I am new to this forum. I have joined because we are considering the drastic sounding step of demolishing and rebuilding our house. Work will not commence for over a year, however I am putting in a lot of effort at the moment to understand the options and possibilities that we have.
The purpose of this post, probably the first of many, is to outline the overall high level plan that is evolving in my mind. It seems important to me to get these early big decisions correct as they may otherwise have a big negative impact down stream. So here is the situation.
Why are we doing this?
The house is part of an old stone built mill, next to a river. It was given a very unsympathetic conversion to 2 flats in the 1960’s. Any sign of its heritage was obliterated, it is now just a pebble dashed box.
It is on a sloping site, ground floor 1.4 meters below ground at the front, level at the back. River 17 meters away and at normal levels 2 or more meters lower. It is cold, poorly insulated, draughty and damp in places (no DPC). It is wibbly wobbly, not a lot is level and square. While it would be possibly to retrofit internally to a high standard, and at a high cost, it is subject to flooding. Just once in the 40 years we have lived there to a depth of 15cm, 13 years ago. However the way things are it will likely happen again. There is a party wall to neighbouring property, that has cellar plus 2 floors on top, so does not have the same flooding problem.
Proposed plan.
Completely demolish the house. New footings and drainage, then block walls to 2 meters above current ground floor. 2 story timber frame house erected on this base. New house to be say 1.5 meters from the existing party wall, so fully detached. First floor I beams with insulation in between, possibly factory made floor cassettes. I see no point in a concrete beam floor as that will need insulation on top and would increase the overall height of the house. Metal web joists would introduce a lot of thermal bridging in the thermal envelope. House constructed of factory made and insulated SIPS. Second floor web joists to facilitate distribution of services and MVHR ducting. Vaulted ceiling on second floor. Overall height cellar plus perhaps 1.75 storeys.
There would be a high standard of insulation and air tightness, possibly to passivhus standard. All modern technology to be included, ASHP to UFH, MVHR, 3G windows, PV on the roof, possibly battery storage etc.
External cladding to be part render and part natural local stone to fit in locally, there should be plenty available from the demolition
Cellar to be designed to be flood resistant, allowing water to flow in and out in the event of a flood. Cellar part open to the garden to provide a cool shady patio type room with garden type furniture and basic services, water, electricity at ceiling level etc.
Any comments on this overall high level plan appreciated. Especially anything that might prevent me saying when all is complete “If only I had known then what I know now, I would have done X and Y instead”
No need to dive into the details of anything specific right now, no doubt I will post on specific topics when I am working on them and need advice.
Do it. Renovating is right PITA and it's so much harder to end up with the same performance finished product. You will also save the VAT with new build
I wonder if you could rebuild with a modern house well insulated and airtight but with a nod back to the original stone mill? just coz someone f****d up the heritage doesn't mean you can't dredge up old photos and reimagine the old mill with a modern twist?
might cost a lot in architect's fees though! 🤦‍♂️
That's the trouble with Mills.
Why does it flood? Is the mill stream not controllable?.
My inclination is to keep the founds and some walling, and rebuild above.
Regain some heritage and save lots of money.
I wouldn't want to be digging new founds next to a river.
No mill stream ,everything removed in the '60s. It is just a pebble dashed boxy house 17 meters from a river at the bottom of the garden.
My original idea was to partially demolish, put a ring beam on top, then a TF on that. However such an approach would not qualify for zero VAT, so it would actually cost a lot more. Believe me there is no heritage to be seen or saved, well apart from a few old mill wheels as garden ornaments, and they will be staying.
Edited by Norbert
The original stone mill is a lot more than a nod away as it is. We will just be aiming for a modern house well insulated and airtight, but with a nod to all the other local houses that are a mixture of local stone a white render
I think you need to remove the foundations to save the vat with a new build
Agreed, that is the plan
OK.  Spend say £80,000 on demo and new founds and water conrol.
Get how much back in VAT?
20% of £300,000?
Utter guesses of course.
Sometimes we get obsessed (me incl)  on beating thr system.
No for zero VAT you just need to level the site to ground level, anything below ground (Inc founds and basements) can remain.
Aiui.
16 hours ago, TonyT said:
Get an asbestos survey carried out
And a PRA bat survey. I think your planners may want it but check. I couldn't apply for planning until this was done. If they find anything you could be in for a long wait. Sad but true.
Bat survey already scheduled for August. Had a new roof on 12 years ago, we did have bats so had to do it in the winter as it was a summer roost. Bat slates were put in so expecting a positive. However starting demolotion in winter/early spring fits OK, and happy to incorporate new bat accommodation in the build.
You had more luck than me. It looks like now I am in to my second season of bat surveys due to one lying, scheming, developer hating ecologist.
Aiui.
correct. unless HMRC now have below ground footings inspectors with X-ray vision.
