Hi all
I’m about to fit the PV panels to the roof and have been studying the detail where the GSE system meets the gutter (there won’t be any tiles below the solar array).
The GSE drawings show the flashing at the bottom running straight into the gutter, however my roof and most roofs have the fascia set higher than the rafter tails to kick the bottom tile up. This will inevitably leave a ‘trough’ at the bottom - although perhaps this is how it always is with just the membrane? Doesn’t seem right to me.
Do I fit a sloped batten to kick up the drip flashing (so it’s properly supported over its full length) - seems a ball ache. Or do I adjust the height of the fascia - though this could be problematic as there are tiles either side of the array.
Anyone fitted all the way to the gutter before? Thanks
Expand
Wouldn't you do this. To get the levels where you want them? Doing mine again I would miss out the GSE flashing and do lead instead
Screenshot_2024-08-18-19-30-41-84_e2d5b3f32b79de1d45acd1fad96fbb0f.thumb.jpg.92edbe6318c93d9cb54b67207b99564f.jpg
I’ve just done this
I used two eaves trays. Yeah they’re not 380mm like to instructions, but enough I was comfortable with.
I will do a full write up at some point
Osb over rafter
memvrane
counter batten
and at the fascia..
fascia kicked up 70mm above rafter legs
eaves tray
mebrane
25mm ventilation
eaves tray
Gse tray
solar
  On 18/08/2024 at 18:43, LiamJones said:
Osb over rafter
memvrane
counter batten
and at the fascia..
eaves tray
mebrane
25mm ventilation
eaves tray
Gse tray
solar
Expand
https://www.screwfix.com/p/felt-support-tray-5-pack/36622?tc=OA5&gad_source=1&gbraid=0AAAAAD8IdPzgEcfCF_SZZDp8-alGqZ-b8&gclid=Cj0KCQjwt4a2BhD6ARIsALgH7DpeOwsWCIBweiO47Ge4dCTasY_lGPJ6KSErzIq2sQxveSer3WhYQtUaAqBnEALw_wcB&gclsrc=aw.ds#product_additional_details_container
Like this? I’ve already got the drip flashing (ubiflex), so I could use this in conjunction with the eaves support tray.
the trays finish at the bottom of the panel, there is no spare tray to lap into a gutter. Sounds like the bottom of your panels will actually be in the gutter ?
You have to flash 150mm up and under the GSE tray to make it waterproof.
  On 18/08/2024 at 18:41, LiamJones said:
I’ve just done this
Expand
Nice tiles. What are they?
Thanks
We didn't go down to the gutter, but instead straight to a flat roof. I got a 300mm angled aluminium trim made up that went under the bottom tray and down on to the flat roof.
I have the exact same question and found this thread. I've got the eaves felt support trays fitted and roof membrane, just wondered if you sorted yours and if you have any finished pics?
Expand
It’s finished awaiting the roofers coming back to tile it in.
It was a ball ache to be honest. The angle of the roof changing at the eaves meant nothing really sat quite as I wanted and it involved a lot of improvisation.
I’m not sure how others have found it. I notice the poster earlier in this has some sort of slate? roof, so perhaps the kick at the bottom isn’t quite as pronounced as mine with concrete interlocking tiles. I don’t think I’d go to the gutter if I did it again if I could help it.
  • 6 months later...
Maybe this photo helps? I fitted another eaves tray over the top of the vent and under the gse trays before fitting the panels. This additional eaves tray only spanned the gse trays. At the tiles I had just the one eaves tray. The fascia/vent height was consistent all the way along, however
Expand
Didn’t you have any battens supporting the bottom of the GSE trays?
Screenshot from GSE YouTube video. It shows the support to the bottom of roof.
The GSE tray on my install. The flashing hides the batten, but you can see the tray is supported.
Edited by Nick Laslett
This photo is how the roofers left the roof before I started adding battens and installing the GSE trays. It is hard to see, you will need to zoom in, but there is a piece of roofing felt and roof membrane covering the bottom batten, creating the kick at the end of the roof line, the “tilting fillet”.
Expand
There is a gold batten added towards the end of the roofing work, once I was confident of how the eaves detail would work. If you look back at the first photo I posted, you’ll see it
