Little concerned/curious over these 'hollows' I've found when digging out a foundation trench. They seem to only be close to rocks, the one nearest to camera goes deeper into the hollow. Not very deep but I've not really delved into it. This is the only place I've found them after digging around 7m length
First thoughts were an old well, as in this area it does tend to flood under heavy downpours from groundwater however also could be rat tunnels? Figured I'd share here and get some 2nd opinions
Thank you
PXL_20230629_175317255.thumb.jpg.ca90055d26c237568c3017d4896c6cb6.jpgScreenshot_20230629-190136.thumb.png.fb30b6155f953256c67d1ab639f77b94.png
Edited by garden4ork
Could it be infilled ground? A load of rocks or concrete blocks thrown in and the spaces in between never properly filled?
Think I would dig a bit deeper in those areas to see how deep they go. Be careful you don't fall down a mine shaft or old well. Tie a bowline around your waste if you go in the trench.
It's close to the ground so I'd suspect backfill, but take care and dig some more, pull out the rock and see what your left with, if it's backfill and you get ground water it may well have washed away leaving the voids in the poorly compacted backfill.
Thank you. The void backfill description does sound likely now you've said it but reading about falling down a mineshaft made me shudder a bit! Will take care...
The holes on the side  are where rocks have neen pulled out. And to the bottom they have voids beneatg.
The ground is infill which is normal enough but not suitable for a foundation.
