MarkH Posted April 27, 2017 Posted April 27, 2017 This is an obscure topic but I don't suppose anyone would have an idea of the size of studs we'd need to attach 225x75mm timbers to our walls (using vinylester resin)? The timbers will support joists (also 225x75) spanning 4.8m (on hangers). I used M12 in the smaller part of our house but I'm wondering if I should size up...
Carrerahill Posted April 27, 2017 Posted April 27, 2017 (edited) Oddly our extension calls for almost an identical connection to the existing house - our building warrant drawings show M10 stainless threaded rod at 600mm centres using: http://www.rawlplug.co.uk/products/bonded-anchors/injection-cartridges-systems/polyester-resins/r-kf2/ I would check with your architect or engineer or inspector though. Edited April 27, 2017 by Carrerahill
Alexphd1 Posted April 27, 2017 Posted April 27, 2017 Slightly different but our engineer was happy with 12mm threaded bar (cast into icf concrete) at 600mm centers but our longest span is 6m. We ended putting them in at 400mm centers as the joist is 400mm centers, we are also using the posi joist on the top chord saving using hangers.
Mr Punter Posted April 27, 2017 Posted April 27, 2017 M12 same centres as the joists. Make sure you don't clash with the hangers or joist ends. Threaded bar is cheapest. Make sure you vacuum or brush out the holes properly. 1
Carrerahill Posted April 27, 2017 Posted April 27, 2017 8 minutes ago, Mr Punter said: M12 same centres as the joists. Make sure you don't clash with the hangers or joist ends. Threaded bar is cheapest. Make sure you vacuum or brush out the holes properly. Yeah, best piece of advise when using resin, clean out the hole. I have seen these fail because muppets drill a hole and then just back fill with resin, it sets up a treat in the powder which is like a release agent!
Onoff Posted April 27, 2017 Posted April 27, 2017 Vacuuming the holes out is not the best tbh. I mean it's alright but try it then follow up with a puffer like this and see how much more crap comes out. Puffers a must! http://www.screwfix.com/p/rawlplug-hole-cleaning-pump/6995f (My company fits safety harness eyebolts etc btw).
Alexphd1 Posted April 27, 2017 Posted April 27, 2017 I was just looking at those! http://www.ebay.co.uk/itm/142183010077?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Onoff Posted April 27, 2017 Posted April 27, 2017 8 minutes ago, Alexphd1 said: I was just looking at those! http://www.ebay.co.uk/itm/142183010077?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT That £6 one will do.
Mr Punter Posted April 27, 2017 Posted April 27, 2017 11 minutes ago, Onoff said: Vacuuming the holes out is not the best tbh. I mean it's alright but try it then follow up with a puffer like this and see how much more crap comes out. Puffers a must! http://www.screwfix.com/p/rawlplug-hole-cleaning-pump/6995f (My company fits safety harness eyebolts etc btw). I gaffer a bit of pipe to the end of the vacuum, stick it in the hole and it works a treat. 1
Onoff Posted April 27, 2017 Posted April 27, 2017 Been there, tried both. If really stuck you can gaffer tape a resin nozzle onto the hoover end (remove the mixing screw). Some vacs have the option to attach the hose to suck or blow - alternate between the two. Puffer all day long for me! The "puffing" in/out action is gentler but dislodges more dust than either I reckon. I'm sure yours will be fine, it's pretty much all in shear & it's not like your hanging a man off it!
Mr Punter Posted April 27, 2017 Posted April 27, 2017 Top Customer Reviews 1.0 out of 5 starsPffffff..Even my farts are stronger.. By Marius on 19 Jan. 2014 This pump is a joke..and would you be wasting your time trying to blow out debris. The Pressure that comes out of the nozzle..is NO where near strong enough to even make an impact. Dont waste your time with this product..as there is a reason why it is so cheap compared to the rest of the higher priced pumps. You would honestly be better of making use of a Bicycle pump for this matter.. Comment Was this review helpful to you? YesNo Report abuse 1.0 out of 5 starsOne Star By a warren on 14 Jan. 2017 Verified Purchase Absolutely rubbish, was thrown in the bin after one use, no wonder it's cheap Comment Was this review helpful to you? YesNo Report abuse 1.0 out of 5 starsNope By Paul on 15 Jun. 2016 Hearing aid puffer and a small piece of plastic tubing. Works wonders ! Comment Was this review helpful to you? YesNo Report abuse
Onoff Posted April 27, 2017 Posted April 27, 2017 4 minutes ago, Alexphd1 said: Bugger My fault entirely! It looked the same 'ish as my Rawl one. However...go buy yourself the Screwfix one. By way of apology I've just PayPal'd you the money.
Alexphd1 Posted April 27, 2017 Posted April 27, 2017 Pay your money take your chances with silverline!!! The money will be returned!
Onoff Posted April 27, 2017 Posted April 27, 2017 3 minutes ago, Alexphd1 said: Pay your money take your chances with silverline!!! The money will be returned! Now I'm feeling doubly guilty!
MarkH Posted April 27, 2017 Author Posted April 27, 2017 I'll probably use my compressor to blow out the holes. Last time - with no compressor or puffer thing to hand - I used a toothbrush attached to a drill whilst hosing water down the holes, they were very clean afterwards. I was using vinylester resin so a moist hole wasn't an issue.
Onoff Posted April 27, 2017 Posted April 27, 2017 3 minutes ago, MarkH said: I'll probably use my compressor to blow out the holes. Last time - with no compressor or puffer thing to hand - I used a toothbrush attached to a drill whilst hosing water down the holes, they were very clean afterwards. I was using vinylester resin so a moist hole wasn't an issue. A moist hole is generally always better I find! Seriously, going way, way back I'm pretty sure there was something we got from Rawlplug about it. We were fixing anchors in the soffits of a building in Norwich and there were leaks around the windows. It's all blurry now but sure they said that moisture wouldn't effect it and possibly even enhanced the cure.
bassanclan Posted April 27, 2017 Posted April 27, 2017 I went for the expensive option, nicked a straw from KFC! A little pipe cleaner/ brush is also a good idea.
Onoff Posted April 27, 2017 Posted April 27, 2017 All I can say is TFI all the above are in shear! Spend a tenner FFS! Many years ago my mate was doing his extension. Back then we were as green as and it was all glass break resin capsules "mixed" with hex head, chisel pointed studs in a pistol drill. He ran out despite calculating the number and even though we could get them for free . Realising that they were just dropping straight down the cavity newspaper was duly rolled up and balled then shoved in the holes. Having to get the angles on, joists in and boarded ready for the plasterer it transpired that a big tub of Isopon car body filler worked just as well. BCO was happy as he hung on the RSA to check!
ToughButterCup Posted May 17, 2017 Posted May 17, 2017 On 4/27/2017 at 18:04, MarkH said: [...] I used a toothbrush attached to a drill [...], they were very clean afterwards. [...] That tip has just dug me out of a hole. Needed to cut to the brush down a bit, but still... Tops! Thanks Ian 1
Alexphd1 Posted May 18, 2017 Posted May 18, 2017 We finally used the silverline pump. It done the job fine.
