So we are going to install a 500l thermal store into the utility room. This will create quite a bit of heat I suspect and it would be good to spread this round the building. In fact next to the utility is the integral garage which is full insulated - 60mm internal insulted PB, triple glazing and an insulated garage door. Would it be mad to put a single room mvhr system between these rooms to gentle heat the garage with the excess heat from the the TS?
I suspect there may be a fireproofing issue, effectively having a garage and the house linked by ducting through what is supposed to be a fireproof wall. Perhaps if you had a fire alarm and fire dampers?
Yes
purely because of the initial outlay, the idea isnt bad but it will NEVER pay for itself,
a few hit and miss vents may not be a bad idea but actually pumping the excess heat into a garage. I very much doubt will be cost effective
45 minutes ago, Lesgrandepotato said:
as long as it doesn't encroach over the french windows that could be neat. I suspect the plumber maybe less than enamoured at this development! It is only on the other side of the wall though
Don't ask him.....tell him ;). Your paying ?
