Post and beam Posted March 15, 2023 Posted March 15, 2023 The wooden workshop/garage that i am having built might one day get used to put a car into, radical i know. Its primary use will be for tinkering about so i will probably insulate under the floor, just like the house. Does anyone know if a 50mm screed onto PIR would support a car? Or do i need more or something different. Thanks in advance
Post and beam Posted March 15, 2023 Author Posted March 15, 2023 Well, old Merc's were built like tanks
joe90 Posted March 15, 2023 Posted March 15, 2023 Also what about point loads (jacking a car up etc) personally I would want 100mm (but I do tend to over engineer things). Steel or Β fibres would help I guess).
Nickfromwales Posted March 15, 2023 Posted March 15, 2023 Very expensive to do twice.Β Iβd put 100mm down, impregnated with steel fibres. Not a huge difference in cost, but a huge difference for the end result. 1
Pocster Posted March 15, 2023 Posted March 15, 2023 For my underground build with parking above this was tricky ( specifically the insulation ) . Think I did 150mm screed with rebar . This sat on vac insulation which in turn sat on 200mm concrete and rebar .
Big Jimbo Posted March 15, 2023 Posted March 15, 2023 11 minutes ago, pocster said: For my underground build with parking above this was tricky ( specifically the insulation ) . Think I did 150mm screed with rebar . This sat on vac insulation which in turn sat on 200mm concrete and rebar . All round to yours when the nukes start falling then. 1 2
Pocster Posted March 15, 2023 Posted March 15, 2023 3 minutes ago, Big Jimbo said: All round to yours when the nukes start falling then. All part of my mega plan . Human race destroyed . I then rise out my bunker to dominate the rather empty world with my presence . 1
Onoff Posted March 15, 2023 Posted March 15, 2023 4 minutes ago, Big Jimbo said: All round to yours when the nukes start falling then. Β Morlocks/Eloi π¬
Big Jimbo Posted March 15, 2023 Posted March 15, 2023 Just now, pocster said: All part of my mega plan . Human race destroyed . I then rise out my bunker to dominate the rather empty world with my presence . You need to offer shelter to several fit, young, good looking females. Otherwise, it will be a very dull new world for you. 1
PeterW Posted March 15, 2023 Posted March 15, 2023 3 hours ago, Post and beam said: Does anyone know if a 50mm screed onto PIR would support a car? Point load will be your issue when the slab becomes a beam and bending occurs. 50mm is very strong however I would go 100mm and then chuck fibres in (steel or fibreglass will do) and it wonβt go anywhere.Β 2
Pocster Posted March 15, 2023 Posted March 15, 2023 1 hour ago, Big Jimbo said: You need to offer shelter to several fit, young, good looking females. Otherwise, it will be a very dull new world for you. Yes . I do need to populate my new world at some speed β¦.. First up Nigella , she has two uses ; one is cooking . Then KylieΒ Β then β¦.. ( long list ) 1
SteamyTea Posted March 15, 2023 Posted March 15, 2023 3 hours ago, pocster said: Yes . I do need to populate my new world at some speed β¦.. First up Nigella , she has two uses ; one is cooking . Then KylieΒ Β then β¦.. ( long list ) Am I allowed to mention how fertility drops off as women get older. Gary Glitter is back inside, so the dark web is all yours.
Pocster Posted March 15, 2023 Posted March 15, 2023 3 minutes ago, SteamyTea said: Am I allowed to mention how fertility drops off as women get older. Gary Glitter is back inside, so the dark web is all yours. Excuse me ! You wonβt be around for my global conquest . So eat your pasty , look at the sea , and then (expletive deleted) offΒ 2
Pocster Posted March 15, 2023 Posted March 15, 2023 5 minutes ago, SteamyTea said: Am I allowed to mention how fertility drops off as women get older. So I try more often ? ππππππππππππππππ
Onoff Posted March 15, 2023 Posted March 15, 2023 17 minutes ago, SteamyTea said: Am I allowed to mention how fertility drops off as women get older. Β Tbf everything gets lower.
Pocster Posted March 15, 2023 Posted March 15, 2023 1 minute ago, Onoff said: Β Tbf everything gets lower. Standards ?
