For my many sins it’s finally time to come back and address this light well . Let’s get the laughter out the way - yes it will have walk on glazing .
As you can see it’s concrete with some PIR at the top . The concrete shuttering warped during the pour so it’s not level ( 2nd one is much worse - but that’s a problem for another day ) .
How best to line / prepare - possibly for tiling . Roofers batten vertically ( to get over the bow ) then tile backer board ??
1 hour ago, PeterW said:
Does it not need insulating ..??
No . The light well is outside the building . That window you can see is triple glazed . Council wanted it like this . So the light well isn’t even fixed to the main house .
39 minutes ago, Mr Punter said:
Rendered and painted?  Maybe some render board for the reveals.
No chance of getting a guy in to render it - so need something I can do .
I might've missed something, but how about reflective foil or similar? Sun pipes and endoscopes work by internal reflection  of glass (not the walk on type tho'...)
That would look pants wouldn’t it ? . Though you could cook in it I suppose ……
Ha ha maybe! But mirrors might give an optical illusion...
Gorilla do a waterproof coat and seal .
liquid rubber . This sounds much easier to use ….. ????
https://www.sealantsandtoolsdirect.co.uk/everbuild-aquaseal-liquid-roof-membrane-coating-21kg-grey-aqliqrfgy21?language=en-gb&currency=GBP&gclid=CjwKCAjw0dKXBhBPEiwA2bmObYa4ga9qgfDzqUIoEc6TNVy_tN6TICK6WK0cxuL0oEfAfXIOmClmxBoCZSAQAvD_BwE
expensive - but literally just paint timber / concrete upstands with this ??
Edited by pocster
doesn't say how long it will last, epdm will give you a good few years
Yes but that requires some competency. Painting shit any mung can do …
epdm is easy, look at a couple of videos for internal and external corners and general flat roofs here and just becaue it says rubber in the webpage, don't get hot and bothered
Painting is easier !
yup, but easier isn't always the same as better
Yeah it is .
Name one thing that’s easier but isn’t better ( careful ! )
