LPG Generators
Hello clever people,
We have a large supply of LPG and a relatively inconsistent mains power supply.
lightbulb moment - get an LPG generator to keep the lights/heating going when the power dies go down.
Any recommendations to size/brand or how to calculate efficiency etc? Thinking about spending £500-800ish. Is this way under what’s needed budget wise?
Can it easily enough be wired into the house circuit? We’ll be having a new ‘fuse board’ (or whatever they’re called) so hopefully this can be done at the same time?
thanks for any tips or tricks!!
A while ago I was thinking about an LPG generator, for heating and lighting only, for when we have power cuts. Honda make small dual fuel generators that would be suitable. I was going to have a seperate circuit just for the heating.
https://www.geargb.co.uk/search/LPG-Dual-Fuel-Generator
Trouble with small you can't put the kettle on.
We got one of these for £800 (now £1000)
P1PE 7.9kW / 9.8kVA* Recoil and Electric Start Site Petrol Generator (Powered by Hyundai).
One these to switch mains over to generator £38.
https://www.amazon.co.uk/gp/r.html?C=2X8R0PK3LTH9J&K=34MIE1U6GOBVK&M=urn:rtn:msg:20220215092805432dc27e9784454aaa817bf54550p0eu&R=3L1EKYM8H7V8M&T=C&U=https%3A%2F%2Fwww.amazon.co.uk%2Fdp%2FB079Y3PJN8%2Fref%3Dpe_27063361_487055811_TE_3p_dp_1&H=F0W7TJ2VHJTNC41TRU0YCSGUQ4SA&ref_=pe_27063361_487055811_TE_3p_dp_1
You would just need an LPG conversation kit.
Not always as simple as that. LPG (and combustion bi products) is very corrosive.
So care has to be taken with choice of which motor, induction and exhaust, is used.
Edited by SteamyTea
So what is your heating? LPG? If so you will only need a generator to run that and some lighting etc I guess. If your heating is electric then £££££. You need to calculate what you want powered and the kW you need during power outages and get your fuse board wired so only “required during power outage” is connected to the genny via change over devise. I did consider it for my build to run lighting only but never got round to it (and frankly our supply is pretty good).
@joe90 yup, heating LPG. So enough power for the boiler (guess 110w) UFH pump (60w). Plus a few lights totalling 150w max I guess. If we could also run Wi-Fi (6w per node, 30w total) and a TV (350w) that’d be awesome but only a nice to have. On that note, does fibre to the property work in power cuts? We have a 4G backup dongle just in case, but be good to know!
Does a total of 700w sound about right or have I missed something major?!? Seems a little low to me…?
*apologies if I’ve got my units wrong. Not sure if it should be w or W!
Edited by CotswoldDoItUpper
