markharro Posted April 15, 2024 Posted April 15, 2024 Can anyone recommend a source...I think it needs to be flat smooth cardboard - not corrugated. This looks like it might work but I would need to cut strips from the roll - https://www.tiger-supplies.co.uk/Catalogue/site-equipment/temporary-protection/Floor-Protection/Floor-Card--Heavy-Duty---1M-x-50M-116-054
joe90 Posted April 15, 2024 Posted April 15, 2024 Are you protecting a floor? That’s what that’s for. Furring?? Please expand
Redbeard Posted April 15, 2024 Posted April 15, 2024 Packers for slightly-out-of-line studwork, I had assumed.
markharro Posted April 15, 2024 Author Posted April 15, 2024 35 minutes ago, Redbeard said: Packers for slightly-out-of-line studwork, I had assumed. Yes exactly this
Alan Ambrose Posted April 15, 2024 Posted April 15, 2024 (edited) You can buy a bunch of plastic packers in different thicknesses. This kind of thing: https://www.amazon.co.uk/Assorted-Glazing-Plastic-Variations-Available/dp/B0B21KQJW3 Edited April 15, 2024 by Alan Ambrose
Conor Posted April 15, 2024 Posted April 15, 2024 Window frame packers. I've a big bag from Screwfix. soooo handy for a range of jobs.
Onoff Posted April 15, 2024 Posted April 15, 2024 (edited) Edit: My lad 3D printed the last lot of hinge shims I needed. Edited April 15, 2024 by Onoff 1
Onoff Posted April 15, 2024 Posted April 15, 2024 Don't forget matchsticks & PVA for filling wrongly drilled screw holes. 1
markharro Posted April 15, 2024 Author Posted April 15, 2024 1 hour ago, Conor said: Window frame packers. Yes got them and use them for other things but for a stud length you would need a few dozen!
Russell griffiths Posted April 15, 2024 Posted April 15, 2024 How far out are we talking if it’s a fair chunk you would be better putting the studs right. remember if it sticks out one side it will be low on the other. you can straighten a wonky stud with a saw cut and then re screw it. if a stud is low you can add a bead of no nails to that stud then fit your boards, but don’t screw into that stud, let the adhesive go off then screw it. if you do use packers you will only need 4 per 1200 wide sheet one every 300mm same as screw spacing. 1
crispy_wafer Posted April 16, 2024 Posted April 16, 2024 I used plastic shims from screwfix to straighten a slightly out stud very recently, horseshoe shaped come in various thicknesses (1/3/5/10mm). Painted contact adhesive onto the stud and just stuck the shims in place. Previously I've cut studs on the bowed in side halfway down, give it a shove to straighten and open the cut then place a timber wedge into the cut. A few bags of packers are useful to have around, especially for getting ceiling battening level.
