steveoelliott Posted February 8, 2023 Posted February 8, 2023 Hi, Many of my windows have had silicone sealant applied around the inside in the past and having recently asked a decorator to quote for a job, I asked if he could cut out and renew the sealant as it was looking old and tired. He said they use caulk as opposed to silicone and explained that he isn't able to get a great finish with silicone. The challenge with caulk is, I have had this applied to windows elsewhere and whilst it looks good at first, in time it inevitably cracks and looks nasty as opposed to silicone that has more "stretch to it!" Thanks.
Russell griffiths Posted February 8, 2023 Posted February 8, 2023 You cannot paint over silicon, you can with caulk. Does it need to be painted ? can you get it cut out and decorated, then silicon over the top as a neat finish. Or use a hybrid pu adhesive which is flexible and can be painted. 2
Carrerahill Posted February 8, 2023 Posted February 8, 2023 (edited) 31 minutes ago, steveoelliott said: Hi, Many of my windows have had silicone sealant applied around the inside in the past and having recently asked a decorator to quote for a job, I asked if he could cut out and renew the sealant as it was looking old and tired. He said they use caulk as opposed to silicone and explained that he isn't able to get a great finish with silicone. The challenge with caulk is, I have had this applied to windows elsewhere and whilst it looks good at first, in time it inevitably cracks and looks nasty as opposed to silicone that has more "stretch to it!" Thanks. +1 on above. Ask him to use polyurethene sealant. Better than silicone in many ways and over paintable. Edited February 8, 2023 by Carrerahill 1
Bozza Posted February 8, 2023 Posted February 8, 2023 My painter told me only to ever use acrylic caulk, to prevent cracking. I tend to listen to pros advice.
Nickfromwales Posted February 8, 2023 Posted February 8, 2023 1 hour ago, Bozza said: My painter told me only to ever use acrylic caulk, to prevent cracking. I tend to listen to pros advice. No good around a door which gets slammed / there's movement around the perimeter of. 1
Radian Posted February 8, 2023 Posted February 8, 2023 Everbuild Puraflex 40 is an example of a hybrid polyurethane sealant which has a lot of stretch and is paintable. There are also products known as Modified Silicone that have the benefits of both systems. i.e. paintable, workable and stretchable. Soudal Fixall and Everbuild Stixall are two examples. I would advise anyone to grab a few different types and test them out to see which you're most happy with. 1
MikeGrahamT21 Posted February 8, 2023 Posted February 8, 2023 (edited) I’ve tried so many different things over the years, started with caulk, then siliconised caulk, moved onto Everbuilds 25LM, and just recently I’ve had to do them yet again, this time I opted for CT1, time will tell! It best bloody work at £14 a tube! it certainly seems to have stuck well. before you apply, lightly sand both surfaces, the wall and the frame, clean it with alcohol wipes and don’t stick your mitts in the silicone to smooth it out, a concave finish will always have weak points, get a proper tool to create a wedge shape Edited February 8, 2023 by MikeGrahamT21 1
steveoelliott Posted February 9, 2023 Author Posted February 9, 2023 Thanks all... I've been told the HB42 Caulk is supposed to be super flexible,
Carrerahill Posted February 9, 2023 Posted February 9, 2023 15 hours ago, Bozza said: My painter told me only to ever use acrylic caulk, to prevent cracking. I tend to listen to pros advice. Latex/acrylic caulk is the very stuff that is prone to cracking and shrinkage. OK for caulking when used properly, i.e. a deep fill without half of it removed with your finger leaving a thin bead. If you want to seal things and overpaint then a PU sealant is critical. 1
Radian Posted February 9, 2023 Posted February 9, 2023 56 minutes ago, steveoelliott said: Thanks all... I've been told the HB42 Caulk is supposed to be super flexible, £2 a tube should be telling you something when the others mentioned here go up to £14! 3
steveoelliott Posted February 9, 2023 Author Posted February 9, 2023 28 minutes ago, Radian said: £2 a tube should be telling you something when the others mentioned here go up to £14! I get your point but irrespective of price it has some good write ups. Ultimately it's not really a price dependent decision.
Radian Posted February 9, 2023 Posted February 9, 2023 1 minute ago, steveoelliott said: I get your point but irrespective of price it has some good write ups. Ultimately it's not really a price dependent decision. Are those reviews relating how long the acrylic lasts for? Usually people don't come back with that kind of review a couple of years down the line. When I go to all the trouble of prepping, I want the job to last!
steveoelliott Posted February 9, 2023 Author Posted February 9, 2023 11 minutes ago, Radian said: Are those reviews relating how long the acrylic lasts for? Usually people don't come back with that kind of review a couple of years down the line. When I go to all the trouble of prepping, I want the job to last! I get it... So for you, Everbuild Puraflex 40 is the choice?
Bozza Posted February 9, 2023 Posted February 9, 2023 2 hours ago, Carrerahill said: Latex/acrylic caulk is the very stuff that is prone to cracking and shrinkage. OK for caulking when used properly, i.e. a deep fill without half of it removed with your finger leaving a thin bead. If you want to seal things and overpaint then a PU sealant is critical. You may well be 100% correct, I’m merely repeating what my decorator told me. Relating to my 2 year old new build timber frame, that has no decorative cracks, when I expected there would be, and surprised when there wasn’t. I remember asking him why pops but no cracks when he was snagging after a year, he said because he uses acrylic caulk. May not relate to every decorative scenario of course.
