We're discussing design details with our architect and told her we like the look of parapet verges, similar to the attached drawing. She told us that a parapet verge on a timber frame house is not buildable. The attached drawing is actually from a timber frame company we got a design from but didn't proceed with, so I guess they thought it was possible. I do understand that you only have the one leaf of brickwork, so I'm not sure if the timber frame company were proposing a verge just one brick thick, which would look a bit skinny, or had some other way in mind of building the parapet wide enough to look correct.
Any thoughts? Can you have a parapet verge on a timber frame house?
Yes, 100%.  There is a new(ish) timber frame Premier Inn near me with this detail.  I can see it from my office.
Whilst we have built solid rather than TF I installed two on the roof that I built All in timber
8 minutes ago, LnP said:
Thanks @nod, but I only see barge board verges in your photo.
It’s the same difference I could have quite easily built it higher like your drawing Or taking over a third floor
It’s not difficult with loose rafters
It’s definitely achievable, but you need to look at all these details and work out how much more it will cost versus a standard verge.
I can see some very expensive leadwork needed for your design and also capping they could be stone or more modern aluminium or lead.
I could see each end of that house being 2-3 grand more than standard.
So is it £6000 nicer.
On 31/12/2023 at 23:37, ETC said:
Don’t do it - asking for trouble - water will pour in if it’s not done properly.
Majority seem to use fiberglass
I used lead for the above reason
Quite easy to get the lead nice and flat Not so easy with fiberglass
I used floorboards fully nogged which allowed me to beat the lead round
Barely any wet coming in once the building paper and lead was on
