Efflorescence advice
Steve06
Hi,
My name is Steve and thank you for accepting me into this forum.
I have a efflorescence question please.
We have a retaining rear garden wall that is two years old but has an efflorescence issue.
I have two questions please.
  1. What is the best way to remove this?
  2. How can I stop it returning?
Thank you.
The bricks on my gate pillars were showing some effervescence as well as spots of mortar etc. This after a clean with brick acid and spray application of this stuff. Still looks like this and nothing has come through:
IMG_20220430_184839
Before & after:
IMG_20220430_183443698_HDR IMG_20220503_190905382_HDR
So if I treat it, I am wasting my time and more importantly can it do any damage to the strength/integrity of this retaining wall?
Thank you to everyone.
I am not concerned with how it looks Tom, I am just trying to establish if I need to treat it because I don't know if it will permanantly damage the strength of the wall, this is a retaining wall!
There will be no damage caused by efflorescence. If there were most new build housing estates would be a pile of rubble.
 Reasonable to ask I guess Steve, but then why start the thread with:
Very sorry if I mislead with this post, my mind is in a state of panic at the moment should this wall fail.
I had dip into my pension to pay for it.
Edited by Steve06
It'll likely outlive all of us, looks well made. Only issue is the lack of water proofing that's causing the leaching, it won't weaken it. Of it really bothered you, you'd need to dig out the gravel, install a dpm, and fit coping stones to the wall. Hard work.
2 minutes ago, Redbeard said:
It's not quite an answer to your question, but am I right that there are no weep-holes?
But there is no cavity 🤷‍♂️
On 09/03/2024 at 12:50, nod said:
Unfortunately You can’t stop it
Eventually the salts in the blocks and mortar will run out.
If you add some weep holes it will be drier and leach out more slowly, and it is good practice anyway. Some bits of drain pipe pushed through flush with the garden side and as spouts on the outside. Holes that size are fairly hard work but ok with a good drill and high quality bit.
For now, the salts will brush off or wash off and eventually you will prevail.
There are weepholes thankfully.
Ironically one is where the worst of the efflorescence is, I believe the wall was built correctly, I just couldn't understand this!
I would like to say a MASSIVE THANK YOU to everyone who has commented, I am so grateful 👋🏻
Gratitude makes the world a better place. I'm grateful for it.
Ironically, that weep pipe may be causing wetness to concentrate in the ground in that area. No harm though and drying the rest of the wall.
