CotswoldDoItUpper Posted August 13, 2022 Share Posted August 13, 2022 I’m considering PV and batteries from Alibaba. Now I’ve bought many things from Chiba before so I’m aware of the process/pitfalls of importing things. my main question is quality. Surely if they’re CE rated and last for only 10yrs rather then 20years like other brands but are significantly cheeper then it’s not the end of the world? is there anything else I should be aware of? Has anyone else tried this? thanks! Link to comment Share on other sites More sharing options...
ProDave Posted August 13, 2022 Share Posted August 13, 2022 I doubt they will come with the correct G99 certificate that the DNO will require here. Link to the alibaba advert? Link to comment Share on other sites More sharing options...
CotswoldDoItUpper Posted August 13, 2022 Author Share Posted August 13, 2022 I was thinking about having batteries upstream of a 3.6kWh(?) inverter therefore not needing a G99, only a G68(?). https://m.alibaba.com/product/62561537296/5000w-Solar-Panels-5kw-Solar-System.html? Link to comment Share on other sites More sharing options...
SteamyTea Posted August 13, 2022 Share Posted August 13, 2022 35 minutes ago, CotswoldDoItUpper said: CE China Export. CE is a self certificate scheme, if I remember correctly. 1 Link to comment Share on other sites More sharing options...
Dillsue Posted August 13, 2022 Share Posted August 13, 2022 20 minutes ago, SteamyTea said: China Export. CE is a self certificate scheme, if I remember correctly. CE marking is potentially meaningless for a personal import from outside the EU. If something dodgy injures you who you gonna complain to...... a company in China whos name you cant pronounce. As mentioned a few years ago rumour has it chinese companies were using a very similar CE mark that they said was a "China Export" mark and noghing to do with European CE marking Link to comment Share on other sites More sharing options...
ProDave Posted August 13, 2022 Share Posted August 13, 2022 CE mark is not the issue. The Inverter must be on the approved list and have a G99 certificate for connection to the UK grid. Link to comment Share on other sites More sharing options...
TonyT Posted August 13, 2022 Share Posted August 13, 2022 16 minutes ago, ProDave said: CE mark is not the issue. The Inverter must be on the approved list and have a G99 certificate for connection to the UK grid. like your cheap grid tied inverter? Got something similar as do loads of people…… Link to comment Share on other sites More sharing options...
CotswoldDoItUpper Posted August 13, 2022 Author Share Posted August 13, 2022 2 hours ago, ProDave said: CE mark is not the issue. The Inverter must be on the approved list and have a G99 certificate for connection to the UK grid. I assume that the same applies for a G98 certificate for under 3.68kW inverters? I also assume that I could get correctly certified inverter in the UK (as they seem less scarce!) and have it fed by any PV panel? Link to comment Share on other sites More sharing options...
Dillsue Posted August 13, 2022 Share Posted August 13, 2022 3 hours ago, CotswoldDoItUpper said: I also assume that I could get correctly certified inverter in the UK (as they seem less scarce!) and have it fed by any PV panel? Yes. Have a look on the ENA inverter database for any make/model youre thinking of buying to verify the G98 cert. If a manufacturer has bothered to type test and certify their inverter, Id be fairly comfortable buying their kit Link to comment Share on other sites More sharing options...
SteamyTea Posted August 13, 2022 Share Posted August 13, 2022 3 hours ago, Dillsue said: ENA inverter database https://www.ena-eng.org/gen-ttr/ In the past (it is a decade since I stopped workign in the industry), MCS had a list of approved modules, but inverters were 'open'. Not sure if that is stil the case now. Link to comment Share on other sites More sharing options...
ProDave Posted August 13, 2022 Share Posted August 13, 2022 When you register the install with the DNO under g98 or g99 they will expect to see the appropriate certificate from the inverter manufacturer. Link to comment Share on other sites More sharing options...
nod Posted August 14, 2022 Share Posted August 14, 2022 21 hours ago, CotswoldDoItUpper said: I’m considering PV and batteries from Alibaba. Now I’ve bought many things from Chiba before so I’m aware of the process/pitfalls of importing things. my main question is quality. Surely if they’re CE rated and last for only 10yrs rather then 20years like other brands but are significantly cheeper then it’s not the end of the world? is there anything else I should be aware of? Has anyone else tried this? thanks! If you spend x number of pounds and they need replacing in ten years Will you have saved enough on your energy bill to cover your initial outlay Our Sap is still only predicting a few hundred pounds per year saving Or am I missing something Link to comment Share on other sites More sharing options...
SteamyTea Posted August 14, 2022 Share Posted August 14, 2022 Just now, nod said: am I missing something A possible future carbon tax. This would make the modules more expensive and any imported electrical energy that was generated from gas, coal and biomass. Link to comment Share on other sites More sharing options...
nod Posted August 14, 2022 Share Posted August 14, 2022 (edited) If they faze gas out They will have to make the shortfall up somewhere Though it’s looking like a big IF at the moment To quote our Architect At the moment From a financial point of view PV doesn’t stack up But who knows what may happen in the future Edited August 14, 2022 by nod Link to comment Share on other sites More sharing options...
kommando Posted August 14, 2022 Share Posted August 14, 2022 If your inverter is not G98 or G99 approved then you can sit it behind a Mainspro protection relay which is G99 approved, to make the figures work it will need to be second hand and with the 1.6.1 firmware although the ALoMCP upgrade program for commercial sites allows 1.6.0 firmware to be used and the settings altered to match the default 1.6.1 settings. The Mainspro will take over the Grid tie disconnection duties but it must be between the inverter and the incoming supply. Link to comment Share on other sites More sharing options...
SteamyTea Posted August 14, 2022 Share Posted August 14, 2022 (edited) 31 minutes ago, nod said: To quote our Architect At the moment From a financial point of view PV doesn’t stack up Let us say that you can get PV installed at £750/kWp. A kWp will generate between 850 and 1050 kWh/year, depending on where in the country you are, and how well orientated your system is (any fool can make a PV system fail). Assuming that 50% of the PV is self use (the other 50% helps to keep others bills down), then that is, in effect, £1500/kWp. Taking a ten year life (which is very low) that is £150/kWp. Taking a median generation of 950 kWh/year, £150/ 950 kWh/year is £0.16/kWh. Or 12p cheaper than imported power. Edited August 14, 2022 by SteamyTea 1 Link to comment Share on other sites More sharing options...
Thorfun Posted August 14, 2022 Share Posted August 14, 2022 7 hours ago, SteamyTea said: Let us say that you can get PV installed at £750/kWp. A kWp will generate between 850 and 1050 kWh/year, depending on where in the country you are, and how well orientated your system is (any fool can make a PV system fail). Assuming that 50% of the PV is self use (the other 50% helps to keep others bills down), then that is, in effect, £1500/kWp. Taking a ten year life (which is very low) that is £150/kWp. Taking a median generation of 950 kWh/year, £150/ 950 kWh/year is £0.16/kWh. Or 12p cheaper than imported power. and adding in the paltry £0.05 SEG for the exported electricity brings it down to £0.155/kWh. (assuming my maths is correct!) 🙂 Link to comment Share on other sites More sharing options...
SteamyTea Posted August 14, 2022 Share Posted August 14, 2022 Just now, Thorfun said: and adding in the paltry £0.05 SEG for the exported electricity brings it down to £0.155/kWh. (assuming my maths is correct!) 🙂 5p/kWh isn't it. That makes it 11p/kWh. Not sure if you can get MCS fitted PV for £750/kWp at the moment, but self installed is a possibility. In a new build, with a suitable roof, well worth it. Link to comment Share on other sites More sharing options...
Thorfun Posted August 14, 2022 Share Posted August 14, 2022 6 minutes ago, SteamyTea said: Not sure if you can get MCS fitted PV for £750/kWp at the moment, but self installed is a possibility. this is true. we paid approx £1000/kWp for our MCS installation not too long ago and I think that the prices have gone up since then. still, using your maths above even at £1000/kWp I still think it makes financial sense, especially when the panels I bought have a 25yr warranty. so even if I get 20 years out of them with the SEG it's looking good! Link to comment Share on other sites More sharing options...
Dillsue Posted August 14, 2022 Share Posted August 14, 2022 2 hours ago, SteamyTea said: Not sure if you can get MCS fitted PV for £750/kWp at the moment, I think its typically twice that at £6k for a 4kwp Link to comment Share on other sites More sharing options...
SteamyTea Posted August 14, 2022 Share Posted August 14, 2022 2 minutes ago, Dillsue said: I think its typically twice that at £6k for a 4kwp Then that works out at 27p/kWh with the SEG. A penny shy of the cap. They know how to price these installations. Link to comment Share on other sites More sharing options...
CotswoldDoItUpper Posted August 20, 2022 Author Share Posted August 20, 2022 (edited) First two solid quotes. Obviously change the inverter out for a G98 inverter and double the battery to 6kW. Anything else I need to be aware of? Planning on putting batteries upstream of the inverter (though no idea how yet - still learning!) thanks all! Bluesun 3.5kw Off Grid Quotation 0820.pdf Bluesun 5.5kwOff Grid Quotation 0820.pdf Edited August 20, 2022 by CotswoldDoItUpper Link to comment Share on other sites More sharing options...
CotswoldDoItUpper Posted August 21, 2022 Author Share Posted August 21, 2022 This quote is with a g98 inverter. can anyone tell me if it’s ok or complete ar5e? I’ve been sent the official g98 certificate, how do I check if it’s accepted by my DNO? thanks! Link to comment Share on other sites More sharing options...
dpmiller Posted August 22, 2022 Share Posted August 22, 2022 prices don't look too bad to be but will you be actually saving very much once you get all the mounting kit locally, and deal with any Duties and the onward freight from "London Port"? Link to comment Share on other sites More sharing options...
Dillsue Posted August 22, 2022 Share Posted August 22, 2022 13 hours ago, CotswoldDoItUpper said: This quote is with a g98 inverter. can anyone tell me if it’s ok or complete ar5e? I’ve been sent the official g98 certificate, how do I check if it’s accepted by my DNO? You can check the inverter is listed on the ENA database, as above. If its on the database its hard to see how your DNO could refuse to accept your inverter. For your budget dont forget youll be charged VAT and/or import duty when the goods arrive in the UK. Link to comment Share on other sites More sharing options...
