flanagaj Posted July 13, 2023 Posted July 13, 2023 Can anyone provide any guidance as to the likelihood of being able to get planning permission for a two story extension of the property below. Basically, we are looking to infill the left hand corner to create a utility room and upstairs ensuite. The property is not in a conservation area, and the aerial view is as below. The plan would be to hopefully extend with a contemporary vertical clad based approach. Any pointers welcomed.
Alan Ambrose Posted July 13, 2023 Posted July 13, 2023 Yeah, maybe as you're not building in front of the front elevation. Depending on your LPA, you might be able to get informal advice, or just put in some simple plans for pre-app discussion. 1
joe90 Posted July 14, 2023 Posted July 14, 2023 You won’t know till you ask/apply, see if any other house in the area has done similar. 1 1
Alan Ambrose Posted July 14, 2023 Posted July 14, 2023 >>> or just put in some simple plans for pre-app discussion. Of course, if these look graphically attractive, that helps - everyone's human after all. Maybe a discussion/pre-app about the principle with the LPA with a simple plan (i.e. from above) plus 3D elevation made as an outline only shown with a white line. You can probably draw on top of Google street view images. (Not just a squiggle as above, a reasonable accurate outline.) Listen carefully, if they'll talk to you (some LPAs won't). Then if they don't hate the idea, submit a good quality render / plans taking care to observe any guidelines they give. Probably as a full application.
flanagaj Posted July 14, 2023 Author Posted July 14, 2023 2 hours ago, ETC said: Where's your boundary?
DevilDamo Posted July 14, 2023 Posted July 14, 2023 With all the properties on your road being of the same design and style, I think you’d struggle. If you were to pursue a design, get your designer to look at a crown flat top. That will still retain the barn hip ends. Also make sure the new front wall is not flush with the existing and therefore set back slightly. The front elevation wouldn’t therefore change very much. 1
Temp Posted July 14, 2023 Posted July 14, 2023 (edited) I'm afraid I think it would look horrible, especially with a flat roof. I think a single storey with pitch roof sloping from the back down to the front might just look ok but would block part of the window to your stairs. Edited July 14, 2023 by Temp
flanagaj Posted July 14, 2023 Author Posted July 14, 2023 I'd like to understand whether a planner could refuse simply because of how it would look relative to the other houses. They don't exactly look aesthetically pleasing on the eye as it is.
Temp Posted July 14, 2023 Posted July 14, 2023 (edited) Im thinking you might get PP for something like this but not sure if the dimensions work.. Perhaps a double width window instead of the single Ive shown? Edited July 14, 2023 by Temp
flanagaj Posted July 14, 2023 Author Posted July 14, 2023 6 minutes ago, Temp said: Im thinking you might get PP for something like this but not sure if the dimensions work.. Perhaps a double width window instead of the single Ive shown? It was mainly upstairs that I wanted the extension for.
ETC Posted July 14, 2023 Posted July 14, 2023 15 hours ago, joe90 said: You won’t know till you ask/apply, see if any other house in the area has done similar. Go for it. Do up a sketch and send it in. Get @Temp to do a two-storey version. His/her/their photomontage looks great.
Temp Posted July 15, 2023 Posted July 15, 2023 (edited) 12 hours ago, flanagaj said: It was mainly upstairs that I wanted the extension for. Yeah I realise that but I think a flat roof extension at the front would look horrible. And the ceiling height upstairs too low? Would have to be below existing eaves? Edited July 15, 2023 by Temp
flanagaj Posted July 15, 2023 Author Posted July 15, 2023 3 hours ago, Temp said: Yeah I realise that but I think a flat roof extension at the front would look horrible. And the ceiling height upstairs too low? Would have to be below existing eaves? And that is the issue. So not sure how it would work.
Temp Posted July 15, 2023 Posted July 15, 2023 22 minutes ago, flanagaj said: And that is the issue. So not sure how it would work. I would measure from existing floor level upstairs to the underside of your soffit. Then subtract 388 to 400mm for the following.. 150mm - upstand for flashing the flat roof to the wall. 25mm - Waterproof layer and 18mm OSB. 50mm - Ventilated air gap 150mm - PIR Insulation between rafters. 1mm - Vapour barrier 12mm - Plasterboard. Total 388mm See what that gives you. If its less than about 2.25m you might need to look at trading off headroom downstairs by lowering the first floor so there would be a step down from the bedroom into the ensuite. 1
