that happens to be for sale)
Ā
We are looking at the road planings it is parked on.
Ā
That was constructed as a temporary loading bay for log lorries for some planned tree extraction (that has not yet happened)Ā  As far as I could tell from what I saw of it's construction is it is just a load of crushed stone of some sort laid and compacted and topped by quite a thick layer of road planings, probably laid and compacted in layers.
Ā
It certainly feels solid and does not appear to move as you drive or walk on it.
Road planings are a favourite material.
It is a highly controlled product as if type 1 with added sticky.
So if it is well broken up into being like a load of stone, and is well spread and compacted,Ā  it will be very strong.
I can't remember the bitumen content but it is a small %.Ā  About 3% maybe? ie lots of good stone.
Ā
Then you get a hot summer and it adjusts and sticks even better.
Ā
BUT make sure you aren't getting footpath surfacing. It is not strong and not a good surface for traffic.
Ā
The only downside of planings is that it used to be cheap but now is popular.
And quite rightly it can now be recycled for roads...it used to be designated as waste.
26 minutes ago, scottishjohn said:
how thick can you lay them so they will not move about with traffic
Best put courser cheaper stone down first. Then 50mm minimumĀ  Ā 100 better.
The driveway to our cottage is fairly steep with a tight turn. We initially laid it with type 1 which rapidly began to form ruts and potholes, as soon as the rain had washed away the fines.
Ā
I laid a load of tar planings over the top and packed it down with a walk-behind roller. What a transformation! It basically became as good as a tar surface but under a third of the cost.
Ā
It's not been 100% perfect though. There is one spot where repeated vehicles have managed to scrub a hole through the surface. The cottage is a holiday let so we have had hundreds of people going up and down, and they tend to be a bit hesitant about the steep, tight turn. If you know what you're doing, you know not to take your foot off until you reach the top.
Ā
I have had a half hearted attempt to repair the pothole, using some loose planings from the bottom of the drive, and mixing in some bitumen. It was extremely messy and without use of any heat the bitumen remained a sticky mess just under the loose chips. I think over time it will set, but it's taking much longer than I expected.
Be a neerd and watch the highways people. A patch won't stick, so they cut a rectangle out and fill it tight.
Then wheels are pushing the material sideways against the vertical face, not scrubbing it upwards.
Ā
Meanwhile you could make the pothole cleanish then apply bitumen tacky stuff before the infill. A tamper will be helpful.
how long ago was it you did thisĀ Ā
as newer type of tarmac is a chemical setting type-doyou cannot haet it like old tarmac and use it againĀ Ā
that is my worry that newer types of plannings will not bond together as older typeĀ  which came from an old road made with real tarmac
thanks for the replies boysĀ
Ā as for cost, quite cheap hereĀ
£15 a ton if you collect or £100 a truck load ,so I am told
Edited by scottishjohn
Depends when this was introduced and when the Road it came from was laid šŸ¤·ā€ā™‚ļø
It shouldnt be getting ripped up yet.Ā
Ā
The bitumen (or other bonder) is only surface coating the aggregate so it will be good, blended stone, whatever.
Ā
I'm not sure this method works with tar planings? There's not really a surface there to cut. It's still a somewhat loose material, basically small stones that are slightly stuck together. Like a big bowl of sticky rice.
Good point, neither am I. But it should be better than just a loose filling on top.Ā
at least 10years ago
Ā this is why resurfacing of roads does not last as it used to
Ā older type it was semi melted on hot days and healed upĀ  ,but not so with new typeĀ
Ā add to that the fact that they only lay it in 35mm thicknessĀ  and even on wet days when it never gets a chance to bond to the lower layers and we have a recipe to keep the pot hole repaiirers in biz for everĀ
it amazes me how they think it can work laying a much cooler tarmac than they ysed to on to wet foads and expect it too last
you used see flames coming out from under the tarmac laying mchine as they dried out and heated the road as the tarmac was laidĀ
,you never see that now as they don,t heat the road ,
with flames andwhich used to heat and blow the water awayĀ
how could anyone think laying tarmac on a cold wet day is going to make it bond to the layer below,
hence why you see patchs of it coming offĀ  down to the layerĀ  belowĀ  and then along comes the patching crewĀ  Ā  and a year later the patches peel offĀ
the reason a tarmac man gve me for the 35mm layer is that if they laid it at 50mm - and it came off it would then be classed as a pot holeĀ  and would have to be repaired much sooner under EU regsĀ  Ā
one of my pet hates --I have been watching sections of road where the old surface has been replacedĀ  Ā more than once in the past few years and yet th eold sections which were okĀ  are still okĀ Ā
proof it it were needed that the new product is not as good as the old typeĀ
all in the name of polution control to cut down the petrolium based tarmac emmisionsĀ
Ā add to that the change some years ago of not allowing use of granite chips in tarmacĀ  because it was said they made the surface less gripper cos they were hardĀ  and noisierĀ  Ā again EU regsĀ
Ā  yes granite chips in tarmac were and are harderĀ  and made the surface last longerĀ
Ā I know this is fact because that was the main reason that the quarryĀ  I am on was shut in 1992Ā  althoug the quarry had superb stone for building and monumentalĀ  workĀ  ,that produced lots of wasteĀ  which went into tarmac productionĀ  Ā and super white gravle chips for drives and pathwaysĀ  along with granite sand for use in concrete for sewers and harbour constuctionĀ  flod defences as it does not wear away the sameĀ  as it was and still is the best for constant contact with water
 granite sand is now well over £120  per ton as opposed to normal building sand at less than half the price
and instead of granite they turned to whinstone for tarmac
when all said and done you drive to grip on the roadĀ  and modern tyres are much gripper than they used to be anywayĀ
10 minutes ago, Roger440 said:
the madness of road laying
I once knew all about it, but it was hot and flexible stuff then. I sat onĀ  a Blaw Knox paver for months.
I don't know the new chemistry or the principles....so I'll say nothing.
Perhaps a little.
Ā
Maybe it is too stiff.
Our ground moves a lot, not just at trenches but everywhere and constantly through nature and vehicle load.
The old bitumen stuff was very flexible indeed so would bend and stay intact.
I daily saw a pile of removed road, perhaps 300 thick. One cantilevered lump, overhanging 600mm, rotated 90° in a summer and stayed in one L shaped piece.
Ā
I'm suggesting, in all ignorance, that the new make-up is harder. Without an independentĀ  research body (old TRRL) we may not find out.
Ā
Ā
Ā
Ā
  • 1 year later...
Just bumping this topic because it's time for me to do a bit of maintenance work on my tar planings driveway.
Ā
Question- should I sweep any loose stuff away first? Seems like it might be a good idea to get the best chance of the new batch staying where I want it.
I could probably part fill some of the deeper holes with the loose stuff, so long as I leave space for a couple of inches of fresh stuff on top.
Ā
I'm just going to be getting a trailerful (about half a tonne) at a time so it's really just a patching job. But I think I'll hire a whacker to go over the whole thing.
Ā
Anybody got experience of repairing holes in a tar planings surface? It's funny stuff... not exactly loose like aggregate, but not exactly solid like real tar.
Properly laid Type1 is basically returned to nearly solidĀ  stone density, just not glued together. Good planings are the same but do stick together.
Yes clean out the hole to see stone. It might be worth painting it with pitch or bitumen to get some bond.
Ā
Ā
Ā
Ā
I found the only way to get rid of potholes in my road plannings permanently was to do it in the rain! Or at least the whacking part. Tended to drag the fines and a bit of mud/clay up and bind it all together.Ā
Ā
But as per saveasteading, properly clean out the hole first.
Ā
Legend has it soaking in diesel also works but ive not tried that, and probably shouldnt.
1 hour ago, Roger440 said:
Ā
Ā
Ā
Finding a rainy day to do the job shouldn't be a problem!
2 hours ago, Roger440 said:
soaking in dieselĀ
Soaking would dissolve the bitumen content and lose the stickiness. I couldn't vouch for a coating of solvent between the old and the new but it might work.. it's your own surface so you can try.
Can you soften it with a blow torch.
Or put some mix in a barrel and light a fire under it.
Pour into hole, put a metal, or even timber, plate over it, then drive over it a few times.
Rinse and repeat till level.
Ā
(Road making materials are, by mass, the world's biggest recycled materials)
Ā
That might be more plausible were it not around 2⁰C just now.
