TheMitchells Posted October 3, 2017 Posted October 3, 2017 Can anyone give me suggestions for covering the rust showing on the corners of our front porch, in the render? I plan to give it a coat of white paint to freshen it up but assume if I just paint over the rust, it will soon show up. Its on most of the corners both at the front of the hosue on the porch and at the back on the kitchen extension. I wondered about Hammerite as better it has a slightly different shade of white than the rust. Or could I then paint over it?
Onoff Posted October 3, 2017 Posted October 3, 2017 I reckon they didn't originally use stainless steel render beads! I had that on a corner of an extension and ended up hacking it off and fitting a st/st bead. Anything else will just delay the rust.
Gone West Posted October 3, 2017 Posted October 3, 2017 The problem with steel rusting under render is that the steel expands when it corrodes and the render will crack. On my last house someone had fitted a steel bracket in the mortar between bricks. The bracket had broken off and been pointed over and over the years it rusted and pushed the brick out around 1/4".
TheMitchells Posted October 3, 2017 Author Posted October 3, 2017 thats not good news. its on about 4 corners. some worse than others. as we plan to sell it soon, i dont fancy the thought of having to get it all off and re-done.
PeterW Posted October 3, 2017 Posted October 3, 2017 If you can get the paint off it then give it a coat of Jenolite to convert the rust. Decent metal primer over the top and a coat of masonry paint should be ok. Don’t use Hammerite as nothing sticks to it so you’ll end up with a stripe on each piece that will make it look worse. This normally happens where external scuffing has occurred so just make sure the render and corner bead aren’t damaged. 2
gravelld Posted October 3, 2017 Posted October 3, 2017 Corner bead on the back of a van, pull it off... scrrratch... whack it up anyway.
Roger440 Posted October 3, 2017 Posted October 3, 2017 This. Available in white and over paintable. http://www.rust.co.uk/em-121-epoxy-rust-proofing-chassis-paint/c28117/ Given its buried in render it wont last forever, but a lot longer than anything else i could think of. 1
TheMitchells Posted October 3, 2017 Author Posted October 3, 2017 Have orderd the jenolite. sounds like just the right thing. thanks.
