Pocster Posted November 18, 2022 Posted November 18, 2022 Lane entrance to our house is pitch black at night . Whilst I could put a pir light up I’m not keen on helping the neighbors. Quite happy for them to fall on a dark winters evening and their corpse laying rotting in the bleakness . Anyway ( and more importantly ) SWMBO finds it too dark ! So I was thinking of a method to identify swmbo ( presumably based on her having her phone on her ) . Doesnt need to be accurate - but work reliably . Anyone tried any geo fence type technology ? . The lane is too far from my router ( so can’t use that as a recognised connection point ) . Some kind of basic sensor embedded in the wall in the lane ?? Ideas welcome ! ( I love doing things like this ! )
SteamyTea Posted November 18, 2022 Posted November 18, 2022 1 minute ago, pocster said: The lane is too far from my router Why not put another router down there that detects her phone when she sneaks in late at night. I think Wireshark can detect them.
Kelvin Posted November 18, 2022 Posted November 18, 2022 (edited) I would try and figure out a way of using PIR to switch the light on without it being activated by anyone else or buy her a head torch as suggested above Edited November 18, 2022 by Kelvin
SteamyTea Posted November 18, 2022 Posted November 18, 2022 12 minutes ago, Kelvin said: head torch as suggested above Or remove the blindfold.
Pocster Posted November 18, 2022 Author Posted November 18, 2022 (edited) 1 hour ago, ProDave said: Buy SWMBO a head torch. You are making the assumption SWMBO will take the head torch with her !! 🙄 Also that’s too easy a solution Edited November 18, 2022 by pocster
Pocster Posted November 18, 2022 Author Posted November 18, 2022 (edited) I’m tempted to go down the route of adding an ASUS mesh hub outside ( in a plastic box ) . Fairly confident then that I can detect a device connected to my WiFi . Will somehow need to know when SWMBO has entered the property to turn the light off . As I have an ASUS mesh at least for now I can experiment. Feels a bit overkill though multiple Ssids ? Edited November 18, 2022 by pocster
Radian Posted November 18, 2022 Posted November 18, 2022 And the ESP32 BLE beacon detector is discounted because?
elite Posted November 18, 2022 Posted November 18, 2022 An app installed on her phone that will do geofencing (https://owntracks.org/ maybe?), then turn off x seconds after she joins wifi Re mesh, I'm on unifi here and can see which AP a device is connected to, assume that is possible on ASUS? 1
Pocster Posted November 18, 2022 Author Posted November 18, 2022 12 minutes ago, elite said: Re mesh, I'm on unifi here and can see which AP a device is connected to, assume that is possible on ASUS? I think so . The issue then is getting the HA too see it .
Radian Posted November 18, 2022 Posted November 18, 2022 7 minutes ago, pocster said: I think so . The issue then is getting the HA too see it . https://www.home-assistant.io/integrations/mqtt_room/ https://www.jamesridgway.co.uk/better-presence-detection-with-home-assistant-and-espresense/ Duh.
elite Posted November 18, 2022 Posted November 18, 2022 https://www.juanmtech.com/location-tracking-with-owntracks-http-mode-and-home-assistant/ 1
ProDave Posted November 18, 2022 Posted November 18, 2022 1 hour ago, pocster said: You are making the assumption SWMBO will take the head torch with her !! 🙄 Also that’s too easy a solution Does her phone not have a built in torch? 2
Radian Posted November 18, 2022 Posted November 18, 2022 Bet she's got an iphone. Pity. Quote OwnTracks on Android runs in the background, all the time, whereas on iOS it is "killed off" by the operating system and woken up every several hundred seconds, in which it gets a teeny tiny time slot to do its thing. Still reading though. Things may look up.
SteamyTea Posted November 18, 2022 Posted November 18, 2022 1 hour ago, pocster said: You are making the assumption SWMBO will take the head torch with her She can swap it for this 1
Pocster Posted November 18, 2022 Author Posted November 18, 2022 28 minutes ago, ProDave said: Does her phone not have a built in torch? Of course it does ! We need something SWMBO proof I.e it requires no action on her part
Pocster Posted November 18, 2022 Author Posted November 18, 2022 15 minutes ago, SteamyTea said: She can swap it for this You can keep the gag ; but I’ll certainly take the girl
SteamyTea Posted November 18, 2022 Posted November 18, 2022 6 minutes ago, pocster said: You can keep the gag ; but I’ll certainly take the girl She has a mouth like a sewer, and a Yorkshire accent.
Kelvin Posted November 18, 2022 Posted November 18, 2022 My experience of my SWMBO is that any automation needs to work 100% of the time with zero interaction from the user with no obvious fiddling from the on-site IT support. Anything less than this and it’s ‘what’s wrong with a switch’ Plus she has a head torch already so I don’t have this problem 😂 1
joe90 Posted November 18, 2022 Posted November 18, 2022 Everyone here knows I hate tech (unlike @pocster) so I would use a pir outside light, yes I know Pocster hates his neighbours but is it worth it ? it would be nice to illuminate anyone that might visit (presuming he has any friends 🤷♂️). 1
Pocster Posted November 18, 2022 Author Posted November 18, 2022 39 minutes ago, SteamyTea said: She has a mouth like a sewer, and a Yorkshire accent. Perfect
Pocster Posted November 18, 2022 Author Posted November 18, 2022 39 minutes ago, Kelvin said: My experience of my SWMBO is that any automation needs to work 100% of the time with zero interaction from the user with no obvious fiddling from the on-site IT support. Anything less than this and it’s ‘what’s wrong with a switch’ Plus she has a head torch already so I don’t have this problem 😂 Mines the same . 99% HA is not good enough . As we know 100% is impossible.
Pocster Posted November 18, 2022 Author Posted November 18, 2022 33 minutes ago, joe90 said: Everyone here knows I hate tech (unlike @pocster) so I would use a pir outside light, yes I know Pocster hates his neighbours but is it worth it ? it would be nice to illuminate anyone that might visit (presuming he has any friends 🤷♂️). You’re the only one that visits . You just want a pir light so you don’t fall and break your neck . Oh yes ( as you can imagine ) (expletive deleted) the neighbors 1
Radian Posted November 18, 2022 Posted November 18, 2022 6 minutes ago, pocster said: You’re the only one that visits . If you don't get off your lazy @rse and code something up on a microcontroller, I'm going to have to come up to Bristol and do it for you. 1
