johnhenstock83 Posted April 3, 2023 Posted April 3, 2023 the eternal question: to lay flooring (engineered wood) under kitchen cabinets or not? we've started planning the new kitchen and we're looking at 6.5m worth of units + an island (2m long). what is the general consensus on whether flooring should or shouldn't be installed under units? it could save a bit of time/money, but are there any disadvantages?
Bonner Posted April 3, 2023 Posted April 3, 2023 Not for me, waste of floor covering. If you were tiling however, it would need to continue under the island to ensure correct levels and joints.
Bozza Posted April 3, 2023 Posted April 3, 2023 The only scenario that I can see to justify flooring under units would be if you were to change your kitchen & layout in future, and keep the flooring. I’m not sure that is realistically very likely to ever happen though TBH in practice. Normally replacing a kitchen involves new flooring for design reasons of course. I would however advocate taking the flooring under where you have appliances eg dishwasher or washing machine. Makes it easier to get in and out, and if there is a leak it’s less likely to pool inside what would be otherwise a hidden trough. So my default is to not floor under units unless there is a technical reason to do so as has already been indicated.
Andeh Posted April 4, 2023 Posted April 4, 2023 Echo the above, we are tiling where appliances will go, but not elsewhere under units. There is no other way of changing the kitchen layout design, so am easy £300 odd saved!
saveasteading Posted April 4, 2023 Posted April 4, 2023 I now always continue flooring under units. Getting an appliance in or out is very tricky with a step, and there is increased risk of the worktop being low. Also, a dishwasher' feet might not slide on a plain concrete surface. The material could be changed to save cost. Another option might be to surface only where an appliance will go. What if I replace or reform the kitchen and expose some floor? Only you can answer the chances of that. 1
markc Posted April 4, 2023 Posted April 4, 2023 Def no step, as above it makes access to appliances a real pain. If laying a floating floor (laminate, solid or engineered) either lay the entire floor or lay it after the kitchen fit. If only the front support legs land on the floating floor it often causes the underlay to compress and ‘domes’ in the centre. Run a floating floor right up to the support legs (not forgetting expansion gap) and under any appliances 1
johnhenstock83 Posted April 4, 2023 Author Posted April 4, 2023 So from what yoh all said, unless appliances sit directly on the floor, there’s not much reason for it. that’s good bews, as the dishwasher is built in and the washing machines are in the utility room, which is tiled 100%. thanks all
ProDave Posted April 4, 2023 Posted April 4, 2023 3 minutes ago, johnhenstock83 said: that’s good bews, as the dishwasher is built in Most built in dishwashers sit on the floor like any other so you want the flooring to continue under them.
