SteamyTea Posted August 10, 2017 Share Posted August 10, 2017 http://www.telegraph.co.uk/property/luxury/10ft-wide-skinny-house-worth-27m-wins-planning-approval-london/ Seriously, what bother. Link to comment Share on other sites More sharing options...
ragg987 Posted August 10, 2017 Share Posted August 10, 2017 I like it - quirky and makes use of the space quite well. We are used to larger old houses in the UK, but in cities like Barcelona and Madrid a small new apartment is the norm. Would I live in it? No way could I afford it, and even if I could doubt I would like to live on a busy road like this... Link to comment Share on other sites More sharing options...
ToughButterCup Posted August 10, 2017 Share Posted August 10, 2017 The house next to ours is one door and one window wide at the front, and a narrow door wide at the back. Link to comment Share on other sites More sharing options...
Temp Posted August 10, 2017 Share Posted August 10, 2017 Apparently it's being built for Jodie Whittaker. Link to comment Share on other sites More sharing options...
SteamyTea Posted August 10, 2017 Author Share Posted August 10, 2017 2 minutes ago, Temp said: Jodie Whittaker (had to look her up) Link to comment Share on other sites More sharing options...
ProDave Posted August 10, 2017 Share Posted August 10, 2017 That's not especially small. My first house 1 bedroom starter home rabbit hutch, was only 12ft wide. They build a whole estate nearly 100 houses like that. The 2 bedroom ones were just as narrow, just a bit deeper. But on a practical note. Looking at the picture, the left hand property appears to have windows overlooking the alleyway. Can you just block up someone's windows without their permission? I like the split level layout that in effect makes the whole middle of the house a stairwell. 1 Link to comment Share on other sites More sharing options...
craig Posted August 10, 2017 Share Posted August 10, 2017 (edited) 14 minutes ago, ProDave said: But on a practical note. Looking at the picture, the left hand property appears to have windows overlooking the alleyway. Can you just block up someone's windows without their permission? The ground level expands out to the back but doesn't impact the windows above. The windows at the front side are bricked up, the windows further back are not going to be impacted by the building so won't be bricked up. However, the light etc. to those windows will certainly be impacted. Edited August 10, 2017 by craig Link to comment Share on other sites More sharing options...
Temp Posted August 12, 2017 Share Posted August 12, 2017 I believe you can indeed totally block a neighbours window provided it hasn't acquired a Right to Light under the Act with similar name. Link to comment Share on other sites More sharing options...
Ferdinand Posted August 12, 2017 Share Posted August 12, 2017 (edited) On 10/08/2017 at 17:00, craig said: The ground level expands out to the back but doesn't impact the windows above. The windows at the front side are bricked up, the windows further back are not going to be impacted by the building so won't be bricked up. However, the light etc. to those windows will certainly be impacted. I think they are false windows. A common trick in London. F Edited August 12, 2017 by Ferdinand Link to comment Share on other sites More sharing options...
