It turns out my planned house is just within a conservation area. An ASHP was drawn on the planning application on the south side of the house but somehow i dont think i can justify saying this is tacit approval of same.
So i have the obvious 2 options. Request planning and go for an expensive MCS install.
or
Buy the parts and try to engage someone that will connect it all up for me. I am not a plumber and just about bright enough to understand that my limitations mean i should leave this to someone else.
Discuss
Oh and thanks as always
Our planning department just assumed we had a heat pump, asked for heat pump commissioning cert and UVC cert, even though the plans were showing a gas boiler.
Ask the planners if you have express planning for the heat pump, if shown on an approved drawing, they have approved it.
Then do whatever you want as far install.
so do you have planning permission for the house in the drawings c/w a heat pump? If it was on the drawings them surely you have permission and must build in accordance with the drawings?
To expand on @dpmiller, if on the drawing you have to do it, deviation requires an amendment. Your planning notice should say this explicitly.
I had a couple things in different locations and prior to getting a completion certificate, amended drawings had to be provided and approved.
Thanks for the replies guys.
My concern is that once i engage them there is no going back. Therefore, if they say that i dont have permission i am then committed to putting in a planning application.
This removes my other option of quietly getting a non MCS install doesn't it?  Planning will insist on an MCS certificate.
Maybe not, they will ask for a commissioning certificate. What does your planning letter actually say?
Don't see how they can do this unless it's built into one of the conditions.  Building control sign off is of course necessary, but that needs only to meet the BC rules
Planning won't care who I stalls the heatpump, just where it is. Ours is 90° to where was agreed but so far no complaints
You can install an ASHP under permitted development even in a conversation area, so long as it's not visible from the main road and a few related location restrictions. Plus all the usual constraints (1m from boundary, comply with MCS section 20 noise design limits, be the first/only heat pump on the premises, not be used for cooling,  etc)
Is your concern related to your comment about PP being for it "on the south side" ? We don't have the context to interpret the relevance of that.
In my experience (also in a conservation area, and we forgot to put the ASHP on the PP application at all), the LPA won't care about MCS, and the MCS installer won't care about PP/PD process.
The only value in the paperwork is to cover your backside if anyone comes at you making complaints, or when you come to sell.
Doing an MCS install it the easiest (in terms of effort, if not money) way to get an official looking piece of paper that says you followed the MCS noise guidelines. And that's only important if someone complains about the noise.
Couple of comments
A new build has zero permitted development rights, until after the completion certificate is issued. So no.
That also states it must be on the rear elevation in a conservative area, within permitted development right, which is relevant here anyway.
Gosh. Well if someone wants to block the install on this basis, just unplug the external unit and shift it into a store room until they're gone the certificate issued, then bring it back out. 🙄
Do you have a reference for that? I can't find anything saying it must be at the rear (and indeed, ours isn't).
Planning portal says "On land within a Conservation Area or World Heritage Site the air source heat pump must not be installed on a wall or roof which fronts a highway or be nearer to any highway which bounds the property than any part of the building" which is what a paraphrased as "not visible from the main road".
(btw did you mean to say "irrelevant"? I think it's semi-relevant even if going through PP, as the PD rights will be the reasonable baseline the LPA will start with)
No, simply to illustrate that a small box annotated as ASHP is drawn on the south side of the ground floor part of the submitted drawings. No other significance.
The whole idea is it's on the plan, sorted, you have planning permission.
There no permitted development rights for anything while a property is being built, until approved and signed off. While a build is under progress it has to be completed as per the approved drawings.
The heat pump location looks like I took it from the Scottish version of permitted development rights
https://www.gov.scot/publications/guidance-householder-permitted-development-rights-9781780456836/pages/8/
But this English site says front wall. Less prescriptive.
Got it.
So there's three different Qs here, and there's very little interdependency between them.
1/ MCS vs self-install. You can choose this regardless of installing under PP or PD (or in breach thereof). The fact it's conservation area has little bearing on going MCS or not.
2/ Install under PP or PD. As JohnMo says, you can't use PD until completion. So the choices are doing it under PP or just close your eyes and claim it was done under PD post-completion.
3/ Conservation area. This is only relevant if doing it under PD, and the impact is minimal (slightly more restrictions on placement). As JohnMo says you can't do it under PD until after completion anyway.
Another undiscussed issue is if you are claiming the £5k BUS grant. Then is must be an MCS install, and you need to declare the date of install which will probably be pre-completion which means it really needs to be covered by the PP. Which again as JohnMo says, if it's on the plans its covered.
Edited by joth
I just read the England relevant version on the .gov site.
It does not say you cannot install in a conservation area, its just more restrictive. But even that is not that restrictive.
Needs to be MCS or equivalent, ? and not for cooling or closer to the road than the house.
Otherwise go for it
Well that is sort of the whole thrust of my question.
Should i just ignore the grant and get it done outside of MCS at the best standard and price i can arrange.
Comes down to
a)Price
b)Whether you either know someone who can do the system design/install outside MCS or are prepared to learn enough to do it yourself.
If b) is true then you will quite likely get as good or better job than many (but not all) MCS installations at a similar or lower cost even without the grant. If b) is not true I'm not sure you have a choice.
Doing it outside MCS requires express planning consent (which you appear to have) and excludes you from the grant.  On the plus side you don't have to pay the MCS fees (which are bundled into the MCS installers price) and you aren't bound by rigid MCS rules which don't always allow the optimum design choices.
MCS will argue that MCS gives you better consumer protection, others have a different opinion.
If you have UFH the system design is done basically. Just a matter of kW for the heat pump size, if your have loads of zones, install a buffer (but a two port in the return line). 3 port valve and cylinder. 6kW can get away 22mm copper pipes as long as the run isn't for miles, 6 to around 10kW 28mm primary pipes.
Keep an eye on eBay, my ASHP was £1300 delivered (same thing from Viessmann, currently reduced to £3300 from £5200)
 https://viessmanndirect.co.uk/Catalogue/Vitocal-Heat-Pumps/Vitocal-100-A,
The same person I bought my ASHP from, also had pre-plumbed cylinders for £6-700, @Jenki I think bought one.
Update:
I asked planning to confirm that i had planning permission for the ASHP as drawn on my submitted plans.
Their response....
The details of the air source heat pump will need to be provided when you discharge 6 (Climate change). If you include technical details of the pump you want to install then we can determine that it is appropriate.
They did not expressly say so, but did say that they are mostly concerned with noise. This is reasonable i would say. Then after a back and forth e mail exchange
The details would be included when you make the application to discharge.
When it comes to air source heat pumps, we are mainly concerned with the noise levels. We want to keep this to a minimum in order to protect the amenity of neighbouring properties. I have asked the Environmental Health Officer to provide you some advice in which he responded ‘the ideal sound power level (SWL) would be a maximum of 50dBA. Anything above this, we would usually require a background noise measurement to demonstrate that the unit achieves 5dB below the background noise level at the nearest neighbour. I do not know of any units that have a sound power level of 50dBA or below, so it would ideally be as close to this as possible.’
 I would therefore suggest looking into the sound power levels when searching for an appropriate pump, and choosing one with a lower level.
I have asked them to clarify becuase it appears to me that they expect me to buy a pump first and then they test it to decide it meets their criteria. As it happens the closest neighbour on the south side is 9 metres away. At the rate the sound level falls away with distance i very much doubt there is going to be a problem. But, with them not wanting to just say 'yes you have permission'  as per my submission, i am careful not to p!ss them off.
49 minutes ago, Post and beam said:
Update:
Their response....
er, so the EHO is basically asking for a spec he knows cant be met 'I do not know of any units that have a sound power level of 50dBA or below, so it would ideally be as close to this as possible.’  Hardly helpful.
The background noise can be measured without buying the heat pump, your phone will give you a ballpark figure, remember to do it at night also.  £20 will buy you a proper-ish noise meter.  If its below 40dB(A) then LPA may argue that the PD rules (which sort of assume 40dB(A) background) are too lax for your 'quiet neighbourhood'.
If I were you I would check the precise words of the condition, they may want to influence the choice of ASHP this way, but unless the condition allows them to, then they cannot.   Also, having agreed to the principle of a HP, they cannot refuse a reasonable one (so better choose a lower noise one and be prepared to demonstrate that it is such).
If they are anything like my LPA, they want to be able to prove absolutely that they have done 'the right thing', even if it costs (me) a fortune.  Mine makes a big fuss about how levels permitted under PD are high relative to the background, and how they therefore cannot consent applications based on PD rules but must instead impose impossible to meet standards to avoid the possibility of complaints.  Yet in the past three years they have had only one noise complaint about a HP installed under PD, and it was not upheld.  So the argument is completely confected and backside covering but still nothing shifts them.
If you decide that you do have to submit something to them then reading this might help https://www.ioa.org.uk/heat-pump-briefing-notes-calculation-sheet-ioa-cieh.  On the other hand  others have suggested that the less you tell them the better, which I tend to agree with!
BTW the LPA has 8 weeks to consider and respond to the discharge of a planning condition.  If they don't then you can issue a deemed discharge notice which gives them 14 days (I think you can issue it 14 days before the 8 week period expires).  If they don't respond within that time the condition is deemed to be discharged anyway.
Edited by JamesPa
It's the normal planning bull. I had exactly the same with my ventilation system and gas boiler, they needed data sheets for everything. You give them what they want to hear, they are able to tick a box, job done. They don't examine to make sure model and make xyz is installed, it could be 5 years later when you ask for a completion cert make and model xyz may not exist then.
Don't ask questions you don't want an answer too. They have to respond the way they have.
maximum of 50dBA
That is meaningless without a distance dimension.
Not if it means what it says ie sound power level (as opposed to sound pressure level). The former is the total sound energy emitted from the unit and requires no distance.  It's the starting point for a sound pressure level calculation.
I think it probably does mean what it says because of the comment that follows.
Shouldn't answer stuff latest night, you are correct
Here is my heat pump sound data as a starter for 10.
  • 7 months later...
Conor, are you happy with it? Which one did you get?
Cooleneegy invertech 9kW. Couldn't be happier. Yet to miss a beat.
