Going to sound like I'm super tight but rather than replace a pair of worn rising butts, can you simply add a couple of washers over the hinge shafts?
On Off. You are right. You do sound like a tight old git.
1 hour ago, ProDave said:
Christ, how much have they worn?  I doubt you will need more than one surely?
It's just the crappy bog door catch in the upstairs ensuite won't slide into its hole. It's either the hinges worn a fraction or the timber frame of the dormer shifted! 😂
Just shift the catchplate !🤷‍♂️
Yes. Usually they need an edge cut off though, if the spindle is close the the frame.
This is the easiest solution if the door is catching the floor.
46 minutes ago, pocster said:
Think you should see a GP
Christ it's like summoning Beetlejuice. The mere mention of a tight butt and he appears 😱
  • Haha 2
