pauld70 Posted February 11, 2024 Share Posted February 11, 2024 I have some strange noises coming from the system, the majority are caused by the flow meters, the clicking noise. But there are other noises, ive managed to capture these on youtube.. Keen to see what everyone thinks.. https://www.youtube.com/shorts/h4s7s81V4Xc Link to comment Share on other sites More sharing options...
JohnMo Posted February 11, 2024 Share Posted February 11, 2024 Has it always been like this? Did anyone touch or maintain the system prior to the noise starting? When I had air in the system the flow meters bounced about - I would start by bleeding the system. Link to comment Share on other sites More sharing options...
ProDave Posted February 11, 2024 Share Posted February 11, 2024 You have an electrical problem. Are the lights on top of the actuators really flashing? or is that an ailiasing problem with the camera? If they are really flashing, they should not be, and the pulsing of the flow meters looks like a pump is rapidly turning on and off. Post some close up still shots of all the electrical control boxes, pumps and motorised valves etc so we can see what you have. Has it only just started doing this. Link to comment Share on other sites More sharing options...
pauld70 Posted February 11, 2024 Author Share Posted February 11, 2024 Link to comment Share on other sites More sharing options...
FuerteStu Posted February 11, 2024 Share Posted February 11, 2024 +1 on the electrical issue. Looks like a loose connection or possible sticky relay in the stat. Link to comment Share on other sites More sharing options...
pauld70 Posted February 11, 2024 Author Share Posted February 11, 2024 Lights flashing shouldn't be an issue just loxone showing the state of the system. LED states↑ Please note that the status LEDs do not light up while the actuator is moving. LED state Description RED with short interruptions No communication to Miniserver possible. Please check the wiring. ORANGE on with short intervals Tree Device was detected on Tree bus, but is not paired with Miniserver. GREEN 3 short flashes Communication OK, device paired. RED blinking Online, valve open more than 90%. ORANGE blinking Online, valve open between 10% - 90%. GREEN blinking Online, valve less than 10% open. RED rapid flashing The error "valve stuck" or "no valve detected" is present. Please check the valve pin, it should be easily movable. Link to comment Share on other sites More sharing options...
pauld70 Posted February 11, 2024 Author Share Posted February 11, 2024 Hi would electrical explain the other noises ? Link to comment Share on other sites More sharing options...
pauld70 Posted February 11, 2024 Author Share Posted February 11, 2024 25 minutes ago, ProDave said: You have an electrical problem. Are the lights on top of the actuators really flashing? or is that an ailiasing problem with the camera? If they are really flashing, they should not be, and the pulsing of the flow meters looks like a pump is rapidly turning on and off. Post some close up still shots of all the electrical control boxes, pumps and motorised valves etc so we can see what you have. Has it only just started doing this. Dave do you need any other photos mate ? Link to comment Share on other sites More sharing options...
pauld70 Posted February 11, 2024 Author Share Posted February 11, 2024 guys some feedback, there is no air in the system and the pump is modulating the boiler Link to comment Share on other sites More sharing options...
pauld70 Posted February 11, 2024 Author Share Posted February 11, 2024 todays noises - close up of system Heating 1.mp4 Link to comment Share on other sites More sharing options...
ProDave Posted February 11, 2024 Share Posted February 11, 2024 So the flashing lights might be normal, this is not a system I am familliar with, and I don;t think the actuators could be opening and closing that quick. The water flow is pulsing on and off very rapidly, it has to be the pump as I can't see anything else that would turn on and off as quick. Somewhere on the pump on that black plastic box will be some buttons and lights. Try pressing the button to select a different pump mode, and try posting some pictures or video of what the lights on the pump are doing. Link to comment Share on other sites More sharing options...
dpmiller Posted February 11, 2024 Share Posted February 11, 2024 Actuators are normally slow-acting devices. The flow pulsing as it does seems too fast to me. I'd be checking that any non-return valves, pressure regulating valves, mixing valves, and pressure vessels attached to the system are all in good order as it looks more like a hydraulic resonance. Like water hammer... Link to comment Share on other sites More sharing options...
Kelvin Posted February 11, 2024 Share Posted February 11, 2024 (edited) Just to be clear. It was working fine until it wasn’t. Nothing has changed anywhere on your system both on the heating side and the Loxone side? You need to start ruling things out and I’d start with the Loxone system. Can you run the system manually and effectively disconnect the Loxone system? Presumably it’s possible to put the Loxone actuators into manual mode and fully open them. If you can do that you might be able to determine if the fault is on the heating side or the Loxone side. You can then bring one room back on at a time to potentially further isolate the problem. It could be electrical with something calling for heat rapidly on and off or indeed some kind of hydraulic problem as above. Edited February 11, 2024 by Kelvin Link to comment Share on other sites More sharing options...
Alan Ambrose Posted February 11, 2024 Share Posted February 11, 2024 Wow that's super odd - ours has been pretty much silent at all times except for the slight sound of water moving in the pipes. Now I think about it, even that seems odd. +1 to some actual diagnosis steps. Switch the Loxone box off for a minute, or disconnect the connection to the actuators and see whether most of the rapid stuff stops. Link to comment Share on other sites More sharing options...
Kelvin Posted February 11, 2024 Share Posted February 11, 2024 3 hours ago, ProDave said: So the flashing lights might be normal, this is not a system I am familliar with, and I don;t think the actuators could be opening and closing that quick. The water flow is pulsing on and off very rapidly, it has to be the pump as I can't see anything else that would turn on and off as quick. Somewhere on the pump on that black plastic box will be some buttons and lights. Try pressing the button to select a different pump mode, and try posting some pictures or video of what the lights on the pump are doing. If it was the pump you might be able to hear it. They generally almost silent when running by rapid pulsing would be audible just because it isn’t constant. Use a long screwdriver as a makeshift stethoscope with the blade placed on the pump and cup your hand round the top of the handle. Move the tip to different places on the pump. If it’s pulsing you’ll hear it. Link to comment Share on other sites More sharing options...
