Looking at some of the quotes we have had so far to design, supply and install ASHP and tanks to meet our requirements I'm rapidly coming to the conclusion they are all conmen. The figures I've been quoted range from £15k for an 8kw unit and tank (material cost £4k from city plumbing) to £35k for a 16kw and 2 tanks (material cost £8.5k from city plumbing).
The plumber who have used for the last 3 builds i am very happy with, excellent quality of work, price and reliability. He is gas safe but hasn't crossed the void to ASHP installs. I am happy to be his guinea pig and have offered to buy the kit needed to install (gas ?). In return he has said he will fit at cost, day rate. with a cap of a weeks work which I am very happy with as its a win win for both of us.
What kit is needed to gas up the new (R32?) units and what about manufacturer warranty ?
If it's a monobloc then it comes gassed up.  Only splits need gassing.
Manufacturers mostly seem to specify that the unit must be installed by one of their certified installers to get an extended warranty (>2-3 yrs) but this does differ from manufacturer to manufacturer.
Edited by JamesPa
Clarify
as said monbloc is pre gassed. You really would only use a monbloc ASHP, that keeps all the noisy stuff outside.
You need the ASHP
Flexible hoses
3 way diverter valve
cylinder with 3m2 or bigger coil
Heating system - this needs to be designed to run as low a temperature practical, so ideal is UFH. But big rads can work.
If you have loads of zones you need a buffer or volumiser.
No real difference to a system boiler.
Just need to make sure ASHP isn't oversized to much and flow temps are low. Oversize the cylinder as it stores at a lower temp.
Sounds as though you have a relationship to treasure with this plumber.
Maybe if instead of buying the F-Gas kit you helped with the training e.g. pay the course fee or travel or accomodation he would be williing to put in his own time to take the chosen manufacturer's course, then in addition to all the above you get the extra warranty and he gets a new skillset. So win win win win.
Why do you need such a kit? You are not touching refrigerant gas - or shouldn't be?
Not me. OP's plumber, see OP above.
As @JamesPa said he will not need it unless it is a split HP, hence my alternative suggestion.
Edited by sharpener
As per the OP figures, i have been quoted £21k ( excluding the £5k cash back) for a Nibe 11 kw by Nu-heat.  and not much less for a Grant from 2 different suppliers.
 As it happens i spoke to a guy at the NEC show last weekend on the NIBE stand. I told him i wanted to buy his products but would not pay £21k ish. When he asked who the quote was from he just gave me a very knowing smile. He then said he would get me a quote from someone else from their suppliers list.
Similar prices here.  £15-20K before the 5K BUS.  No wonder BUS is not getting much take up.
Not sure how this farce ends to be honest.  Maybe Octopus will succeed in busting the cowboy's business model, but I doubt that they have the volume to do it alone.  The fundamental problem is, I think, the requirement for MCS both for BUS (which is just about understandable) and for permitted development (which is scandalous).  MCS expressly forbids separating the contracts for design and installation, otherwise it would be straightforward for a customer to 'buy' a design from someone who specialises just in design and get their favoured plumber to quote (ie the same model as architects/builders).
Its almost like MCS and the rules around heat pumps are sponsored by the manufacturers of gas boilers!
I have done a few now, plumbing and wiring for my own, wiring only for a few others in conjunction with a plumber.  I really don't know what installers are frightened of?  From a blumbers point of view it is usually just like a system boiler and HW tank.  It can be a little more complicated for the electrician as every one is different, which just means you have to read the manual and do what it says.
2 days each trade should do it normally.
I suspect the issue is your standard plumber and electrician won't know how to size one.  Easy on a new build house where you have had a full SAP design done giving you the heating requirement.
I do agree it is time the over priced MCS cartel is shown for what it is and their near monopoly broken.  The worst part is the government BUS grant is not benefitting the customer, but lining the pockets of the over priced installers.
If you have a plumber and electrician willing to install it then just do it.
I suspect that's spot on, hence my lament that it's not possible, within the MCS stranglehold, for the customer to separately contract design and installation.
Can't see any prospect of change though.  The advisors to govt will likely be mostly MCS and boiler manufacturers, both of which have a vested interest in the status quo.
+1
My experience is designing/installing for cooling is the hardest part, not intrinsically difficult just unfamiliar to any UK plumber.
But MCS doesn't even train for cooling (still sticks to the it's-not-legal mantra) so complete waste.
Has anyone ever met a https://www.flexi-orb.com/ certified installer??
