Bonner Posted May 30, 2022 Share Posted May 30, 2022 Suddenly got a joiner lined up to start next Monday but need to order all the material for stud walls PDQ 😲 CLS or regularised timber (4x2 nominal)? Door casings rebated or separate stop beads (114mm)? Link to comment Share on other sites More sharing options...
Thorfun Posted May 30, 2022 Share Posted May 30, 2022 what does your joiner say you should get? I'd be checking with them first! Link to comment Share on other sites More sharing options...
joe90 Posted May 30, 2022 Share Posted May 30, 2022 I always preferred separate stop beads, it allows you to be accurate with the doors it case either the frame or door is not completely square!. Fit the door with hinges and catch then fit the stop beads leaving a 1 mm gap for paint or varnish 🤷♂️ 1 Link to comment Share on other sites More sharing options...
Bonner Posted May 30, 2022 Author Share Posted May 30, 2022 57 minutes ago, Thorfun said: what does your joiner say you should get? I'd be checking with them first! He prefers CLS as it’s easier to work with but regularised is cheaper and a bit wider (95 vs 89mm) Link to comment Share on other sites More sharing options...
Bonner Posted May 30, 2022 Author Share Posted May 30, 2022 58 minutes ago, joe90 said: I always preferred separate stop beads, it allows you to be accurate with the doors it case either the frame or door is not completely square!. Fit the door with hinges and catch then fit the stop beads leaving a 1 mm gap for paint or varnish 🤷♂️ That makes sense, just thought a rebated frame would feel more solid but suppose you wouldn’t notice any difference once it’s done Link to comment Share on other sites More sharing options...
Thorfun Posted May 30, 2022 Share Posted May 30, 2022 1 hour ago, Bonner said: He prefers CLS as it’s easier to work with but regularised is cheaper and a bit wider (95 vs 89mm) Do you need wider internal walls? Our TF company used 89mm CLS for ours. if your joiner prefers CLS is he likely to charge more to use non-CLS as it might make things take longer? If so it could negate any savings on materials. just a thought. Link to comment Share on other sites More sharing options...
joe90 Posted May 30, 2022 Share Posted May 30, 2022 1 hour ago, Bonner said: That makes sense, just thought a rebated frame would feel more solid but suppose you wouldn’t notice any difference once it’s done If the frame or door is out a bit with a rebated frame your knackered, if the door warps a little in the future you can move them 👍, I also tend to glue them in case people slam doors (my pet hate) 🤷♂️ Link to comment Share on other sites More sharing options...
Bonner Posted May 30, 2022 Author Share Posted May 30, 2022 5 minutes ago, joe90 said: If the frame or door is out a bit with a rebated frame your knackered, if the door warps a little in the future you can move them 👍, I also tend to glue them in case people slam doors (my pet hate) 🤷♂️ Okay, I’m convinced! 😄 Thanks Joe 1 Link to comment Share on other sites More sharing options...
Bonner Posted May 30, 2022 Author Share Posted May 30, 2022 8 minutes ago, Thorfun said: Do you need wider internal walls? Our TF company used 89mm CLS for ours. if your joiner prefers CLS is he likely to charge more to use non-CLS as it might make things take longer? If so it could negate any savings on materials. just a thought. No, you’re right. Labour costs more than the material so I’m better off staying with standard. Cheers Link to comment Share on other sites More sharing options...
Gus Potter Posted May 30, 2022 Share Posted May 30, 2022 3 hours ago, Bonner said: Suddenly got a joiner lined up to start next Monday but need to order all the material for stud walls PDQ 😲 CLS or regularised timber (4x2 nominal)? Door casings rebated or separate stop beads (114mm)? Hope this helps a bit. Just watch the timber thickness.. as in an 89 depth it is often 38 mm thick as opposed to 45mm thick that you get with grade C16/ 24 95 x 45. Please ignore the branding, it's just a snippet I have in one of my data sheets, makes for easy reading though. 1 Link to comment Share on other sites More sharing options...
Thorfun Posted May 30, 2022 Share Posted May 30, 2022 49 minutes ago, Gus Potter said: Hope this helps a bit. Just watch the timber thickness.. as in an 89 depth it is often 38 mm thick as opposed to 45mm thick that you get with grade C16/ 24 95 x 45. Please ignore the branding, it's just a snippet I have in one of my data sheets, makes for easy reading though. My whole house is 38mm thick CLS!! 140mm external and load bearing and the rest 89mm. seems pretty standard for TF companies. 1 Link to comment Share on other sites More sharing options...
Gus Potter Posted May 30, 2022 Share Posted May 30, 2022 4 minutes ago, Thorfun said: seems pretty standard for TF companies. Yes it is standard stuff, nothing wrong with it. In fact most of the big TF companies seem to use it. On the practical side if you are a self builder then you have to be more accurate to fix plasterboard to a 38mm wide stud than a 45mm wide stud. In certain windy places or if you have slightly higher walls (longer studs) it can work out economically if you use the slightly deeper 95 x 45 timbers as this lets you keep a 600 centre stud spacing rather than going for a 400 centre stud spacing. It's not just the extra timber as when you have 400 centre studs you get closer repeating bridges which impacts on the insulation performance. The main thing is that an 89 x 38 mm stud has different load bearing and wind resisting properties compared with a 95 x 45 size. Would be a shame to do a lot of work and BC knock you back. Best to check first. 2 Link to comment Share on other sites More sharing options...
MortarThePoint Posted May 30, 2022 Share Posted May 30, 2022 (edited) Aren't CLS and Regularised both eased edge? Why does Chippie prefer the CLS? Is it because it's lighter? Or is CLS typically straighter? Spot whose not a TF expert 🙂 Edited May 30, 2022 by MortarThePoint 1 Link to comment Share on other sites More sharing options...
Bonner Posted May 31, 2022 Author Share Posted May 31, 2022 Thanks for all the replies, should have explained its for internal (non load bearing) stud walls. Large part of them are 3.3m high, hence wanting the slightly thicker section, as well as 400 centres! Another issue is door casings are 114mm to fit 89mil studs + 2x12.5 board. Next size is 138/140mm. I am going to the timber merchant this morning to look over it. Link to comment Share on other sites More sharing options...
markc Posted May 31, 2022 Share Posted May 31, 2022 Easy to rip door casings down to size 1 Link to comment Share on other sites More sharing options...
Thorfun Posted May 31, 2022 Share Posted May 31, 2022 9 hours ago, Gus Potter said: Yes it is standard stuff, nothing wrong with it. In fact most of the big TF companies seem to use it. On the practical side if you are a self builder then you have to be more accurate to fix plasterboard to a 38mm wide stud than a 45mm wide stud. In certain windy places or if you have slightly higher walls (longer studs) it can work out economically if you use the slightly deeper 95 x 45 timbers as this lets you keep a 600 centre stud spacing rather than going for a 400 centre stud spacing. It's not just the extra timber as when you have 400 centre studs you get closer repeating bridges which impacts on the insulation performance. The main thing is that an 89 x 38 mm stud has different load bearing and wind resisting properties compared with a 95 x 45 size. Would be a shame to do a lot of work and BC knock you back. Best to check first. all makes perfect sense. I'm using 2"x1" roofing battens for my service cavity battens and so will be fixing the OSB/plasterboard to that so all I have to do is ensure I hit the 38mm timbers with the battens and then I've got 45mm to hit with the plasterboard screws! 😉 Link to comment Share on other sites More sharing options...
JohnMo Posted May 31, 2022 Share Posted May 31, 2022 Our non load bearing partition; 45x70mm w/w/reg treated timbers faced with 12.5mm plasterboard. Did noggins (if that's the right word) every 1200mm, walls are up to 3.6m high. Filled with 50mm dense Rockwool. Seem well solid. Link to comment Share on other sites More sharing options...
Bonner Posted May 31, 2022 Author Share Posted May 31, 2022 41 minutes ago, JohnMo said: Our non load bearing partition; 45x70mm w/w/reg treated timbers faced with 12.5mm plasterboard. Did noggins (if that's the right word) every 1200mm, walls are up to 3.6m high. Filled with 50mm dense Rockwool. Seem well solid. Interesting, that’s quite a small section but good know it feels solid. What spacing are your studs? Link to comment Share on other sites More sharing options...
JohnMo Posted May 31, 2022 Share Posted May 31, 2022 600mm centres 1 Link to comment Share on other sites More sharing options...
Simplysimon Posted May 31, 2022 Share Posted May 31, 2022 On 30/05/2022 at 22:29, MortarThePoint said: Aren't CLS and Regularised both eased edge? Why does Chippie prefer the CLS? Is it because it's lighter? Or is CLS typically straighter? Spot whose not a TF expert 🙂 i was always under the impression cls same in 63 & 89 x 38 and any thing else that has come along since is regularised, but i'm not canadian Link to comment Share on other sites More sharing options...
Bonner Posted June 1, 2022 Author Share Posted June 1, 2022 On 30/05/2022 at 22:29, MortarThePoint said: Aren't CLS and Regularised both eased edge? Why does Chippie prefer the CLS? Is it because it's lighter? Or is CLS typically straighter? Still not sure, seems to be all he knows or maybe he calls all framing timber CLS?! Anyway I went to the timber merchant and looked at both, you can hardly tell the difference. CLS is paler in colour, presumably because it has more planed off. Both straight, smooth, kiln dried and rounded edges. Regularised (C16) is available in 3.6m lengths from stock and costs less per metre. So bigger timbers for less money with less waste, ordered! 1 Link to comment Share on other sites More sharing options...
