I'm trying to decide if to insulate the first floor floor void or not. I don't believe it is  building reg requirement (feel free to correct me).
Benefits are reduced sound transmission, and stops so much heat transfering upstairs?
Problems I see are the void is full of services, cost, time and getting the insulation to be continuous and not fall out from between the joists.
Any thoughts?
Yep rockwool type material - not PIR, otherwise you will hear every noise from above. Plus as said noise is covered in building regs.
I just checked Part E. It needs 100mm mineral wool.
What's the best way to do this? Position pipes and cables in the top of the floor void, then push the mineral wool in the gaps between the joists before plasterboard?
Wool rolls are the cheapest, but I can see it falling out as its not very rigid.
Any thoughts?
I’m doing exactly this as we speak. It’s a building reg as far I understand it. Even if it wasn’t I’d be doing it anyway. In the grand scheme of things it’s not a huge expense. I’ve put all above the cables and between all the webs of the joists.
If you cut slightly bigger than the hole your filling it stays in.
Edited by Kelvin
