Help with window
Sophiae
I am sure a lot of you know me by now 🙂 so I am posting it here separately so that others may be able to contribute with their wisdom.
This is a single story detached bungalow. Planning has been approved for this side window (ground floor) which the neighbours are not happy with (understandably) and have already erected a fence opposite so to stop me from opening it. Planning office has my full plans and BCO doesn’t mind it being a boundary wall ( I only found out the legalities of things ). My neighbours won’t grant me access to my wall.
I now need help to figure out if
1. It is possible to use a T&T inward opening obscured glass window?
2. What alternatives do I have to have the room compliant for fire escape?
3. Can I move the room door so that it is facing the open space, thus opposite the exit?
4. If all fails and I use it as a play room/ office, what’s the best ventilation to use when my neighbours refuse to open the gate and allow me to access my wall?
5. Any bright ideas that won’t cost a fortune as I have already lost about £20K or more waiting to find solutions to get on with the work.
Any and all comments are truly appreciated as I am unable to sleep for the last few nights trying to find a solution so it may be used for emergency overnight stay for my son’s carers.
14 minutes ago, Bonner said:
Unless I am mistaken, it’s fine as it is. The bedroom door opens on to the hall. Even though not directly it’s still part of the hall and acceptable fire route.
So it doesn’t need a window?
Not correct. The bedroom is an inner room and will need an alternative means of escape - ie an emergency egress window.
2 hours ago, Conor said:
You still need a window for rapid ventilation. Swap it for an inward opening tilt and turn.
Correct. However if the window is within 1.0m of the boundary it won't be permitted.
2 hours ago, TonyT said:
Sure building control.
don’t think the OP has ever mentioned a building warrant in any of the threads
I do have one. I’ve had a few visits so far and the BCO is the one guiding me to be compliant. Hence why I am asking here because he is ok with the window in question.
it’s not that I don’t trust him but a few people including @ETC said it won’t be allowed even though BCO has approved it.
Forgive me if I sound confused.
1 hour ago, Sophiae said:
Hmmm. U see this is where the dilemma is. The website said within 1 meter. Doesn’t this apply?
Between 0m - 1m you can only have 1.0m2 of unprotected area - ie doors or windows. If this satisfies the ventilation requirements (1/20th of the floor area) - grand. It will satisfy EEW requirement which requires a 750mmx450mm (0.33m2) but you may come across resistance from your neighbour. The window you have shown is too big.
I can work the size up to 1m2 and my neighbours won’t be happy regardless. I am in the process of drafting a kind letter so that we are all clear.
I am so grateful to you and everyone here who contributed with an answer.
Aside/OT..
I would change the layout of the doors to the master bedroom and ensuite to eliminate that little corridor as it's a waste of space? Think there are several options but perhaps..
Edited by Temp
