Post and beam Posted August 23, 2023 Posted August 23, 2023 I believe this forum is more reliable than the usual check a trade type sites, so i am hoping to engage a bricklaying wizard, and or, get a recommendation if you know of anyone you trust. The project is at post code SG27EF in North Hertfordshire and i hope to be requiring this work at the end of the year, ish. Do brickies work during the coldest part of the winter? Obviously frost could be the issue. Anyway, details are 200 square metres 4 bed storey and a half cottage style house. Cedral cladding to the gable ends and dormers so no bricks at these locations. Large chimney and an internal Inglenook. I am looking for a little herringbone panel work to the front. Can supply pictures of the elevations as required. From a previous conversation i think its about 9000 bricks total.  Is this even the correct way to go about this? Apologies in advance if its not. Thanks keith
Canski Posted August 23, 2023 Posted August 23, 2023 5 minutes ago, Post and beam said: Do brickies work during the coldest part of the winter? No we are all lazing around in the Caribbean then waiting for it to warm up 🙂  Get your m2 areas of your brickwork and blockwork quantified. Measure extras like lintels , feature work, insulation etc. Draw up a list of any special requirements you have then start contacting some bricklayers for quotes.
Post and beam Posted August 23, 2023 Author Posted August 23, 2023 12 minutes ago, Canski said: then start contacting some bricklayers for quotes. Thats sort of what i thought i am doing here. 'Lintels' ? might as well be latin dude.
gaz_moose Posted August 24, 2023 Posted August 24, 2023 a lintel is the load bearing beam above a window or door.
Big Jimbo Posted August 24, 2023 Posted August 24, 2023 Have you got a decent set of drawings, showing all the elevations ?
Big Jimbo Posted August 24, 2023 Posted August 24, 2023 I know a good team of brickies, but they are going to want more than "I want a bit of this, and a bit of that" Full set of plans showing all elevations. Inner and outer wall construction. Details of cavity, and cavity insulation. Lots of details required before you can just get a pi$$ing in the wind quote.Â
Dave Jones Posted August 24, 2023 Posted August 24, 2023 more info, is this above DPC work only ? Â Do you have construction drawings showing all the detailing BCO require ? Â Have you had it QS'd yet ? Â
Post and beam Posted August 24, 2023 Author Posted August 24, 2023 I know what a lintel is, i dont know what parameters of one i need to care about to answer your question. Yet. I have elevations and floor plans, dont have the BC full 'buildable from' plans yet. Â Yes this would be up from DPC. There is a groundworks contract to get that far. Then phase 2 is TF erect. Phase 3 is weathertight. External cladding then follows, hence me starting to need figures for said cladding.
Mr Punter Posted August 24, 2023 Posted August 24, 2023 If the information is on the drawings you can just send these out. Lots of bricklayers are labour only. Send out plans, elevations, Structural Engineers drawings and notes, specification and lintel schedule.
Dave Jones Posted August 25, 2023 Posted August 25, 2023 pay £200 and get your plans QS'd. https://www.estimators.com/  Anyone having to quote will know exactly how may bricks, blocks, trays, weepers etc they will be having to lay . You will also have a ballpark price to know if your being bent over. 1
flanagaj Posted September 12, 2023 Posted September 12, 2023 On 25/08/2023 at 07:33, Dave Jones said: pay £200 and get your plans QS'd. https://www.estimators.com/  Anyone having to quote will know exactly how may bricks, blocks, trays, weepers etc they will be having to lay . You will also have a ballpark price to know if your being bent over.  I was just looking at the estimator service. Keen to understand how they go about deriving the labour costs and material costs.  Are they accurate?
Dave Jones Posted September 13, 2023 Posted September 13, 2023 9 hours ago, flanagaj said:  I was just looking at the estimator service. Keen to understand how they go about deriving the labour costs and material costs.  Are they accurate?  as accurate as your plans. Provide the structural engineer drawings and they will price steelwork as well. They use rates for your area but you can override day rates to suit.  They will not cost as they cant, your costs to get out of the ground so groundworks costs. 1
