1 hour ago, Crofter said:
Thanks Jeremy, I get a bit confused because my current house uses a rather peculiar dual circuit system.
If I could drift the thread a little, I have yet to get my head around the wiring of the UVC- there are two immersions, and I gather that the lower one is designed to go on the E7 supply, with the top one used for boost. There must be multiple ways of skinning this particular cat, e.g. a simple switch for the boost (pref one that times out after an hour, so it can't be left on all the time), and a timer on the lower one set to sync with the E7 times- or is it better to get a fancy all in one box to control both? Perhaps a question for @Nickfromwales?
Pic of your  meter / CU?
I wonder if you are on the "Total Control" tariff, something I think was unique to SSE areas and no longer available a a new install.  The give away will be a comlicated looking CU with 3 main switches often labelled "A circuits" and "B circuits"
If you do have that setup then one bank (I forget which one) will be specifically for "heating appliances" and will be available and metered 24/7 at the cheap rate. This is where you connect focal point heaters, the immersion boost, showers and towel rails.
14 hours ago, Nickfromwales said:
Normally I'd say yes, but as this is not a huge UVC in a nice rental I'd say stick with the lower for maxing the UVC out on e7 and just have the upper as boost ( eg you can put a sign saying "please press once before showering for continuous hot water" if it was deemed necessary of course. It ( the boost heater ) could even be triggered by flow to the shower via a flow switch and contactor, and a timer.
Its just one of those things where there are a lot of eventualities that need to be considered. A boost switch is a simple backup / contingent.
That makes a lot of sense. If there is a stat in the top heater it will only actually come on if the water previously heated by E7 has already been used.
  • 4 weeks later...
Back on this one again...
My sparky is wanting to wrap everything up soon so can't put this off any longer.
This is a sort of "does this exist" question:
- for the towel rail, what I would ideally like is a one-gang timer switch that I can set to sync with the E7, but the controls for which are then locked down behind a blanking plate. Thinking a simple mechanical timer hidden behind a 1G blank. Something like this: 15493efea54ebc.jpg.jpg
although I'm not sure if that unit is designed for you to screw a blanking plate over the top.
What would be even better would be if a timed boost facility could be added, for the user to operate.
The DHW should be much easier- just a timer for the main immersion, and one of those one-big-button boost controls for the top immersion. Hopefully nobody will want to tamper with the E7 timer if I give them  a big button to press.
Edit to add: here's a thought. Buy an unfilled towel rail, fit it with *two* immersions, one for boost and one for the timer. Other than looking a bit gallus with the two flex coming out of it, is there anything wrong with this idea? I presume each immersion has its own thermostat anyway so it wouldn't actually matter if they both came on at the same time.
You can get tamper proof enclosures for time switches, like this: https://www.heatingcontrolsonline.co.uk/lockable-programmer-timeswitch-guard-p-344.html
With a bit of ingenuity, you could probably drill a hole in the lockable cover that would only allow access to the boost button that some timers have.
This was just the first one I came across, but there are probably others around, as I suspect that it's pretty common to want to lock down controls in rented accommodation.
  • 4 months later...
Guest Alphonsox
On 30/08/2017 at 09:36, Alphonsox said:
Minor update on this subject ......
I fitted 4 of these Greenbrook T205 units a year or so ago - One failed within 6 months, another has just failed. Looking at the product reviews on the screwfix website this seems to be a very common occurance. I'll be replacing them all with the Timeguard FST77 as mention by @PeterStarck above. These now come with 5 Year guarantees so I have some hope they will still be working in a few years time.
  • 1 year later...
Help needed so I am jumping into this post with another towel rail question?  In the parents new shower room, which is almost finished, we need to add a towel rail.  I was over ruled in putting in under floor heating (for various reasons) so they are relying on a towel rail for all the heat.  There is electric to the location for the rail but no conenction to another point outside of the room for a controller so we need a towel rail with an element controlled by a wireless timer/thermostat.  All the decorating has been done now so we dont want to have to channel out for another cable - also there are plenty switches outside the bathroom door that we'd struggle to add another.
The bathroom suppliers I went to ordered what I thought was what we wanted but it has arrived and it has a wifi control unit which still needs a cable to the electricity supply for the rail. ie - running it from a smart phone, which isn't what we wanted.
i have found this one
https://richmond-radiators.com/product/bellerby-thermostatic-electric-curved-heated-ladder-rail-towel-warmer-rack-classic-chromewhite/
Does this sound right - we can have the control unit in the bedroom and it would communicate to the element in the towel rail??
The bathroom supplier has been in communication with the supplier of the towel rail and they say they have not heard of anything suitable for our situation!  I am hoping @Nickfromwales can help here.  It looks like we'll be charged a restocking fee if we send it back.  Help!
Edited by TheMitchells
Having just rung Richmond Radiators, they have the timer and element which I can buy to put into the towel rail that we already have.
https://richmond-radiators.com/product/digital-thermostatic-electric-towel-rail-heating-element-chrome-white/
or they can supply the towel rail and timer instead and thats cheaper than the towel rail that I have already paid for......
I need to see if I can return the rail and wifi controller  and get my money back.
I've been looking for the same for another couple of jobs, and found these about the most aesthetically pleasing of all of the 'offerings' out there. There are some bloody ugly and 'clunky' ones out there, so I have these ones earmarked already.
"Carry on!"
