Self build water connection ideas
Amateur bob
3 hours ago, saveasteading said:
About £600 to mole it?
The longer coil of pipe you put in, the fewer connections and leakage risks. For the best pipe prices and long lengths. try the specialist suppliers.
heres a quote from someone on here a while back
The cheapest price I could get to run 140m of water pipe down the lane was nearly £24k.  That was using a contractor (approved by highways and Wessex Water) to dig the trench, lay the pipe, and make good, and Wessex Water doing the connections, installing the meter etc.
my connection point is 600m away so this is a big concern
Not sure whose quote you are reading but ‘down the lane’ implies to me a road or pavement dig not across fields. They will probably only inspect both ends of the trench ie from road and into dwelling.  But if in field make sure it won’t freeze.
how do you plan to remove your foul/waste water? If that’s by public sewer then they will ask about your incoming water.
if your only building an annexe you might get away with connection to existing property because some annexe don’t have own council tax.  But I’m guessing it’s not an annexe.
im planning to put in a treatment plant, klargester, no its not an annex its a 1 and 3/4 storey house
11 hours ago, Jilly said:
A secondary/ submeter off the main one might be a possibility in your situation?
thats an interesting idea, connect to the pipe going thru field and put a metre on it for myself? interestingly the guy who the pipe goes to has a metre and he subtracts his total off the main one where it comes off the main so that hes not paying because as i said the same pipe goes up to the farm steading which isnt residential so has to pay, in reality i should be free to so the guy in the house would just be subtracting a bigger amount from the total if i just joined on to his pipe?
In Scotland, you explicit approval from SEPA to install a treatment plant and soak away. Full design details need to be submitted and approved.
Just do a proper job, teeing off another pipe will just end up with you or the other person getting a dribble out of the tap, if the other runs their tap at the same time. If you want to build, do it properly or not at all.
yes ive an engineer working on designs and my draiinage system at the moment, regarding the water pressure i suspect there is enough for another house as we used to house double the amount of cattle in that steading drinking at the water toughs with no issues, a house only uses water occasionally i.e when you run a tap or take a shower?
Flow issues can be overcome with a cold water accumulator and a booster pump.
If you have a planning condition to connect to the public water supply, you'll need confirmation from SW that this has been done in order to discharge the condition. If SW does not approve of a branched connection from a neighbouring line then you'll never get this condition discharged until you do it the right way which is with SW engagement. Do it right once and you save yourself a massive headache and being tripped up by 'paperwork' (or lack of) when it comes to obtaining completion.
3 hours ago, Conor said:
What you're proposing to do is illegal under the 1980 and 2002 water industry acts. You'll need to apply for your own connection to SW, or drill a borehole.
are you sure its actually illegal if i were to connect at the steading given we actally own the steading and water supply there?
ok ill need to check its actually a condition, can you get a mortgage without a completion certificate given ill have a mortgage to start with for the build?
thanks
3 hours ago, joe90 said:
I tend to agree with a new supply, should it ever get sold sharing will cause problems and you know you will have decent pressure 👍
the new supply could be doable if i can confirm that pipe can be laid with a mole plough, ill need to cross fields though so field drains could be an issue at depth
Just ask the farmer. 🤞
I would get some prices to make an informed decision.
In 2020 in Ireland we had a borehole all done and dusted for about €4000.
Similarly our council requires separate supplies for a farms and houses. A person in my locality was only granted planning on this condition although he owned an existing borehole 30m from the house. As to whether the second borehole got done in the end I couldn't possibly say but it was shown in the plans....
thanks
You'll need to check with a mortgage provider/broker what the requirements are for moving from a self build mortgage to a standard mortgage. My guess is a completion certificate may be one of those requirements. Hopefully someone more knowledgeable in mortgage matters can confirm.
