The wooden workshop/garage that i am having built might one day get used to put a car into, radical i know.
Its primary use will be for tinkering about so i will probably insulate under the floor, just like the house.
Does anyone know if a 50mm screed onto PIR would support a car? Or do i need more or something different.
Thanks in advance
Also what about point loads (jacking a car up etc) personally I would want 100mm (but I do tend to over engineer things). Steel or  fibres would help I guess).
For my underground build with parking above this was tricky ( specifically the insulation ) .
Think I did 150mm screed with rebar . This sat on vac insulation which in turn sat on 200mm concrete and rebar .
All round to yours when the nukes start falling then.
  • Haha 2
All part of my mega plan . Human race destroyed . I then rise out my bunker to dominate the rather empty world with my presence .
You need to offer shelter to several fit, young, good looking females. Otherwise, it will be a very dull new world for you.
Point load will be your issue when the slab becomes a beam and bending occurs. 50mm is very strong however I would go 100mm and then chuck fibres in (steel or fibreglass will do) and it won’t go anywhere.
  • Like 2
Yes . I do need to populate my new world at some speed …..
First up Nigella , she has two uses ; one is cooking .
Then Kylie
then ….. ( long list )
Then Kylie
Am I allowed to mention how fertility drops off as women get older.
Gary Glitter is back inside, so the dark web is all yours.
Excuse me ! You won’t be around for my global conquest . So eat your pasty , look at the sea , and then (expletive deleted) off
  • Haha 2
So I try more often ? 👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍🙄
Tbf everything gets lower.
