Ok, so I put a foot onto our screed too early and it left a depression.
Underfloor heating mats and laminate tiles are meant to go over it another day.
is it f*cked? What can I do? Or can there be a self leveller applied or something??
Edited by zaarin_2003
1 minute ago, nod said:
Your tiler will fill it with adhesive as he goes
Your not the first
Laminate is usually laid as a floating floor?  I guess you could first use some tile adhesive as a levelling compound.
Footprints sometimes raise the surrounding material. That's harder to deal with than the hollow. If not too late wack or scrape any raised area back down.
If there isn't a cat, dog and bird print (the Big Three) then it isn't a proper floor.
The point about the adjacent area being high is good. The material has moved from the imprint sideways and up, so put a straight edge on it.
If high, grind down with a carborundum stone if posh, or a brick, the sooner the easier.
Then I would fill anything more than 3mm deep before the tiling. This gives it time to shrink and cure. Tile adhesive as good as anything, and really sticks, so the tiler could do it first.
I'm convinced that non-shrink adhesive does shrink, hence doing it early.
A photo of the footprint would be rather good for your ID.
Thanks. I had a flat piece of wood which I ran over the depression and it seemed pretty flush to the surrounding area, so I think it’s flat. If it has raised up at all it’s not noticeable to the naked eye. So I’m hoping it won’t be an issue. The centre of the depression should be able to be filled with adhesive or something, right?
16 hours ago, zaarin_2003 said:
filled
Right.  If 3mm or less, say, then adhesive as you tile. More than that, up to 10mm filll with adhesive first and let it harden. Easy either way.
Over 10mm, let's see the photo please.
