Can’t find anything obvious online .
Can it go straight back to the CU ? . Need a fused spur in the wc room or outside ?
Don’t want bco pulling a face …. ( not that they’ll ever visit but just in case )
Fused spur outlet in the room with the WC is fine if it is just a WC. If there is a bath or shower in there, different rules apply.
  • Like 2
Just a wc and sink - thanks
Presume the fused spur can be up the wall high I.e out of harms way ( but reachable of course )
Edited by pocster
if all the circumstances line up as a worst case including too much vindaloo it needs to be resilient to an aerosol of high speed, liquidised, flying poo.
(Warning: football song incoming)
If that does occur a photo will be posted up here asap !!
No low down, the only couple I have seen come with a relatively short fitted flex.  I never investigated if you could change it.
1 hour ago, PeterW said:
Just use an extension lead so you’ve got the flexibility to pull it out when it goes wrong ….
Or you get fed up with the noise 🤷‍♂️
Best place to put them is the basement then..
Assuming you are not in the basement yourself.
Just now, Ferdinand said:
Best place to put them is the basement.
Most of @pocster,s house is a basement.
  • Haha 2
