Wood wool board as final internal finish
Has anyone used wood wool board (eg https://www.celticsustainables.co.uk/savolit-plus-wood-wool-boards/ ) as a final finish on walls, albeit painted? We've got quite high vaulted cielings and a concrete floor so our architect suggested this to be used in some areas to help improve the acoustics, as well as for the aesthetics of it. I quite like the look of it - and also the fact we will reduce some of our skimming costs. Has anyone here used this before in this way?
Are they not an expensive alternative to plasterboard
The manufacture seems to be recommending lime plaster or render
I’d check with the manufacturer if they are flammable If you have to apply a fireproof paint It will be quite expensive
No but Center Parcs used to in their villas in the non-essential areas and it looks like sh#t …
At £35 ish for the same coverage as your standard board and skim, it is probably double the cost. It also isn’t fire resistant so would need an (expensive) intumescent coating
Aha, good point re fire resistance. They are described as non-flammable and self-extinguishing, but comes down to the regs I guess. I have emailed the UK distributor to ask...
I would forget any monetary saving
It will be more expensive
But if it is the look you like
Go for it Speak to the manufacturers
Then get a decision off BC
They May make your decision for you
Yep, will see what I can find out.
Interesting that you saw them used at Centre Parcs, Peter. Could be worse I suppose, could have been Butlins...
Years ago, when I was at school, and over the summer break all the asbestos was removed, that was the finish that was left on all the corridor ceilings.  and yes I thought it looked rubbish and "unfinished"
Those wood wool boards are rough as they're specifically designed to carry plaster or render. You'll also find that they're not acoustically rated. The acoustic rated ones are a lot more expensive. You can get some nicer panels with both fire and acoustic ratings from Troldtekt or Celenit but they will cost significantly more .
True, but what I can see these ones and just the standard look pretty similar - and I wonder if the premium is just for the rating certificate. I'll see if I can get some samples of both
  • 2 months later...
For what it's worth I just had the same thought for a cathedral ceiling / wood floor application.
My notes:
https://www.cewood.com/products-eng
https://izoliacija.com/produktas/cewood-akustine-plokste-naturali/
https://izoliacija.com/produkto-kategorija/akustine-izoliacija/
"Construction" grade cheaper / rougher (3 mm fibres)
https://online.depo-diy.lt/product/705
"Decor" grade spendier / finer (1 mm or 1.5 mm fibres)
https://online.depo-diy.lt/product/701
Plaster over the rougher construction grade for sound isolation. Leave the decor grade unfinished for sound absorption.
https://en.wikipedia.org/wiki/Mineral_bonded_wood_wool_board
Some fire and fitting notes:
https://www.cewood.com/video-1
Painting sounds like a pain:
https://www.baux.com/faq/can-i-repaint-my-installed-baux-acoustic-products/
Pinterests:
https://www.pinterest.co.uk/pin/291678513374269376/
https://www.pinterest.co.uk/pin/194991858856196266/
https://www.pinterest.co.uk/pin/111323422029673729/
https://www.pinterest.co.uk/pin/688980442995825160/
Will probably end up with taped and jointed plasterboard. Will probably regret it acoustically!
I don't think suspending the ceiling on the 'genieclip' style donuts plus metal bars will achieve the same result. Those are for isolation not absorption. More notes to self:
Genieclip:
https://www.soundstop.co.uk/soundproofing/soundproofing-ceilings/genie-clip-solution1.php
https://www.gyprock.com.au/products/accessories-resilient-mount-clip
Equivalent for hanging plasterboard off joists on metal channels
https://online.depo-diy.lt/product/2681#2681
https://online.depo-diy.lt/product/2582
Bathroom / bedroom perhaps.
  • 3 years later...
Hi @markocosic did you end up using the wood wool board? We are thinking of the same thing. The more expensive option is designed for show and I am pretty sure is fire rated. I think I read its used a lot for ceilings in Denmark
  • 2 months later...
We did not @markharro
- 50 x 50 mm battens on 600 centres
- 50 mm mineral wool between battens
- 120? mm tongue and groove over the top
Because:
- She who must be obeyed liked the look
- It'll get handprints on it on the mezzanine that would be a pain with wood wool
- Plasterboard painted would have showed every mark / cracked at every opportunity
Acoustically the T&G over mineral wool is fine. Not as hard a reflection as plasterboard. The gaps and air movement to the mineral wool probably aid acoustics.
