Marvin Posted January 7, 2024 Posted January 7, 2024 We have a Cool Energy InverTech Air Source Heat Pump | CE-iVT9 4.3kW-9.5kW. We have had a DC Bus Overvoltage fault come up. Running since June 2021, its our first hiccup. The result was that the pump was on but not the compressor or the fan. We managed to turn everything off and turn it all back on and it fired up as per normal. However, in case it happens again does anyone know what might have caused this to happen? Regards Marvin
Conor Posted January 7, 2024 Posted January 7, 2024 One for @dpmiller Only fault I've had was due to a power cut.
HughF Posted January 7, 2024 Posted January 7, 2024 That would typically present itself as an error in the power+ module that drives the compressor (the inverter) - a fault like that would be caused typically by a spike on the AC input, I would think. A quick call to Chris might be worthwhile? He can probably advise. 1
dpmiller Posted January 7, 2024 Posted January 7, 2024 possibly a mains spike that got through the rectifier? Both the fan and the main drive inverter are on the same bus so I'd guess that anything that disables the inverter crashes the fan module too. 1
dpmiller Posted January 7, 2024 Posted January 7, 2024 1 minute ago, HughF said: That would typically present itself as an error in the power+ module that drives the compressor (the inverter) - a fault like that would be caused typically by a spike on the AC input, I would think. A quick call to Chris might be worthwhile? He can probably advise. snap! 1
HughF Posted January 7, 2024 Posted January 7, 2024 R290 version available ‘soon’ btw….. looks excellent, as you’d expect from Sprsun + Chris….
HughF Posted January 12, 2024 Posted January 12, 2024 Hiccup on mine today too. I get a phone call this evening saying ‘the heating went off this afternoon’…. Asked for a photo of the panel, it had started to do a dhw refill but never started up the pump/compressor/fan cycle. So it was just sat there waiting for Christmas to come round again. No errors, and a power cycle seems to have fixed it and it’s now doing a refill, having woken up in heating mode.
Chanmenie Posted January 12, 2024 Posted January 12, 2024 (edited) On 07/01/2024 at 19:31, HughF said: R290 version available ‘soon’ btw….. looks excellent, as you’d expect from Sprsun + Chris…. The CE-IVT9-EVI is R290 and available now I believe It’s rather expensive though, a £1k more than the Vaillant Aerotherm plus Edited January 12, 2024 by Chanmenie
HughF Posted January 13, 2024 Posted January 13, 2024 10 hours ago, Chanmenie said: The CE-IVT9-EVI is R290 and available now I believe It’s rather expensive though, a £1k more than the Vaillant Aerotherm plus Yep, certainly not the cheapest unit around…. Shame they don’t make a 5kW as well really…. It’s a little on the large side for most.
JohnMo Posted January 13, 2024 Posted January 13, 2024 11 hours ago, HughF said: Hiccup on mine today too. I get a phone call this evening saying ‘the heating went off this afternoon’…. Asked for a photo of the panel, it had started to do a dhw refill but never started up the pump/compressor/fan cycle. So it was just sat there waiting for Christmas to come round again. No errors, and a power cycle seems to have fixed it and it’s now doing a refill, having woken up in heating mode. My ASHP did something similar (not cool energy) just after I started to do DHW with it. It changed modes from heating to DHW and just stopped waiting for something. I switched off and on again, never done it since.
dpmiller Posted January 13, 2024 Posted January 13, 2024 @HughF what kind of changeover valve do you use?
HughF Posted January 13, 2024 Posted January 13, 2024 55 minutes ago, dpmiller said: @HughF what kind of changeover valve do you use? Honeywell…. Came on my Vaillant pre-plumbed cylinder. Hasn’t given any issue till now and it doesn’t have any aux contacts. I’ve got it wired up to the heating live, so it’s power-off for dhw .
HughF Posted January 13, 2024 Posted January 13, 2024 Temp was 37.5 (reheat threshold is 12.5 below target) and setpoint was 50. Everything behaving as expected, except it just sat there and didn’t fire up to complete the dhw cycle.
Wil Posted Wednesday at 14:37 Posted Wednesday at 14:37 Sorry to thread resurrect- but for you CoolEnergy owners- any way of getting the COP (or even just the actual heat output) out of the Controller? I have the electrical measured elsewhere but would love to know what COP I’m getting. Just not love it enough to pay £1000 to emonpi for their meter…
