Alternative broadband supplier questions
I am on the verge of signing up with this new wireless ISP, but they dropped this into the discussion:
"CFWN normally supply a Dual band router (ACB-AC) as standard for installs, however due to the ongoing global equipment shortages these are currently unavailable and and we are unable to even obtain an estimate for availability. Therefore, we propose to provide you with an alternative an ACB-ISP. This router is only single band (2GHz) but will provide your basic needs for internet connectivity and allow us to proceed with your installation"
Just checking my present BT dual band router, I find it has currently got 6 devices connected to it's 2.4GHz wifi and 4 connected to the 5GHz wifi.  Not all of these are in use, e.g an old out of contract phone used occasionally to stream music, my old Ubuntu PC turned on once in a blue moon.  Would that many devices connect and work with the 2GHz only router?
That description sounds like this Ubiquiti airCube airMAX (the codes match if you google them one is 2.4 and the other is 5) If that’s the case it’s not a router it’s an access point that will be connected to whichever box they use to connect to their network. If that’s the case you could buy a different access point that has both frequencies. Worth asking them at least.
As far as your question goes (will it make much difference) Probably none that you will notice.
Edited by Kelvin
Well we bit the bullet and our CFWN broadband was installed yesterday.  We now get a blistering * 45 MBPS download and 20MBPS upload.
As well as being faster, it seems more reliable, by that I mean I have had the Pi Music Box quietly streaming Radio Caroline for nearly 24 hours now without a single drop put.  Previously it used to stop and start a lot, particularly early evening.
There was a little "confusion" with how to cancel the old BT service.  The advice from the new provider was cancel your broadband and keep your landline, and when you are ready to migrate the LL to VOIP let us knw and we will transfer it.  So I phoned BT yesterday.  "Yes sir you can cancel your broadband, but to keep the landline that will enter a new 12 month contract"  and it appeared when you left you still had to pay the remainder of the 12 month contract.  I argued and got nowhere, so I ended the call without cancelling anything.
Another call to the new provider and you could hear the lady on the phone sigh, BT up to their dirty tricks again.  So the result Is I have signed the forms for the VOIP transfer and just received an email from BT the landline transfers on the 15th October and on that day both my LL and BB contract with BT ends. So both ending together they can;t play the silly new contract trick.
BT really are acting like a spoiled child.  I have given them plenty of time to improve their service and finally lost patience and am leaving them.  Their behaviour in this matter does nothing to make me want any dealings with them again in the future.  I wonder if they will ever learn the way to get happy customers is give them good service?
*Some of you lucky enough to get FTTP will wonder how we manage with such a slow connection, but it is 15 times faster than wired ADSL was here and all we are ever likely to get in the near future.
45 upload is VERY fast, and for many things it is arguable that upload and reliability is much more important than download. What is your latency like?
I pay crazy money for Virgin Media and get 500mb download but only 34mb upload. Reliability is terrible. Last month i complained and they promised to discount my bill. Of course, when the bill came through yesterday, they hadn't.
Shame CFWN is only available in the Highlands.
I got my upload and download mixed up (now corrected in quoted post)  they say upload is capped at 20MBPS.
Latency, if you mean ping time 43mS
Ah. But 20mbps upload is still very decent.
There is loaded and unloaded latency, with loaded being more indicative of real world usage. run a speed test on www.fast.com to see both figures (you need to click on "show more info" then wait for the second part of the test to complete to see those figures.)
7 minutes ago, Adsibob said:
how would you know what that smells like?
I was around in the 60s, in Holland. When the girls were not working, and my parents wanted a night out, they came around and did the child minding.
Very liberal family.
So (hopefully) last bit of network reconfiguration done so everything has been swapped to the new provider.
I have repurposed the old BT router.  All it's broadband and DHCP services have been disabled as has it's wifi been turned off.  This leaves it pretty much as just a dumb 4 port network switch, which I need as I have 4 hard wired things on the network and the new router for the new broadband only has 3 ethernet ports.  So that is working and all hard wired devices are connecting and seeing the new broadband.  but the reason I repurposed the old router rather than replace it with a simple ethernet switch, was I have a HDD connected to the USB port on the BT router and that can be seen by any device on the network as a cheap and cheerful (if a bit slow) Network Accessible Storage, and I wanted to keep that. So that was the reason to keep the old BT router in circuit.
They may ask for it back.
When a relative died and we cleared their house we lost the router. Some months later Virgin called wanting it back. It was many years old. I said we had lost it and they made some noises about charging £30 but I don't think we ever did get billed.
If they do ask for it back, I will refer them to the email telling me "if you joined after December 2019 you must return your kit"
If they still insist I will send it back and seek another BT hub with the same USB port from freecycle or not much money on ebay.
Today the phone line transferred to the VOIP service with the new provider.  That should end all my services with BT.  Just got to wait for the final bill to see if they have tried to sting me for any silly charges.
I have had clarification of equipment returns, the only thing they want me to return is a 4G router that they sent to give coverage during a line fault.  Well they are welcome to it back, it never worked at all.  They are sending a postage paid return bag to send that back at no cost to me.
No mention of returning the router so I won't.
One little oddity left.
The old landline is still active, as in it still has a dialing tone.  Dialing 14707 it reports it's telephone number which is now a different number to what we had, but it won't make calls and dialing this new number from another phone says unobtainable.
Is this normal?  I expected it to just go dead with no dialing tone?
